Question about Innergie PocketCellTM Portable Rechareable Battery Bank
PocketCell charging i am using pocket cell first time and trying to check the chrging status by pressing power indecator E also want ot charge but i havent any adopter so guide me what to do
Gateway NV5378u lap top, brand new battery installed and status says 100% charged. When I unplug the computer it shuts off as if there is no battery. Could the new battery be defective?
There are a few things to check. The LED lights can tell you a lot. This will tell you more about the battery:
  1. On the taskbar, double-click the power cord icon or battery icon to open the Power Meter dialog box. Note: If the power cord icon or battery icon does not appear on the taskbar, click the show hidden icons button.
  2. Press Fn+STATUS to view the power status box, which opens in the upper-left corner of the screen. The power status box shows the current power source, the battery charge level, and the power management mode.
  3. Look at the battery charge indicator (if applicable).
    • LED green - Battery is fully charged.
    • LED orange - Battery is charging.
    • LED blinking red - Battery charge is very low.
    • LED solid red - Battery is malfunctioning. Note: This LED only lights up when the notebook is connected to AC power.
  4. Press the battery meter button on the battery. The battery meter lights indicate the percentage of battery charge remaining.
  5. Wait for a Low Battery warning message to appear.
If your battery charge indicator displays what looks like an inaccurate charge, you may need to recalibrate the battery.
To recalibrate the battery as mentioned, try this:
  1. Connect the AC adapter and then turn on the notebook.
  2. As soon as it starts and you see a startup screen, press the F2 key.
  3. In the BIOS Setup utility, use the TAB key to select the Advanced menu.
  4. On the Advanced menu, select Battery Auto Learning, and then press the SPACEBAR to select Enabled.
  5. Use the RIGHT ARROW key to select the Exit menu. On the Exit menu select Exit Saving Changes, and then press ENTER.
  6. At the Setup Confirmation prompt, select Yes, and then press ENTER.
  7. The battery recalibration process begins and a screen opens showing you the progress.
  8. When the recalibration has finished, and the message "Press [Esc] key to exit" appears, press Esc. The battery charge indicator now displays an accurate battery charge.
Hope this helps!!
Oct 20, 2013 | Computers & Internet
V 630i chrging solution
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 19, 2010 | Sony Ericsson V630i Cellular Phone
Battery not charging. Blue light for electric
1. switch out the battery for new!
a: if its new then you going to have to go deeper into your pockets you going ot need to have the motherboard repaired or replaced as the connectoer is on the mainboard.
So its ether or my friend hate to bring the back tech news but it is what it is, let hope its under warranty.
Thanks and please do leave acceptable ratings for a free solution that was written out for you.
Jul 02, 2010 | Toshiba Satellite A135-S2356 Notebook
Not chrging problem
If your phone is not charging and you have use different charger to charge the phone and yet not still charging, then, it means the charging port of your phone is bad and will need to be replace, replace the charging port on your phone and you will see that the phone will start charging.
Take care.
Jul 01, 2010 | Nokia 3120 Cellular Phone
Rapid flashing battery light and battery apparently not charging- is battery dead or is charging circuit u/s?
Hello!
Tricky issue, try removing the batt, power it up using ac power, when booting try going to the BIOS page, try looking for the A/C adapter type. if ot shows there, then your good with your ac adapter, now try hooking the battery then check again in BIOS your battery status, is if its saying other than charging, then possibly its a battery issue, most batteries are good for 1-2 yrs, more than that batt hold will degrade. time to replace your battery...
Hope it help!
Apr 20, 2010 | Dell Inspiron 2200 Notebook
My nokia 3110c chrging show but not charg battery
the battery of your phone is bad, and that's why it cannot with hold power. It might indicate that its charging but won't charge.
You need to replace the battery and the problem would be resolved.
Battery replacement is what will solve this problem.
I wish you all the best.
Jan 11, 2010 | Nokia 3110 Cellular Phone
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Lg cookie fault
please remove battry 10mins over reset chrging
Jul 06, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Phone wont turn on
first thing connect your phone to AC power (electricity) then see if the charging indecator is red or orange or green ,
then try to start your device if it's not working the problem is hardware and go to a pepairmant workshop ,
if the indecator doesn't work and there is no light try to change the battery with a new one and then do the stpes agian
Nov 05, 2007 | i-mate JAM Pocket PC
Innergie PocketCellTM Portable Rechareable Battery Bank Logo
79 people viewed this question
Top Innergie Electronics - Others Experts
Are you an Innergie Electronics - Other Expert? Answer questions, earn points and help others
