Question about Alessi SG67 W Handheld Vacuum Cleaner
Alessi sg67 Battery
There is a red blinking light on my dyson when I first plug it in to be charged. Please advise
First, I'm not a Dyson Tech, but I have worked on battery operated recharge devices.
* Is this new or second hand? Most chargers for any device will blink red if the charge on battery is so low that the charger will not recognize the battery. If so (old battery) then got to get a replacement (New) battery.
Aloha, ukeboy57
FYI there is a slight possible fix for this old battery. But it's a long shot. Check on you tube on your specific battery "save ________ dead battery." (you force charge it to a reasonable level. But you didn't hear it from me ;-)
May 11, 2018 | Dyson Vacuums
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
When the battery need to be replaced in 4210 roomba
Change the Roomba battery when the battery does not seem to get charged well or drains off too quickly or if you feel the roomba is not cleaning well. Its then the time to change the irobot roomba battery.
Make sure you buy a good quality Roomba battery form Battery Manufacturers only. bbmbattery stocks all batteries and also manufacturers batteries upon requirements. If you donot find the battery you need ask them. They can get you any battery you need.
Thank you.
Jul 20, 2012 | iRobot Roomba 4210 Bagless Robotic Vacuum
Its showing full battery then after 5minutes showing low battery...
You have a nearly-failed battery.
You'll need to replace your battery as soon as possible, or (like everyone does) use your laptop
while plugged into the wall outlet, because modern battery technology is so substandard, and
after 6 months of use, everyone's laptop battery goes marginal - just as yours has.
Sep 19, 2011 | Vacuums
Seems to charge but then wont come on
Sounds like you bought a defective battery
You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new. If it still goes red get a refund and a new one.
Mar 07, 2010 | iRobot Roomba 4105 Bagless Robotic Vacuum
I think I need to replace the main battery in my small floor vac - the one that can be hand held like a dust buster or work like a small floor vac. I need to know how to remove the battery and replace it...
I see my sense of humor is not appreciated...it was only a joke. Anyway, here is what you do: First, slide the battery cover off the bottom of the hand held unit. Remove the battery from the motor housing by pressing the tab on connector “A”; this releases the battery from the motor housing. Plug the new battery (LC-R064R2P) into connector “A”. When installing the battery the wires have to go in first and they must be placed in front of the battery or you'll never get the battery cover back on.
Oct 16, 2009 | Vacuums
Model4210battry won't recharge, is it worth ordering a battery?
don't buy a new battery yet. you can reset the battery by charging for 16 hours, if this does not work, you need to take the battery out, push and hold the power button on your roomba for at least 15 seconds then reinstall the battery. plug in the charger directly to roomba not the docking station and charge until the battery light on the roomba is green. do not interrupt the battery charging cycle. after, leave the roomba charging for an additional 3 days or 72 hours. after, run roomba in max mode and run it till the battery is completely depleted. this will improve the battery overtime by charging again for 72 hours and depleting the battery. do this 3 or 4 times. and the battery should get better
Jun 28, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Alessi SG67 W Handheld Vacuum Cleaner Logo
133 people viewed this question
Top Alessi Vacuums Experts
Are you an Alessi Vacuum Expert? Answer questions, earn points and help others
