Question about Laser Tek Services 1 Ml-d3470b Samsung Ml-3470 High Yield Black Toner Refill Kit Also For Samsung 3471 3470a 3471nd Ml-d3470a Printers And Cartridges
Ml-3470 high temperature
Errore high temperature
Resetter of samsung Ml3470 laser printer resetter
Try this...
1 Press Menu until System Setup appears on the bottom line of the
display and press OK.
2 Press the scroll buttons until Maintenance appears and press OK.
3 Press the scroll buttons until CLR Empty MSG. appears and press
OK.
4 Select On and press OK.
5 Now the Toner Low Replace Toner message does not appear but
the Replace Toner message will remain for reminding you that the
new cartridge needs to be installed for quality.
The User Manual (ver. 6.00) is available at...http://www.samsung.com/us/support/owners/product/ML-3471ND/XAA
Jun 08, 2014 | Samsung ML-3470 Series
Samsung ml-3560 will not initialize
hi,please cheque printer papper jam & please take the jamed papper after printer is turn on to contiue see the error please replace the high voltage power supply
Mar 29, 2014 | Samsung ML-3560 Laser Printer
Safeboot hard disk error (80H)
You need format your hard disk... sorry but if your problem continues... is logical error or hardware error.
Jan 21, 2014 | Dell OptiPlex 7010 MT Desktop Computer-...
Ml 3470 toner empty
Sir/Madam,
You have to purchase a new toner from any computer shop. Your printer toner can make approximate 1500 prints in standard condition.
Jan 05, 2010 | Samsung ML-1640 Monochrome Laser Printer
ENGINE FUSER, LOW HEAT ERROR
Replace the fuser, it's not reaching operating temperature within a set time (normally a thermister or the lamp is shot)
May 21, 2008 | Samsung ML-3561ND Laser Printer
Laser Tek Services 1 Ml-d3470b Samsung Ml-3470 High Yield Black Toner Refill Kit Also For Samsung 3471 3470a 3471nd Ml-d3470a Printers And Cartridges Logo
43 people viewed this question
Top Laser Tek Services Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Laser Tek Services Office Equipment and Supply Expert? Answer questions, earn points and help others
