Question about Dometic Rooftop RV Air Conditioner
Ac and furnice both come on when I turn on the heat
RV central heat and air both come on when I turn either one on
    Genius:
  • Dometic Master
  • 1,363 Answers
Faulty t-stat or relay modulre
Posted on Aug 16, 2015
Wiring from coleman rv ac unit has 6 wires and duotherm rv ac unit has 10--what do you do with other wires
you need a wiring diagram of each to see what they are for. heat pump, auxillary heat, inside sensor, outside sensor, electric heat, gas heat there are many different applications.
Aug 20, 2015 | Coleman Heating & Cooling
Coleman mach rv central air conditioner maintenance
maintaining rv a/c is just a matter of changing filters, cleaning coils and drain lines. visual inspection of wireing for heat damage.
Jun 18, 2014 | Coleman Heating & Cooling
RV. when furnace is turned on , fan on rooftop AC unit runs continually
i would say its the relay board or communication cabl between stat and board.
Jun 18, 2014 | Dometic Rooftop RV Air Conditioner
I have Lux DW 1100 ver 2.2 Thermostat,and set temp to 20 C but last few days thermostat do not turn off furnice even tempreature is over 22-23C what usually did turn off. Tempreature get to 25-28C and I...
i have never liked the LUX brand due to faults that i seen you can replace due to having a long warrentee and possibly not have this problem again but a honeywell t-stat would be my recommendation to replace also white rodgers is a good brand
Mar 05, 2011 | Heating & Cooling
Central heating not working properly and maybe a problem with the timer
To getproper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV
Dec 15, 2010 | Honeywell Heating & Cooling
The fan on the Ruud furnice unit runs all the time but the Ruud ac unit is not kicking on . I know nothing about any of this but would like some Ideas what I might check. I went outside and could not find...
Some Ruuds have a red rubber cap reset button on the bottom of the unit or inside. Usually the fan quits and trips the switch. Or look at the metal run cap with 3 leads on it, if it looks bulged(concave on top) and not flat and sunk in, replace that and ur good to go. Let me know. Please pull the power disconnect if you attack the cap, and write down what leads come off which terminals. azeddysac@yahoo.com
Aug 14, 2010 | Ruud Central System Air Conditioner
Central Air- Breaker flips when AC is turned on
IT SOUNDS LIKE YOU HAVE A BAD COMPRESSOR OR A DEAD SHORT SOME WHERE IN THE UNIT
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
AC Thermostat wiring
YES U SHOULD MOUNT IT
May 10, 2009 | Heating & Cooling
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
