Question about Dishwashers
HOW DO YOU REPLACE PLASTIC FACIA ON BOSCH SGS65L22GB/07 DISHWASHER THE PART NO IS 00449039 IT IS A PLASTIC FACIA WHICH INCORPORATES THE HANDLE WHICH IS CRACKED
5 Suggested Answers
SOURCE: Broken door handle Indesit dishwasher DG 6100
broken door handle solution
Posted on Mar 07, 2008
SOURCE: Bosch Door Handle: Loose
I had the same problem with my Bosch dishwasher.I came to this web site to find out how to get the door off.I took the experts advice,placed 4 pillows on the floor in fromt,opened the door,took out the screws and the front panel dropped down.It was so easy,the plastic spacers stayed in place.I put a little J B weld on the handle screws and tighted the handle and put everything back together,12 minutes tops.Thanks for the help,thankful in Georgia
Posted on Feb 21, 2009
bugsy33
  • 33 Answers
SOURCE: Water leaking from the bottom of the dishwasher.
check water valve seal sounds like its broke also check water lines going in might not be tight
Posted on Dec 05, 2009
SOURCE: I have a Bosch dishwasher that now doesn't easily
This is a child safety latch. It opens the door when slid to the right.
It can be reset to off by sliding it to the right and inserting a tooth pick into the small hole under the handle. It is hard to see and do! Get on the floor and look up.
It will stay over to the right when you are done.
If the plastic face panel is broken or cracked it will need to be replaced 8>(
HTH,John
Posted on Jan 19, 2012
The plastic handle that opens the door to the dishwasher is cracking. Is there a replacement handle we can purchase?
Yes. If you you go to appliancepartspros.com site you will find just about every appliance and the parts for them. Just have the brand and model number handy.
Aug 27, 2015 | Bosch Dishwashers
Loose door handle
Here is the link to the installation manual; http://www.bshextranet.com/files/techtoolbox/SHV46C13-SHX43Cii.pdf pages 14 and 9 of the manual (16 and 11 of the pdf) describe how to remove the toe panel, and the door facia panel. You should then be able to access where the handle is attached. Hope this helps :)
Jul 15, 2007 | Bosch SHV46C03 Built-in Dishwasher
Bosch dishwasher sgs43e how do I replace water filter
Bosch dishwashers don't have water filters per say. It may have a salt water softening system. It does have a small mesh filter in the inlet hose but if there is any kind of actual water filter inline with the system then it is external to the dishwasher.
They do have though microfine filters in sump of the unit which require cleaning regularly. This is removed by turning the plastic handle anticlockwise on the grill which is under the bottom spray arm. You turn the plastic handle to unlock the grill and lift it up revealing the filters.
Refer to the user manual for more information. If you don't have it, you should be able to download it from the BSH website.
Jun 09, 2014 | Bosch Dishwashers
Install panel facia on bosch dishwasher
You should be able to google your model number and get step by step details.
Jan 28, 2013 | Bosch Dishwashers
I have a Bosch dishwasher that now doesn't easily open. The handle mechanism seems to be breaking. Can feel a plastic strip poking out from under the handle.
HTH,John
Oct 22, 2010 | Bosch 24 in. SHE47C05UC Stainless Steel...
Replacing door seal front loader bosch
This video will show you how to change a door seal on this bosch
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
Bosch Dishwasher Problem
if you remove the front panel (the 6 torx screws) and the facia panel you can access the control module. remove the module and open it up to see if you have a burn mark from the solder melting. if you do then you know to replace the control module
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Change a white door to stainless??? can I
Okay here we go. The SHU43C05UC/17 is the stainless model. The parts needed to change over to SS are 1) 431828 SS Facia cost 72.80. 1) 417981 power switch button 15.40. 1) 426062 program buttons set 5.40. 1) 214750 SS outer door panel 101.50. 1) 426063 lid (fits inside the handle area) 3.90. As you see it will not be cheap to change over to a SS dw. These prices are from Bosch's Quick Finder website. Hope this helps.
Mar 31, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher SGS43E02 Exxcel Control/Display Facia Panel
The panel is replaceable by removing the #20 torx screws inside the door. Once removed the metal outer door cover will slide down and the plastic top housing less switch panel can be unclipped from two locking tabs on either side. You can order via BOSCH service center, check to see if it is warrantied before removing
Feb 06, 2008 | Bosch 24 in. SGS43E02 Exxcel Built-In...
Dishwashers Logo
Top Dishwashers Experts
