Question about Toshiba Office Equipment & Supplies
Need ''document exit tray'' for toshiba tf621
    President:
  • 1,126 Answers
The Toshiba part number is 12072171 Tx Tray
Posted on Jun 19, 2009
Inner tray is full
Inner tray is where the paper exit...
Jan 03, 2017 | Toshiba Office Equipment & Supplies
Toshiba model 455 error code CDF0
CDF0 is offset tray error on the exit unit, mostly due to the offset motor problem
Mar 05, 2014 | Toshiba e-Studio 350 Copier
Close Front Cover For Toshiba E-studio 350
Make sure the front cover is closed firmly, triggered the front switch, u can see clearly by removing the paper exit tray.
It might be front cover switch problem also.
Sep 27, 2013 | Toshiba e-Studio 350 Copier
False Jam at exit on a Toshiba DP3580 copier
make sure your drawer size shows 11x17 on display if not push user interface button then select the drawer and set it to 11x17
Jul 04, 2017 | Toshiba DP2570 Printer
INNER TRAY
the inner tray is where the paper comes out under the top scanner part there is a paper sensor at the exit mark that tells you if you have paper in the tray and lets the machine know it has come out ok. check that it hasnt locked in place.. this can give a false reading too..Good luck
Oct 27, 2009 | Toshiba Office Equipment & Supplies
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
Automatic document feeder
U need to check whether the flap-exit is working or not.
http://img.photobucket.com/albums/v390/anthonydidi/flap_exit.jpg
May 12, 2009 | Toshiba Estudio 200L Copier
Toshiba 281C Bypass tray
Problem isn't "solved", but have realized that the issue is related to the fact that the document I am trying to print is formatted for envelopes. When I print a regular word document (letter) it prints fine to the Bypass tray. It must have something to do with the fact that the document is 1000 envelopes. If I print to a PDF file, then print the document to the Bypass Tray I don't seem to have a problem.
Feb 17, 2009 | Toshiba Estudio 200L Copier
XEROX 6110 coloer printers
Xerox 6110 Code Description A1-1 to A1-32 All indicate a paper path problem, etc. in the ADF A2 ADF exit problems A3 Irregular size documents A5 ADF interlock A6 ADF single sheet document reset A7 Platen interlock A8 ADF exit interlock C1 Tray 1 jam C2 Tray 2 jam C3 Tray 3 jam C6-1, C6-2 Jams related to duplex C6-3 Registration sensor, re tray 1 C7-1, C7-2 HCF feed problems C7-3 Tray 1 feed problem C8 Paper stays in tray or duplex or HCF C9 Bypass feed problem E1-10 to E1-25 Internal jam E1-6 Paper on registration sensor E2 Reset signal happened. Might read E-2 something else E3-30 to E4-14 Exit jam E3-6 Exit jam E4-10 to E4-14 Inverter sensor not actuated E4-15 Inverter sensor E4-40 to E4-45 Duplex entry sensor E4-6 Inverter sensor E5 Front door interlock E6-1 Tray 1 interlock E6-2 2 tray or duplex interlock E6-3 HCF interlock E7-2, E7-3 Duplex interlock E8-6 to E8-15 Duplex entry sensor F1-1 Sorter entry sensor F1-6 Sorter exit sensor F3 Paper size not available for sort/stack F5 Sorter interlock J1 Add toner J3 Replace copy cartridge J7 Replace copy cartridge J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM L6 Auditron or other counter problem L8 Platen glass temperature is too high L9 Communication problem between interimage erase/edge lamps and main board U1-1 Main motor drive problem U2-1 to U2-4 Scan home sensor U3-1 Lens sensor U4-1 Open fuser thermistor U4-2 Fuser did not warm up properly U4-3 Fuser temperature too high U4-4 Fuser problem. Staying on too long U4-6 High fuser temperature U5-1 Sorter bin home switch not activated U5-2 Sorter bin home switch stayed actuated U5-3, U5-4 Sorter bin home switch U6-1 ROM problem U6-2 RAM problem U6-3 Low battery U6-4 Incorrect value in NVM. Reinitialize main board with code 20-96 U8-1 to U8-6 Problem with exposure lamp, lamp sensor, lamp board
Jan 03, 2009 | Office Equipment & Supplies
Change default tray for E-studio 520
go to Control panel, select printers and faxes (windows XP),then select es520,right click properties, select Tab advanced,then you should click on printing defaults. then will open toshiba driver defaults,go to paper handling tab. THERE IS option called "destination" and there you can chose exit tray (inner,tray1,tray2...etc). After selection you must click apply and then ok. and that it. every time after that documents will be printed out to selected tray.
Jul 25, 2008 | Toshiba COPIERS E-STUDIO 520 Copier
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
