Question about Husqvarna Forest & Garden 125c 17" Curvgastrimmer
Trimmer head wont spin on Husqvarna 125c. It seems to be bound up.
  • jim_pears378 Jun 17, 2009
    I took the shaft off, removed the cable, and put it back together. The the head will still not spin freely. I cranked the engine and worked with it until I got it to spin again but it still doesn't spin freely. The tech at a local shop suggested that bearings at the head end of the shaft may have seized. I order a new shaft kit ($35). Thanks for the reply.
  • 1,041 Answers
The drive shaft is not seated into position properly or the shaft has broken. Have you had the shaft off recently? If so, take the shaft off again and try to seat the shaft as you gently pull on the rope. If you need further assistance, just let me know.
Jim
Posted on Jun 15, 2009
  • Jim Parker
    Jim Parker Jun 16, 2009
    Thanks for the rating. Good luck!!
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
Used 323l husqvarna weed eater. Head stopped spinning. How do I fix it?
you need to find what stopped the head. Did debris wrap around the head / shaft and stop it or did the clutch fail. Try to remove the trimmer head and determine if the drive shaft is spinning.
Jun 30, 2014 | Husqvarna 323L
Husqvarna trimmer starts but head doesn't spin, made a high squelling sound but continued to cut, the next time I went to start it the cord pulled quickly then caught started turned briefly then quit while...
Make sure there is not debris stopping the head. Try removing the trimmer head and make sure the shaft turns freely. If it does the problem could be either the engine or clutch.
Jun 25, 2014 | Husqvarna 28cc Gas Line Trimmer
Husqvarna 128ld trimmer head turns slowly,why
Make sure debris is not wrapped around the cutting head. Remove the cutting head and clear any debris. Then see if the drive shaft spins freely. The problem could be either where the drive shaft mates with the clutch on the powerhead or the clutch is worn.
Jun 08, 2014 | Husqvarna 128LD 17" Gas Trimmer
Trimmer head not functioning right
sounds like the inner drive cable has broke inside the shaft that drives the trimmer head.
Apr 30, 2010 | Husqvarna Forest & Garden 125c 17"...
Starter cord will not move, appears to be locked. is there a release somewhere?
no release gonna have to loosen pull cord mount to see if jammed or something broke inside,when you get it loose try turning flywheel by hand to see if free, could also be stuck trimmer head
Oct 05, 2009 | Husqvarna Forest & Garden 125c 17"...
Husqvarna string trimmers 125c
Check for a spark. If none, then the coil is bad. Replace it. That should solve your problem.
Sep 10, 2008 | Husqvarna Forest & Garden 125c 17"...
Husqvarna Forest & Garden 125c 17" Curvgastrimmer Logo
912 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
