Question about Besta CD-608 Dictionary
Cannot point to icon
Can I plug the adapter in the USB port
Computer does not recognise speedstream 6300
you try form USB or LAN interface \\Ethernet connection (recommended)
  1. Plug one end of the RJ-11 telephone cable into an unfiltered telephone wall jack (enabled for Sympatico High Speed Internet service).
  2. Plug the other end of the RJ-11 telephone cable into the DSL port on the back of the modem.
  3. Plug one end of the RJ-45 Ethernet cable into your computer's Ethernet port.
  4. Plug the other end of the RJ-45 Ethernet cable into the Ethernet Port 1 on the back of the modem.
  5. Insert the rounded end of the power adapter into the Power port and the dual-pronged plug end into your power outlet.
  6. Press the power button to turn on the modem.
USB connection
  3. Plug the small, square end of the USB cable into your computer's USB port.
  4. Plug the wide, flat end of the USB cable into the USB port on the back of the modem.
May 28, 2012 | Efficient Networks Speedstream 6300...
Charging my juke with a usb cord
Fully charge the battery to maximize playing time. However, it is not necessary to fully charge or completely discharge the battery each time. You can charge the battery by connecting the jukebox either to the AC power adapter (fastest) or to a USB port on the computer. The battery icon in the upper right corner of the screen indicates the remaining battery charge.
  1. Connect the USB combo cable to the AC power adapter, and then plug the power adapter into an AC power outlet. Or, you can connect the USB combo cable to a USB port on the computer.
  2. Plug the combo cable into the jukebox. Make sure that the top of the plug (the side with the arrows) is facing the same direction as the front of the jukebox.
    View Picture
  3. If you are charging your jukebox from the computer's USB cable, turn your jukebox off. If your jukebox is on, it cannot charge from the computer's USB cable. Note: If you are charging your jukebox from the AC power adapter, you can leave your jukebox on as it charges, but it will take longer to charge.
  4. If the jukebox is on, the power cord icon appears in the upper right corner of the display. The keypad's backlight turns on while the battery charges, and then turns off when the battery is fully charged.
  5. When your jukebox battery is finished charging, pinch the two side buttons on the plug, and then pull the plug out of the jukebox.
Feb 25, 2012 | Samsung SCH-U470 Juke Cellular Phone
I have connected my nanomax ipod to the computer and it is not charging.how should i charge it?
Good morning, afternoon, evening or night; whatever time you are viewing this solution post. Thank you for choosing FixYa to solve your problem. So you have connected your Nanomax iPod to the computer and it's not charging like it's supposed to, and you want to know how you should charge it properly? There are two ways you can charge the battery - charging via your Dock Connector to USB Cable, or the Apple USB Power Adapter (which is sold separately). Here are the step by step instructions to charging your and Nanomax.
Using the Dock Connector to USB Cable
  1. Using your Dock Connector to USB Cable, plug the dock connector end to your iPod and plug the USB end to your computer. Make sure the computer you are using has a USB 2.0 port (check your computer's technical specifications to see if it's USB 2.0 certified). Most USB ports on the keyboards of laptops do not provide enough power to perform charging activities. If you have a Docking Station, plug the docking connector into the station and placed the iPod in the station as well.
  2. Make sure your computer is fully awake and not asleep (meaning in sleep mode).
  3. A fully charged battery takes 3 hours to complete. An 80% charged battery takes an hour and 30 minutes. The battery is charging when it shows the charging icon (a battery not fully shaded in green, with a lightning bolt).The battery is done charging when the "fully charged" icon shows (a green-shaded battery with a 2-prong plug showing).
  4. When you are done, disconnect the cable from your computer.
Using the Apple USB Power Adapter
  1. Connect the Alternating Current (AC) Plug Adapter with the power adapter (if connected already, skip this step).
  2. Using your Dock Connector to USB Cable, connect the dock connector end to your iPod and the USB end to the power adapter.
  3. Plug the power adapter into a polarized wall outlet or surge protector outlet.
I think you connected everything correctly, but the USB port on your computer did not have enough power to charge your battery. If that's the case, you will have to find a computer that has a USB 2.0 port on it (like a desktop PC or MAC, or a car adapter charging device) and connect to it, or use the USB Power Adapter (sold seperately). I think this pretty much answers your question. I hope this benefits you the best way possible. Once again, thank you for choosing Fixya as your one-stop solution spot for your problems. Have a good day, evening or night; whatever time you are viewing this, and visit us again the next you need assistance troubleshooting.
