Question about Brother MFC 8440 All-In-One Laser Printer
Machine error 72
Error message
Unable print copy 71
Sir/Madam
The machine has a mechanical problem.
Turn the power switch off, wait a few minutes, and then turn it on again. If the problem continues, please call your dealer or
Or Follow Us For Online Brother Printer Support
Jan 08, 2014 | Brother All-In-One Laser Printer DCP7065DN
Error 72
The error message "engine firmware" code 72 is showing up on the display. I've turned the printer off/on and error message still appears.
Jun 17, 2013 | Xerox Phaser 6200N Laser Printer
When tally erp open one error message occured that is unable to read message 1 for update error code : 2147483651
when i tray to copy after some times display will show print unable with error code 72
May 02, 2013 | Computers & Internet
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Apr 07, 2013 | Brother Multi-Function Center MFC-665CW...
I have brother DCP 7055 it shows print unable 71 error pls suggest
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
Dec 18, 2012 | Brother Dcp-7055 Laser Print Copy Scan...
Xerox phaser 6200 error message, firmware failure error 72?
if you turn the machine off and turn it back on:
A} error code is gone, problem solved, system just needed to refresh
B} error code returns, pot luck, the engine control board inside of the printer needs to be replaced and coming from me who is a professional and has had to do it twice, please don't call me to do it, it's a pain in the tookus.
Nov 07, 2008 | Xerox Office Equipment & Supplies
Error 77 is apprearing
Unplug the unit.
Hold down the menu key while plugging back in / powering up.
When finished initializing, hit 99.
Wait to status comes back and hit 91.
This supposedly happens due to a power surge or outage.
If this doesn't work for you try reversing the numbers above.
I have a bad memory, it might be 91 first then 99 but, you definately have to hold down the menu key.
Sep 11, 2008 | Brother IntelliFAX 4100 Laser Fax
Error message "engine firmware" code 72
Most likley the problem is a faulty Imaging unit. The chip on the unit has failed. You can try reseating the Imaging Unit and if that doesn't work replace it.
Here are the other listed causes.
Cause:
Corrupted NVRAM Possible Causes are Imaging Unit, Fuser, EEprom Board or PE/MCU Board
Feb 12, 2008 | Xerox Phaser 6200N Laser Printer
Brother MFC 8440 All-In-One Laser Printer Logo
16 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
