Question about Sylvania Lc200sl8 20-inch Lcd Edtv With Built In Tuner
Sync to my phone devices to screen
Mirror
How do I connect to Ford Sync?
To use any of the phone features for SYNC such as making a call, receiving a text message, or using SYNC Services, you must first connect, or "pair" your Bluetooth-enabled phone. Pairing is what allows Bluetooth devices to communicate securely with each other.
Please note that SYNC can make and receive calls using only one paired phone at a time.
Before you start
There are a few things you should do before starting step 1:
blobserver?blobkey=id&blobwhere=1309207543643&blobcol=urldata&blobtable=mungoblobs&b=91
Turn on your
  • Mobile phone
  • Vehicle
  • Radio/SYNC
blobserver?blobkey=id&blobwhere=1309207543650&blobcol=urldata&blobtable=mungoblobs&b=91
Enable your phone's Bluetooth feature and make your phone discoverable.
Press the Phone button to access the Phone Menu. Press OK. Add a Device displays. Press OK.
SYNC prompts, "Press OK to begin pairing device." Press OK.
SYNC prompts, "Search for SYNC on your device and enter the PIN provided by SYNC." Press OK.
A six-digit number displays on the screen for three minutes, during which time SYNC actively seeks for the same number from your phone.
Type the number displayed by SYNC on your phone key pad.
Upon successful pairing, a message displays confirming the phone is connected.
Exit the phone pairing process by pressing the Arrows to select the Exit message and press OK to leave the Phone menu.
Aug 25, 2014 | Cell Phones
Tip
How to sync Gmail contacts with your mobile phone
<p>Google Sync is needed to make your calendar and synchronize Gmail contacts with the device. However, Google Sync is not compatible with all devices. Google Sync for iPhone, Blackberry, Windows Mobile and Nokia E series and N series devices. You must have iPhone OS 3.0 or newer version of Google Sync. By configuring this feature, Google Sync will update the phonebook contacts from the device to your Gmail contacts. Because Google Sync is a two-way service, you can save time by adjusting a single platform, such as telephone or Gmail account. <br /> <p><br /> <p>Windows Mobile <br /> <p>1. Choose the Active Sync on the Home screen and select "Set up your device." <br /> <p><br /> <p>2. "m.google.com" type under the "Server Address" field and then check the option "This server requires an encrypted connection" box. <br /> <p><br /> <p>3. Log into your Gmail account by entering your data. <br /> <p><br /> <p>4. Select "Next", enter your full address and password in the "User Name" and "Password" and select "Next." <br /> <p><br /> <p>5. Check "Contacts", "Calendar" or "Email" check box, depending on the features you want to sync with your device, then select "Finish". <br /> <p><br /> <p>Blackberry <br /> <p>1. Visit the following page using your Blackberry browser: http://m.google.com/sync <br /> <p><br /> <p>2. Select "Download Google Sync" link by selecting the BlackBerry menu button, then select "Get Link". <br /> <p><br /> <p>3. Select "Download" is directed to a download page. Google Sync icon appears on your home screen. <br /> <p><br /> <p>4. Select the icon, move the cursor to the login section, enter your full Gmail address and password fields and click "Login". You are redirected to a welcome screen. <br /> <p><br /> <p>5. Read the summary information on the welcome screen and choose "Sync Now" button at the bottom of the Welcome screen. Standard Google Calendar and Contacts sync synchronizes automatically. <br /> <p><br /> <p>Apple Devices <br /> <p>1. Go to the homepage of the phone screen and then open the Settings application. <br /> <p><br /> <p>2. Select "Mail, Contacts, and Calendars" and select "Add Account". <br /> <p><br /> <p>3. Choose "Microsoft Exchange", and then all your e-mail account on Google's "Mail" field. Do not enter information into the "Domain" field. <br /> <p><br /> <p>4. Enter the email address from Google / Gmail account and password into the "User Name" and "Password" and select "Next." <br /> <p><br /> <p>5. Select "Cancel" when prompted by the message dialog "Unable to Verify Certificate". <br /> <p>6. Type "m.google.com" in the "Server" and select "Next." <br /> <p><br /> <p>7. Enable synchronization of Google services such as "On" next to "mail", "Calendar" or "Contacts." <br /> <p><br /> <p>8. Select "Delete existing contacts" if you just want to synchronize my contact group. " <br />
on Aug 18, 2011 | Google Gmail
Where is sync?
Pairing a Nokia Lumia 520 to a 2013 Ford Escape
1. To Find "Bluetooth" on the Nokia Lumia 520
  • Slide your finger left on the display.
  • Press Settings.
  • Press Bluetooth.
2. Turn on Bluetooth
  • Press the indicator next to "Status" to turn on Bluetooth.
3. Pair a Bluetooth device with your phone
  • Make sure the vehicle (parked in a driveway) is turned on and engine running. Go tot he Phone Menu, System Settings, Add Bluetooth Device, Push OK, The Sync System will display a 6-digit PIN number. Use the Seek Arrows to change to Special PIN (the system will display 0000), Push OK.
  • Your phone now searches for devices and after a moment, a list of Bluetooth devices within range is displayed.
