Question about Hitachi 42HDS69 42 in. Plasma Television
How do i scan
Cant scan for channels
Cant get channels even after channel scan. all snowy screens except channel 3 which is fish swimming around.
Go in the menu and make sure the antenna setting is set to AIR and not CABLE before you start the scan. If that doesn't fix your problem then something with the main board is the problem
Mar 02, 2015 | Insignia Televison & Video
One radio clicks when the other is mic
Scanning is interrupted when you key the other unit's mike. For example, if the non-scanning unit is set to channel 13 and keyed scanning will stop at channel 13 on the other unit to establish communication between the two.
Nov 07, 2013 | Midland LXT310 2-Way Radio
Have just moved house .....have retuned tv ....but cant get any BBC channels
Automatic scan cannot detect the BBC channels, possibly because they are too weak in your new location. It should be possible to add channels manually by using your remote. The setup function of your TV may give you the option of adding channels manually
Oct 14, 2012 | Grundig Televison & Video
Cant get any bbc channels on new alba tv freeview
In that case you need to auto scan your TV to get all available channels on your location..
Go to menu and find auto scan and enter it..For best results please complete the 100% scan..
Aug 28, 2012 | Televison & Video
Cant seem to scan channels?
Press the PGM button,Press Trunk, repeatedly press mode to select MOT,press PGM, enter the frequency you want, then press Enter to store it,if you make a mistake, press CLR. ...You can get your frequency's at www.RadioReference.com .....hope this was helpful
May 19, 2010 | Uniden BC92XLT Handheld Scanner
I cant get them to stay on same on the same channel
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T4500_User_Manual_E.pdf
Read the section on channels and frequencies followed by programming your radios to match one another. Then also read the section on scan. It sounds like you may have your radios in scan mode.
Nov 17, 2009 | Motorola T4550FP (22 Channels) 2-Way Radio
Cant attain digital channel scan on hitachi rear projection tv
Do you have the tuner locked out for use of HDMI input only?
Most of the time when a selection is not able to be hi-lited it is
because a feature that is activated locks out other selections.
Hope this helps,
Skyassoc
Jun 17, 2009 | Hitachi 51F59 51" HDTV Projection...
VIORE PLC7V95 7'' portable TV, cant get channels when scan
I notice that on mine, the positioning of the included tv antenna is very, very, very finicky. I also don't know how to "add" a new channel other than to hook it to the big house antenna and pick "re-scan" (or auto-scan or whatever it's called).
So I think your best bet is to pick a better antenna or know that even the tiniest fiddling with the antenna makes a diff. Sometimes, I even have the antenna horizontal (using the magnet) to get the good reception on a given channel. Seems like a hassle except that what should I expect from a tiny antenna....
Jun 15, 2009 | Televison & Video
Cant get all channels
Instead of doing auto scan the should be a option for channel list or add\delete or manual scan. What kind of tv is it? You don't have a cable box right? If you still have trouble, just comment on this.
Mar 15, 2009 | Televison & Video
Hitachi 42HDS69 42 in. Plasma Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
