No power going to the fuel pump
Vehicles have a safty device that kills the fuel pump in case of a roll-over accident so the fuel will not be poured on to the car and ignite. also, this fuel pump kill switch is used when you are going to remove the fuel pump to de-pressurize the fuel line by cranking the engine while the fuel pump safety switch is off. you can restore the power back to the fuel pump by resetting the fuel pump safety (kill) switch. some are located in the trunk, by the fender well, behind the carpet. some are located inside the kick panel where the front passenger sits. check your motor manuel for that vehicle or ask a parts person at the dealership for the location of the safety switch for the fuel pump.
SOURCE: Severe voltage drop to orange wire on fuel pump
replace the ignition switch (shorting out so to speak) this is the electic part down on the steering colum
SOURCE: no power going to the fuel pump?
you may have fuse blow out or check harness connector if there is power cut off check for continuity power maybe wirer broke under seat