Apr 27, 2011 | Audio Players & Recorders
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
Wg111v2 not working, I plug it in and it does not light up, and when i try to access the icon on my desktop, it says no wireless adapter detected
Hello Sir,
strage thing. Try to do following things:
1. Switch off computer
2. Plug out device
3. wait 45 seconds
4. switch on computer again, log in to the system
5. plug in the device BUT in different USB port!!!
PS: you may also check in: Right click on My computer icon -> Manager -> Device manager if this device is regocnized by system or it has "?" icon.
Cheers,
Mike
May 08, 2010 | NetGear WG111V2 Wireless Adapter
My adaptor is not recognized in my USB ports I installed the router and it completes all of its connection checks. I am trying to install the adaptor on a remote computer (in the basement) and that...
Here's what you can do since this is a USB wireless adapter, first connect the USB adapter on a different USB port on the computer better if you connect it on the back USB port of the computer tower and check if the computer will recognize it and if its recognize you can already continue with the software installation , but if not you can restart first the computer and check if the adapter will be recognized if still not the next thing to do here just to know if the adapter is good or bad is to connect it on a different computer and just to check if it will be recognized once its connected to a USB port , because a device should be automatically will be recognized by a computer once you connect it so if its still not recognized by a different computer adapter is bad...
Dec 15, 2009 | Computers & Internet
Wirless adaptor only sporadically working
Do you know for sure that the usb port is working properly? Plug in a flash drive or a mouse and see if it's detected. If not, it's the usb port. Try another port. If no usb ports work, post a comment and I'll give you some things to check.
If the usb port works:
Unplug the nic, go to device manager and expand network adapters. Plug in the usb nic. If it doesn't show up in device manager, or if no new hardware is detected, then it's probably dead. Plug it into another pc to confirm.
Hope this helps!
Aug 26, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
How do i change the battery
  1. Remove the cap over the USB plug and insert the unit into the USB port of a desktop or laptop computer. The computer will recognize the Sansa Express as a new hard disk drive.
  2. Locate the battery icon on the upper right of the screen. The battery icon will fill in with color as the unit charges. When the icon is filled in, the charge is complete. The unit will fully charge in about 3 hours as long as the desktop computer or laptop is powered on.
  3. Plug the unit into the USB port of a car or AC adapter and then plug the adapter into an AC outlet or an auto cigarette lighter socket, as the case may be. The Sansa Express will charge in about 3 hours.
Jul 17, 2009 | SanDisk Sansa Clip MP3 Player
How do you install wireless usb adaptor
A wireless USB adapter is a simple device that connects to an open USB port on your computer or laptop, allowing you to connect wirelessly to a network that is within range. They come with different connection speeds, ranges and security protection allowing you to connect to the Internet and use email servers, without complicated setups. Installing USB adapters to a computer is a simple task that anyone can perform. With just a few steps, you can access wireless networkmag-glass_10x10.gif where there is one.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderately Easy Instructions
  1. Step 1 Research around before purchasing a wireless USB adapter. There are many different networking companies such as Belkin, Netgear and Linksys (see links in Resources). Compare prices and features such as speed in megabytes per second (mbps). Look for wireless USB adapters with a compliance of IEEE 802.11b or IEEE 802.11g. These options give you increased security on your network.
  2. Step 2 Plug your purchased USB into a USB port on your computer. Depending on the chosen model, you may have an installation CD. Place your installation CD into the CD-ROM on your computer, and follow the setup instructions to install the wireless USB drivers. Some adapters will install automatically.
  3. Step 3 Locate the wireless icon on the lower right of your computer screen. If there is an "X" marked on it, use the manual that comes with your purchased wireless USB adapter to configure it properly. The wireless icon usually lights up when a wireless connection point is detected.
  4. http://www.microsoft.com/windowsxp/using/networking/setup/wirelessadapter.mspx#2
Dec 11, 2008 | Computers & Internet
Wont connect to wireless network
first, I suggest trying a different USB port. remove the adapter and the icon should disappear, so if the usb port is loose or broken that may be why its acting like that. Plug it into a different port and try it. You may have to reinstall the driver for the next usb port depending on your system
Aug 27, 2007 | Linksys WUSB300N Wireless Adapter
Besta CD-608 Dictionary Logo
27 people viewed this question
Top Besta Office Equipment & Supplies Experts
ray gallant
Are you a Besta Office Equipment and Supply Expert? Answer questions, earn points and help others
