Wireless connection not workingn
Wireless connection not working but i get a connection when i use the cables that came with the talk talk pack
  • zackmanbaile May 11, 2010
    Did you configure the wireless router? What kind of router do you have?
  • Carl Navarro
    Carl Navarro May 11, 2010
    I can see 3 problems1. You posted this in the wrong area2. Do you have and did you turn on the wireless card?3. How are you trying to access the wireless?
    Scholar:
  • 62 Answers
You need make sure that the wireless settings on your router is exactly the same as the wireless computer. Check the following:
1. Wireless Name/SSID
2. Wireless Security (if enabled, copy the settings and enter in on your wireless computer)
3. Wireless Filtering (if enabled, add the IP address or MAC address of your wireless computers)
4. Check if your getting a valid IP address
Posted on Jul 02, 2009
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
Skype calls break after every 2 mins when talking on tablet
it could be a connection in between wireless router and your tablet.
if your tablet having ethernet port connection pls try with this port and make sure the fault in wireless connectivity. if yes pls try with change wireless sequrity and test again
Apr 08, 2013 | Computers & Internet
Ho w to fix x box from controller to x box is really slow how to make it normal
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Feb 08, 2013 | Microsoft Xbox 360 Controller
Wrt400n connects via ethernet cable, but won't talk wireless
you said every thing that connects with the ethernet is working. that means the wired part of the router is working. check the wireless settings of the router. Open the set up page of the router on the main computer. connect the main computer to the router with the ethernet cable.
change the wireless settings of the router.
WRT400N is a dual band router ( 2.4 GHZ and 5 GHZ)
You can create 2 different wireless networks. Make sure that the names (SSID) will be different for both the networks. For 2.4 GHZ change the standard channel to 6 and save the settings.
Go to wireless security and set the security mode to WPA Personal. set up password for the wireless network. You can use the same password for both the networks. Make sure that the Wireless MAC address is disabled.
Now try to connect to the new wireless network. and see what happens.
Click here for more information about routers
Mar 12, 2010 | Linksys WRT400N Router
Unable to access the Internet and the Internet Provider Talk Talk expressed the view that the wireless on the Laptop is faulty. What do I need to do?
try to connect your laptop in your router via lan cable..use your lancard..use a utp cable.. if it does not work it mean you have a problem in your internet connection not on your laptop..but if it connects it means you have a problem in your wi-fi connection...
i hope it solves your problem....rate this if this solved it,..
Feb 06, 2010 | Fujitsu Siemens CONNECT2AIR AP-500RP...
Surfboard Cablemodem not communicating with Belkin Wireless Routr
If the modem is actually passing out DHCP, then you have to connect the modem to the router 4 port lan side and not the wan port. Give the router a static ip like 192.168.1.2 and you can talk to it and configure the wireless features.
Feb 17, 2009 | Arris SURFboard SBG900 Wireless Router...
D link dsl 2640r cant find my wireless setting on my laptop
do you have the drivers, or a wireless nic in your laptop?
Feb 12, 2009 | Sony Computers & Internet
DLink DIR 625 Wireless Router
It is the wireless computer setup with the same network name?
Feb 08, 2008 | D-Link DIR-625 (790069292637) Wireless...
Hooking linksys to gigafast
There are some question's that should probably be asked before we begin. Generally a wireless adapter or network card is present in a computer to allow it to access a wireless router which is connected to an internet service provider (generally a dsl connection through a phone line or a cable modem from your cable provider. Your request seems to be to get a computer to talk to a wireless router to talk to a wireless router to talk to your internet service provider (dsl or cable). I will assume after reading this that you probably have or will get a wireless adapter for the computer to talk to one or both of the wireless routers you appear to have. Wiring two wireless routers in the same house may be useful if the home is large or the wireless routers operate on different bands (a, b, g or frequencies) and you have different computers that require the different bands. however both wireless routers are in my experience connected to each other using a wire. Once we clarify the above we can probably address the connectivity issues for the devices you require.
Dec 02, 2007 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
408 people viewed this question
Alun Cox
David Payne
David Payne
