Question about Whirlpool ACP102PS Portable Air Conditioner
Dishwasher stopped after wash cycle restarted and it did same thing
Portable Air Conditioners do not wash dishes.
Posted on Sep 01, 2014
Dishwasher starts in any type of cycle, runs for a minute, then shuts off as the lights blink out.
in general your wash motor can cause that. It gets old and you can hear the wash motor making a rumbling noise when it turns on. The increased load with cause a thermal coupler to turn the unit off.
Jun 23, 2014 | GE Dishwashers
LG dishwasher error code after 2 minutes
fault with the programe as it has stoped in mid cycle
Aug 01, 2012 | Whirlpool Dishwashers
Our Haier HDC1804TW counter-top dishwasher does not complete the washing cycle. It stops after 90 minutes which should be 115 minutes for heavy washing according to the manual. The washing light is...
Since mine does the very same thing, it's my guess that is the sterilising cycle as by this point it has already washed, done a short fill to remove any remaining detergent, and two rinses. I'm also assuming the second short fill is just to cover the heating element and/or to to generate an amount of steam having being heated by the element (I'm basing that assumption on the heat of the dishes at the end of end of the cycle and the heat of the water when it drains)
Mar 05, 2011 | Haier HDC1804TW Dishwasher
Opened lid during wash cycle. Machine stopped but later restarted. The same thing happened two weeks later, but the touchpad has no function. It is getting electrical power to the dishwasher. Thoughts?
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
May 06, 2010 | Dishwashers
I put liquid dishwashing soap IN THE RINSE AGENT DISPENSER. What can I do?
I suggest purchasing a pipette (long thin flexible plastic eyedropper thing) from hobby lobby, Frye's, or from a scientific lab supply.
Draw up as much a you can from inside. Apart from that unless you remove the panels from the door to access the reservoir, then it may take several more washes to remove the soap from the the rinse additive dispenser. One more thing, you could start the machine in the rinse mode to wash the dishes and stop it when done and restart in the wash mode to rinse. When that is finished, stop and restart in the drying cycle. Good Luck!
Jul 03, 2009 | Dishwashers
Dishwasher not completing the programed wash, Now won't restart.
There is not a reset button, but you can try by holding both drain and one of the wash cycle.. hold it for a few seconds.. keeping trying drain and another, and another.... you will hear drain motor draining water out... if there is standing water at the bottom... if the cycle stopped after wash cycle, its usually your control... hope this help...
Jan 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My westinghouse 905 dishwasher starts ok but stops somewhere in the cycle, not having washed the dishes properly.
Hi. I have a Westinghouse 905. At first all ok then we found that it cuts out and short cicuits the whole house. Trips the electricity switch. Restart gets to about half way through then same thing happens. Any help please?
Tks
Apr 22, 2008 | Dishwashers
Whirlpool Dishwasher Fills and then Stops
  Check your connection where you connected dishwasher to power cord.
Oct 25, 2007 | Whirlpool 24 in. GU2500 XTP Built-in...
Whirlpool ACP102PS Portable Air Conditioner Logo
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
