Question about Casio Protrek Radio Controlled Solar PRW-5100-1ER PRW-5100-1 Mens Watch
Finding a black titanium Replacement watch for a Casio PRW 5100-1BJF
Is there a a black titanium watch band replacement for the resin band on a Casio PRW 5100-1 protrek
  • 1141 Answers
SOURCE: change casio g shock resin watch band
It can be done and not too difficult i think but look out that the leather band ain't too wide for the band orginal place,
make sure you keep all original parts in case of toruble
Post a photo if you can after the change will be nice to see the change
Tom
Posted on Nov 10, 2008
escapement
  • 2334 Answers
SOURCE: 3747 Replacement Watch Band
Use this link to get in touch with Casio:
http://www.casio.com/home/
Choose relevant application under the SUPPORT. Here you can find Technical Support, Casio Parts etc.
Choose your nearest region and ask to supply new watch band.
Do not forget to rate, please.
Posted on Jan 13, 2009
escapement
  • 2334 Answers
SOURCE: How do I get the pins out of the titanium band for Casio PAW1500T
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Jul 09, 2009
  • 2501 Answers
SOURCE: require a replacement band for casio triple sensor
Yes, go to "www.casiowatches.shriro.com.au/" where you should be able to find the information you need.
Click on "service agents" to find the address of your nearest agent.
Posted on Mar 02, 2010
SOURCE: casio pathfinder SPF 70-s titanium band adjustment
I purchased a Casio Pathfinder solar/atomic watch, with compass, altimeter, barometer, thermometer, model 1200T-7WC (titanium).
Has the titanium band - on this particular band each link is somewhat waveshaped {i.e., there are 2 "arms" from the link making contact with the middle part of the link above (above meaning towards the watch body), and 1 arm fitting between the 2 arms of the next link down). Unlike described in the first solution, the pin is not split, but solid (doesn't look like a slotted screw on 1 end, so the solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band is no help). Here's what to do if you have this band:
1. Note: before you start, be advised there is a tiny loose 1/8" part (sleeve) that will fall out as you pull the links apart, so work over an appropriate surface to "catch" it. Push pin (from the upper "arrow end) of one of the removeable links (those with the arrows on the backside) out of its hole with a fine poker (I used a 1/32" jeweler's screwdriver, an unbent paperclip would also work, just more likely to bend as you push pin out). This takes some force to do - in my case, after pushing, the pin projected out about 1/2 of it's length, I used needle-nosed pliers to gently pull it out the rest of the way). CAREFUL - once pin is removed and you pull the link away from the one above, a small (1/8") constriction sleeve should fall out of the center arm of the link above. SAVE THIS SLEEVE!
2. Using the same procedure, remove the pin from the bottom end of the link you're removing. again, SAVE THE SLEEVE.
3. to rejoin the band once the link is removed, look at the single/middle "arm" of the upper link, looking for the hole where the pin goes through. One side of the hole should be noticeably larger/wider than the other side - this is where you will place the SLEEVE - I used tweezers, or needle-nosed pliers will work - it will drop into hole. Keep this upright so that sleeve doesn't fall out, and slide the 2 arms of the lower link in place around the center arm.
4. Slide the pin you removed into one of the outer link arm holes - I found it easier if I started from below, pushing it into the center arm - it will stop when it reaches that 1/8" constriction sleeve. I set the extruded end on the pin on a magazine (i.e., slightly padded surface) and then pushed the top side of the band down, forcing the pin through the constriction sleeve and up into the upper arm hole, and Voila, your band is reconnected. The sleeve is important (without the sleeve in place, the pin will simply fall back out).
Posted on Mar 07, 2010
Where can I buy a replacement wristband for my casio twin resist TRT101H-1AV. Please i need someone to help me, i've searched everywhere for it, it was a present from'my mom,the band tore
Try support at the Casio website...eg for spares
http://www.casio.com/support/buyparts
(two outlets, one in CA one in NJ, emailis prob best depending on your location within US. If not in US you will need to try Ca eg sio website for that particular country.)
You could try downloading a manual to see what that says if you haven't already got one This webpage
Timepieces Watches Manuals CASIO
shows you how to do it (you need to get the 4 digit code from the back of your watch and type it into the box).
Some watches are made with the strap as an integral part of the watch and so in the proper sense cannot be replaced with a spare, the manual might tell you about this.
Failing all else you might try ebay or other such site where I have found casio watch straps for sale.eg (but not for your particular watch)
Genuine Factory Casio 25 16mm Black Twin Resin Replacement Watch Band...
18.April.2015
Apr 17, 2015 | Casio Mens Twin Resist watch TRT-100H-2AVH
Where can I get a replacement band?
Ebay is a great place for special watch bands. this one is $30:
http://www.ebay.com/itm/CASIO-SEA-PATHFINDER-WATCH-BAND-BLACK-SPF-40-/330812864375?pt=LH_DefaultDomain_0&hash=item4d05fbb777
You can also go to the source, Casio, and purchase a new band:
http://www.casio.com/support/buyparts/
Oct 18, 2012 | Casio Sea Pathfinder SPF70-2V Wrist Watch
Is it possible to convert the resin band strap of casio GS1001 to metal bracelet? If yes, where can I get the metal bracelet?
I have just found this site, it has all sorts of watch straps for all casio watches.
I am sure that you will find it useful
www.casiosalesandservice.com/starasp/a=3&dept=cwband&class=gshock.
Feb 20, 2012 | Casio GShock Giez watch #GS10011A Watch...
Where can i get a resin watch strap for a Casio Wv-200U-1AVEF
Most department and discount stores that sell Casio watches will carry a general assortment of replacement bands for those watches. However, your model takes a somewhat specialized band that may not be stocked by these stores. Instead, if you're looking for a local source for a replacement band, you might need to visit a "quick watch repair" kiosk or store in your local shopping mall or visit a jeweler who sells Casio watches. Often, both of these types of businesses keep a more comprehensive selection of authentic Casio bands in stock.
Replacement bands are also available online. For example, just because it was near the top of the Google search results I received, this web site has a wide variety of Casio bands, along with suggestions of the watch models to which they go. I have not ordered from this web site, and I have no affiliation with them (I actually think some of their prices are on the high side), but it's one of many online sources for the watch band you need:
http://www.casiosalesandservice.com/istar.asp?a=3&dept=cwband
Good luck finding the band you need at a decent price!
Jun 01, 2011 | Casio Watches
BG1301 Casio watch replacement band
Go to "casio.com" and click on "support".
Although they don't say so directly, their repair section imply that they can replace straps.
Jul 20, 2010 | Casio BG1301-4V Pink Baby-G Watch with...
I need to find replacement band for Freestyle Men's Rockaway watch
Google search your watch, choose from list of suppliers etc.
Nov 02, 2008 | Freestyle Watches
Casio Protrek Radio Controlled Solar PRW-5100-1ER PRW-5100-1 Mens Watch Logo
16 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
