Question about zee Software Android Apps
Need factory software for zeepad 9"
Where do get drivers for zeepad 9?
When you connect something to an USB port for the first time, don't hope to much. You have to be sure the computer has the correct software to recognise the hardware and can work with it. From Windows 7 and up, for all hardware that is certified with Microsoft, you can download the drivers from Microsoft. Lots of hardware is recognised when connected and will initiate a download from Microsoft. But not all hardware will do so and not all hardware is compatible (same as not certified by Microsoft from Windows 7 and up) with the new operating systems.
Most things that worked fine with Windows XP and or Vista, can fail with Windows 7 and 8, because the factory that made the hardware in the first place does not ask for certification with Microsoft for their old Hardware. They only spend time and money to get their new hardware certified on the new operating systems. So to make sure your hardware is compatible with the OS. Check the manual and find out, what you have to do so it will work on your computer.
If your device was working on a USB2 port, it also should work on an USB3 port, on the same computer. But don't expect another speed, because the slowest part decides the speed.
Mar 22, 2015 | ZEEPAD 9XN Dual-Core 1.5GHz 512MB 8GB 9"...
Will my zeepad charge threw my pc. charge light has come on but zeepad has not
You cannot use a computer USB port to charge a tablet, unlike charging a smartphone. You will have to use the supplied charger. If you really want to use the USB port to charge your Zeepad, you will need to custom-built a cable using any extra USB cable you can spare. Just change the connector at the remote end of the cable to one that suits your Zeepad's 5V DC IN socket. You are forwarned the connector is not easy to find.
Jan 12, 2015 | Red Tablets: Zeepad 9XN Dual-Core 1.5GHz...
What is Zeepad Customer Service phone number?
Sorry to say, Zeepad's website (zeepad.net) has had it's contact us and about us links deliberately removed. Also it looks like the domain is for sale (http://whois.domaintools.com/zeepad.net) I am also pretty sure that the site is hosted in China a so good luck contacting them.
Dec 26, 2014 | ZEEPAD 7DRK Dual Core 4.2 Blue Android...
How can I reboot my Zeepad?
Here are the some simple steps to hard reset your ZeePad 7.0:- 1.)First of all,Go to Settings -> Storage -> Factory Data Reset. 2.)Otherwise,Power of the device completely. 3.) Now,Hold down both volumes and power button simultaneously. 4.)After doing this,you should get an android on its back opened up or something. 5.)Now,Press both volumes at same time to open up a small blue text menu. 6.)Then use Vol - and Vol + to navigate the Recovery mode. 7.)Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
May 16, 2014 | ZEEPAD 7 inch Android 2.2 Tablet
Too many pattern attempts!!!! My 9 yr old niece
Hello Ladybug.
Did WE TRY holding down the power button for a full 10 second count...?
Carnac the Magnificent
Apr 23, 2017 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
How do i reset a zeepad
To reset your zeepad you must reload the firmware to it. For instructions go to
www.zeepad.net
Jul 17, 2012 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
Android Apps Logo
69 people viewed this question
Top zee Software Apps Experts
Stan Ford
Jessica Tricial
Jessica Tricial
Level 1 Expert
Are you a zee Software App Expert? Answer questions, earn points and help others
