Question about Softheat Heating Pad
My theratherm heating pad shows malfunction on the screen
The product does not heat up and a continuous beep is heard.
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
DJO Global
Joy, Re POST , make, model #, and complete question so we can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 07, 2016 | Theratherm Digital Moist Heating Pad,...
Where can i get a website to download a free video card for my PCG-6H4L
You can't - a video card is >hardware< - a physical device. Do you mean where can I download >drivers< for my PCG-6H4L? A Google shows that to be a Sony notebook, so Sony websites would be a good starting point.
FWIW, it's very poor form to not give the manufacturer for a device you want help with. I should >not< have to Google to find out the maker of your gizmo. That's rude on your part...
Feb 27, 2015 | Computers & Internet
I have a Kenmore Wall electric oven unit that the heat element at the top is working only and F2 is what comes up and continues to beep. The heat is extreme. WE are wondering if we should just get a new...
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 19, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Heard pop while baking - control screen quit F1 error message
You will have to replace the control board. you can purchase one online from one of the follow websites. You will need your model number
http://www.searspartsdirect.com/partsdirect/index.action
http://www.apwagner.com/
Nov 16, 2009 | Office Equipment & Supplies
Display shows 6's across screen & beeps
HI. the touch pad board is malfunctioning at this time. you will need to replace this damaged touch pad device asap. this will fix your issue.
Sep 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore Oven going crazy
The bang may have been an element arcing over.  Turn off the power and remove the element.  If it shows any form of damage, replace it.  If you're not sure, use a continuity checker to check it.  If you have two elements...do this for both.  You will likely find the problem.
Nov 13, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
New heating pad not working
have same problem with heating pad . reset control by unplugging unit for 1 minute , while holding down power button plugged unit back in . sometimes this takes 3 or 4 tries.
Apr 26, 2008 | Sunbeam 805810 HeatSense Heating Pad...
Softheat Heating Pad Logo
Top Softheat Health & Beauty Experts
Tom Chichester
Are you a Softheat Health and Beauty Expert? Answer questions, earn points and help others
