Question about IGG GodsWar Online
Godswar online no valid 32 bit application
Dsadsadsa
Can't detect XP discs in win 64 bit
Hello Joe, 64-bit processing is faster than 32-bit processing because the CPU is handling more bits at once, However, a 64-bit OS requires more resource than a 32-bit OS, A 64-bit OS requires that device drivers operating in kernel mode be a 64-bit drivers, These drivers must be available from the device manufacturer. An application is compiled to process 64-bit or 32-bits. A 64-bit OS can run either 64-bit applications or 32-bit applications, but 64-bit applications are faster also 64-bit applications cannot run on a 32-bit OS.
A 32-bit OS can only address up to 4 GB of memory, More than that might be on the motherboard, but the OS cannot use it, because it does not have enough memory addresses to assign to the physical memory. A 64-bit OS theoretically can address up to 1 terabyte of memory although in practice, most motherboards can only hold from 12 to 16 GB of memory.( A terabyte is roughly 1000 GB or 1 trillion bytes). If you open many applications at the same time and have high computing needs and enough hard drive space and memory, you can benefit from 64-bit computing. To get most out of it, the processor, motherboard, operating system, drivers and applications must all be 64-bit, and you should have installed the maximum amount of memory the motherboard supports.
Mar 16, 2013 | ASUS G74s Cd-rw Dvdrw Super Multi Drive...
I cant log in my acoount on godswar online , yet its not maintenance .
Try resetting your password or contact there support staff. and check if there servers is online.
Jun 05, 2011 | IGG GodsWar Online
My kalydo loader is corrupted, what is the best solution?
My kalydo loader is corrupted, Problem with the IGG GodsWar Online
Apr 10, 2011 | IGG GodsWar Online
I cant acess godswar in facebook it is said that ERROR REPORT...my classmate told me that it is block from the wireless..HELP
i cant acess godswar in facebook it is said that ERROR REPORT...my classmate told me that it is block from the wireless..HELP
Mar 06, 2011 | IGG GodsWar Online
Hi I am Farah, and as I wanted to download java , it came thet" " is not valid win 32 application'. What shoudl I do? Thx
It is possible that you are attempting to install a 64-bit version of Java when you have a 32-bit operating system. Check your operating and confirm this. In Vista you can find this using Start > Control Panel > System. This is similar if you have Windows 7. Here is what it looks like:
If after that you, you follow these instructions from Sun (Java) to locate and install the 32-bit version.
Error: x64.exe not a valid Win32 application This article applies to:
  • Platform(s): Windows 7, Vista, Windows XP, Windows 2000, Windows 2003
  • Browser(s): Internet Explorer, Firefox, Mozilla 1.4+
  • Java version(s): 6.0
SYMPTOMS
While trying to install Java a user gets an error message similar to:
' ... x64.exe not a valid Win32 application'
CAUSE
The error message is a result of trying to install a 64-bit version of Java on a 32-bit operating system.
SOLUTION
User needs to install a 32-bit version of Java software, since a 64-bit version is not compatible with their 32-bit operating system.
Follow these steps to download 32-bit Java
  1. Go to Manual download
  2. Click Windows XP/Vista/2000/2003/2008 Online.
  3. The File Download dialog box appears.
  4. Choose the folder location.
  5. (Save the file to a known location on your computer, for example, to your desktop).
  6. Click Save.
  7. Close all applications including the browser.
  8. Double-click on the saved file icon to start the installation process.
Nov 07, 2010 | Computers & Internet
I downloaded a software package to my windows XP desktop but, when I try to install I get a pop up stating location Doc. and settings not valid in win32 application. Please advise.
Sounds like the download got corrupted. Try Deleting the current copy and re-downloading. If it still does not work, verify that you have downloaded the 32 bit version of the software if there is a 32 and 64 bit versions available.
Sep 25, 2009 | Microsoft Windows XP Home Edition
Problem to set up java with windows vista
there is a possibility that the file was not downloaded properly, so try downloading it again fully and retry installing.
Make sure that you have the matching bit version. If your windows is a 32 bit version one,, make sure you din download the windows x64 package of java ..
Apr 12, 2008 | Computers & Internet
StyleXPUpdateAmd64
You downloaded the wrong version. You have 32 bit windows (note the "valid win32 application" part?). You need to download the regular 32 bit version, not the 64bit version. The update file for 32bit windows is file that is 4.9MB in size listed on that web site. Please don't forget to rank my answer, thanks :) Peter
Aug 25, 2007 | Microsoft Windows XP Professional With...
Video Game Consoles & Games Logo
18 people viewed this question
Top IGG Video Game Consoles & Games Experts
James Wishart
Are you an IGG Video Game Console and Game Expert? Answer questions, earn points and help others
