Question about Toshiba 57H82 57" Rear Projection Television
Wavy Problem again
I've read about several others with the wavy picture, and from reading, I need to change out the caps. I couldn't find anything specific on this (how many are there, where are they at, etc). Is there any more info out there on this? Any help would be appreciated! Thanks!
  • 105 Answers
Re: Wavy Problem again
Changing caps wont do much good. if you look into the tv you will see two large stk ics they are mounted to two large heat sinks. i do believ they are stk392-120 or stk392-110. you should also check the sorounding components like resistors and fuses.
Posted on Oct 31, 2007
0 characters
3 Points
Toshiba 50H82 with wavy lines at the top when in HD mode
Found this person on eBay who repairs the hyperboard for $75 quickly with very positive feedback.
I have the same problem and will probably send mine after the holidays.
Dec 03, 2008 | Toshiba 50H82 50" Rear Projection...
Mitsubishi WS model 55613
This is a picture of the DM Board in your TV. The wavy lines are tell tale signs of a failed capacitor. The capacitors are the cylindrical components on the board. One or more of them have failed. There is also a FMT Board with capacitors that could be causing this also so test them all. The DM board alone is 1000 bucks so it would be well worth it to invest in 50 bucks worth of capacitors and change them all out. Your boards would be fresh and good for another 4 years.
Your other option is to call a TV repair man and he would come pick up your boards and bring them back to his shop and test out the bad 3 dollar capacitor and swap it out and hand you a bill for 500 bucks.
Hope this helps you out.
Jul 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
PT47WX49E wavy lines
That unit has a history of bad caps throughout the convergence and other circuits. Personally I believe it was an error in the design.... Check and/or replace the following::: C2451, C3007, C7022, C4613, C2507, C7060 all 100uf/16v and C7127, C7128, C7103, C7154, C7136, C3010, C3008, C3002 all 47uf/16v... You can use a higher voltage rated caps such as 35v or 50v for greater reliability.
Nov 01, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Blue Flickering Screen - Which Repair Kit?
yes they provide a free service manual with their kits. the symptom of the blue screen could either be the signal or the FMT as they can both cause those symptoms, My professional guess would be the signal board as the FMT will cause distortion lines across the screen with no picture.
Sep 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wavy picture and turns itself off after an hour or two.
when the set shuts down if you try to press power again does the led blink? If so let me know how many blinks it blinks
May 12, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Wavy picture on a magnavox
sounds like syncronization is not occuring.your tuner may need replacing
Dec 31, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Pitcture is Wavy
Sounds like the tuner is going.
Dec 05, 2007 | Akai PT4799HD Rear Projection Television
My rca big screen tv
capacitor inside is going bad need to take in for service
Dec 04, 2007 | Philips 55PP9363 55" Rear Projection...
Wavy picture except when displaying a 1080p image
Elsewhere! Bad hyper board =bad caps on board need replacement = find a different tech who has heard of this repair or
have him research fixya / Toshiba/ 42H81 / hyper board ......T.
Oct 14, 2007 | Toshiba 42H81 42" Rear Projection...
Wavy picture on all video inputs except component video toshiba 57h82
make sure you replace all the 10uf caps and that the connections are good....
Sep 20, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H82 57" Rear Projection Television Logo
46 people viewed this question
Top Toshiba Projection Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Toshiba Projection Television Expert? Answer questions, earn points and help others
