Question about Speed Queen AWS75NW Top Load Washer
AWS75NW leaking leaking washer
Clicking sound when washing
Remove the back (or the whole ) panel to check what is the problem
Mar 26, 2013 | Speed Queen AWS75NW Top Load Washer
Water leaking from washer model CT599AWN
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Check for tips on the link below to identify parts and removal:
Sep 04, 2012 | Speed Queen AWS75NW Top Load Washer
First I noticed that the clothes after washing them were still a little too wet---then a month later, a loud noise ensued. no leaking no smoke and still wet clothes, also no shaking.
Sounds as if the belt may have a flat spot in it. They run about 24 dollars online. Take
a look at it by unplugging it and having someone hold the machine back at an angle.
There should be an obvious area of excessive wear somewhere on the belt.
Also check the idler pulley (wheel) for excessive play or binding. Hope this helps.
Mar 10, 2011 | Speed Queen AWS75NW Top Load Washer
Oil/grease leaking into tub. Speed Queen AWM492W top load washer. How to fix?? Thank you.
Check to see if the oil is coming from under the agitator. If it is replace the transmission. If it is not check to see if there is a grease spot inside the was tub.
Dec 29, 2010 | Speed Queen AWS75NW Top Load Washer
Motor rund but drum dont spinon speed queen heavy duty washer
Fluid Drive clutch greasy or worn,
Pump blocked or drive belt too loose
Feb 23, 2010 | Speed Queen AWS75NW Top Load Washer
Replace Water Pump on Speed Queen Washer
did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
Dec 21, 2008 | Speed Queen AWS75NW Top Load Washer
Selector switch
it could be a timer fault,or a motor fault but i would go for a timer.unless you have any buttons pressed in you shouldnt.hope this helps.
Mar 06, 2008 | Speed Queen AWS75NW Top Load Washer
Speed Queen AWS75NW Top Load Washer Logo
15 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