  • Press the required Bluetooth device (the tab should say Sync).
  • Follow the instructions on the display to pair the Bluetooth device with your phone. Enter the 4-digit PIN
  • The new device is displayed on the list of paired devices.
  • Press OK on the console screen to set as Primary Phone, set 911 Assist and Download Phonebook. Be sure to check your phone screen and check "Always Connect" and Yes to approve the phonebook download. Be sure to check to see is there is also a request to Always Connect for SMS (texting) alerts.
4. Return to the home screen
  • Press the Home key to return to the home screen.
Your phone should now be paired the Sync system. Use the Voice button on the steering wheel to start the process (say "Phone"). Use the Phone icon to answer (a quick push) or hang up (push and hold down for about five seconds).
For more info www.fordtechlane.com Ford Tech Lane Driving you on the fastlane of vehicle technology
Mar 05, 2014 | Nokia Lumia 520 Smartphone - Wireless LAN...
Iphone screen pass code is locked how do I reset it?
  1. Connect the device to the computer with which you normally sync and open iTunes.
    Note: If iTunes asks you to enter the passcode, try another computer that you have synced with. Otherwise, go to "If you have never synced your device with iTunes, or you do not have access to a computer" section below.
  2. If the device is still disabled, or if iTunes does not automatically sync your device, sync the device with iTunes.
  3. When the backup and sync is complete, restore your device.
  4. When iOS Setup Assistant asks to set up your device, choose "Restore from iTunes backup".
  5. Select your device in iTunes and choose the most recent backup of your device.
Mar 04, 2014 | bessac.ca X9900 2.4-inch Touch Screen Four...
In my phone i am using the screen lock with numbers passwords but now the password is not working how can i get back the password
If you have previously synced your device with iTunes, you may be able to reset the passcode by restoring the device: Connect the device to the computer with which you normally sync and open iTunes. If iTunes asks you to enter the passcode, try another computer that you have synced with. Otherwise, go to "If you have never synced your device with iTunes, or you do not have access to a computer" section below. If the device is still disabled, or if iTunes does not automatically sync your device, sync the device with iTunes. If you have chosen to encrypt your backup, it will contain the passcode. Disable backup encryption before restoring from backup. Learn more about iOS backups in iTunes. When the backup and sync is complete, select Restore from Backup and choose the most recent backup of your device.
Nov 22, 2013 | Sony Mobile Phone XPERIA Sola MT27i White
How i conect my phone with computer
  1. Download and install the latest on your computer.
  2. Open iTunes.
  3. Connect the iOS device to your computer using the included USB cable and select it in iTunes under Devices on the left-hand side.
  4. Set up which items are to be synced: Click the corresponding tabs in iTunes to specify which information you want synced between the iOS device and your computer.
  5. Click Apply, in the lower-right corner of the screen, to sync.
Aug 15, 2011 | Apple iPhone 3G
U430 will not work with ford sync
I have the same problem. Trouble pairing but finally I got the SYNC to find my U430 and paired but the SYNC never connects with the phone.
Sep 17, 2010 | Samsung Cell Phones
How do I bluetooth pair my i9 phone with my Ford SYNC
On your Ford Sync board, press the phone button. It will start to search for already paired devices. If none is found, press the arrow buttons until you find 'Add Bluetooth Device'. Then, press OK. You'll see it will generante a PIN. Now, make your phone's bluetooth application look for new devices. After a while, the Ford Sync device will appear on the phone screen. Select it, and make the the bluetooth application proceed. When a PIN (or pairing code, or passkey) is requested, enter the PIN generated by the Ford Sync device.
Hope it works for you.
Regards, Carlos
May 20, 2010 | Cell Phones
I have a Ipaq 2200 version 4.2 2003 will it active sync with windows7
In order to sync your iPAQ with Windows Vista or Windows 7, you will need to download and install Windows Mobile Device Center 6.1 from http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx.
Notes
  • To find out whether your version of Windows Vista or Windows 7 is 32-bit or 64-bit, click Start, right-click Computer, and then click Properties. The version is listed after System Type.
  • You can use Windows Mobile Device Center 6.1 only with phones running Windows Mobile 2003 or later. ActiveSync and Windows Mobile Device Center won’t work with Windows Embedded CE 4.2 or 5.0, Pocket PC 2002, or Smartphone 2002 devices. (To see which Windows Mobile operating system you’re using, and if your phone doesn’t have a touch screen, click Start > Settings > About. If your phone has a touch screen, click Start > Settings > System tab > About.) To sync content to any of these devices, you must use a USB or serial cable and your computer’s Internet connection and File Explorer.
  • You must use Microsoft Outlook 2002, Outlook 2003, or Office Outlook 2007 to sync your e-mail, contacts, tasks, and notes from your computer.
  • You must use a USB cable to connect your phone to your computer the first time you use Windows Mobile Device Center to sync.
Dec 30, 2009 | i-mate Pocket PC
IPhone screen completely black.
Take your phone to an apple store and get a replacement.
Jul 13, 2009 | Apple iPhone 3G
Sylvania Lc200sl8 20-inch Lcd Edtv With Built In Tuner Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
