Question about Pride Celebrity X 4-Wheel Electric Scooter
Ignition not working
Fuuly charged but when turning the key the needle stays put
How do i make it turn on its just a black screen it shows it is fuuly charged on itunes
Perhaps your LCD Screen has malfunctioned.
1> Make sure hold switch is not activated.
2> press any button to turn on the device
3> put your ear up to the back of it. if you can hear the little hard drive spinning (very faint on smaller iPods, listen carefully.). if you hear it the device is on and working, and your LCD is not working. you will need to take it to Apple to have it repaired.
Dec 06, 2014 | Apple iPod nano 3rd Generation
Why does the rpm & speedometer needle bounce as soon you put in the key & haven't even turned the key
The electrical portion of the switch/tumbler portion of this system most likely has a short...
Aug 07, 2014 | 2000 Cadillac Catera
My envoy wont start turn key and everything works but wont start
What ????? i try to sterted manuely and it start but turn off the light stays on with the ignition. What light stays on ????
i try to sterted manuely ???? I try to start it manually !!!!!!! You need to take your vehicle to a qualified professional technicia .
Jan 23, 2018 | 2005 GMC Envoy
When the walkie on full charge the charge light is not going to off ?
If your battery is flat or close to, then a complete charge is ussually 23 hours. or thereabout, so this is why the light on your charger is still on. The light for a flat battery is red and when the battery is fuuly charges light is green.
8 hours of charging a flat battery, isn't enough, hence the light staying on RED, if I'm not wrong and I doubt that I am.
I hope this has answered your query.
Best regards,
Peter
Oct 09, 2012 | Kenwood KSC-15 - 8 Hour Charger
Loose electrial power when ignition is turned on
check battery cables make sure they are clean no corrosion and tight also make sure they are fuuly charged if the caps on top are removeable check water level if low refill with bottled or distilled water if any of the holes smell like rotten eggs your battery may be bad most likely dead battery or bad connection somewhere
Mar 25, 2012 | 2002 Ford F250 Super Duty SuperCab
My Komota wont stay hold charge if the key stays
Check for a intermittent short in the ignition
Oct 10, 2009 | 2008 Suzuki GSX-R 600
My 1996 Pontiac Sunfire wont crank...
tryy replacing the fule injectors and the fuel pump could possibly be shot as well. you have a fuel problem.
May 07, 2009 | 1996 Pontiac Sunfire
Headlights stay on when car is shut off & keys out of ignition
Replace the ignition switch - not working properly.
Aug 23, 2017 | 1998 Chevrolet Malibu
Pride Celebrity X 4-Wheel Electric Scooter  Logo
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
