Question about Traulsen Refrigeration 48'' Wide x 24'' Deep Reach-In ''Ultra'' Wine Refrigerator With 2 Clear Blac...
On a two wire t-stat,does it matter how you plug in wires?
T-stat problems
The new wall heater will not go on. The pilot light is on. We replaced the thermostat and the heater came on but would not go off. We checked the wiring..all good. Any advise would be appreciated.
You need to preform a continuity check between your T-stat wires. More than likely, the wire that initializes the call for heat is grounded to one of the other wires. Also, if the unit worked fine prior to the initial problem, it's likely that you haven't purchased the proper t-stat for the unit. Wall heaters typically operate using a millivolt t-stat and not your typical heating stat you would find on a central unit. If you did purchase the correct stat, then more than likely it's not wired correctly, or you have a direct short, as mentioned above, in the wiring.
As usual.....when dealing with electrical, no matter how low of current, please turn off the gas and any electrical current that the unit may have prior to servicing.
Feb 04, 2017 | Heating & Cooling
2 wired t-stat
doesn't matter. simple on and off single pole single throw switch.
Mar 29, 2014 | True GDM-45 Refrigerator
Replacing an ST699 with a ST9400C following repl wiring diagram, but programmer does not come on. Is the diagram incorrect? Wiring colours do not follow any of the plans. Syst has room stat, cyl stat,...
Disregard wire colors. Instead wire by terminal designation. In other words :
Wire on "R" Terminal on old thermostat to "R" Terminal on new thermostat no matter the color.
Jun 14, 2011 | Honeywell Heating & Cooling
We are trying to install a HoneyWell programmable thermostat (model RTH6350) and the colors do not match up. We have an orange wire, blue wire and white wire without a connection. It says to wrap the O,...
T-stat wiring is commonly connected with the following color codes:
On a straight heat and cool system:
White = W on T-Stat
Yellow = Y on T-stat
Green = G on T-stat
Red = R on T-stat
On heat pump systems:
Blue = W2 on T-stat
There is no guarantee that your system is wired using this system so you will need to look in the furnace and see where the wires are connected to. You will have another set, probably 2 wires, going to your outside A/C unit. They are typically red and white but could be any color as long as they are hooked up to the same connections. I.E. blue on R at t-stat and to R on furnace would be OK, it just makes it harder to service the unit if you don't know what wire is for what.
Just check your furnace connections and connect the same wires to your t-stat no matter their colors.
How to replace an old 2-wire t-stat-- both wires red & unmarked
It dose not matter what color the wires are, put 1 wire on the w terminal and the other on the r terminal, if you have a millivolt system check the instruction of the thermostat to see if can be used on a millivolt system, Good luck.
Feb 28, 2010 | Heating & Cooling
Trying to wire RUUD gas furnace. connection block
No problem have done this many times. R from the t-stat goes to R on the indoor unit. G goes to G Y goes to Y and C goes to C if you have a C or the t-stat the you are using. If there is no C there dont worry about it. It only need to be hookup if the t-stat uses power from the unit to run. Many t-stats today use battery power and do not need the C wire hooked up. Now R and C from the outdoor unit. R goes to the Y on the indoor unit and C goes to C on the indoor unit. That means that you may have two wires under the Y terminal and sometimes under the C terminal on the indoor unit. If on the outdoor unit there is no designation of R and C dont worry, just hook one wire to each of the two wires there for your low voltage connection. It does not matter which one goes to which unless they are marked then it may matter.
This should get you up and running and see it really isn't that hard!! :-)
Nov 14, 2009 | Ruud UBHC Air Conditioner
The wire in the furnace are hanging and the thermostat does not switch on the terminal are R C W Y G there is a white connect to the R and White connected to the W the hanging wires are b/g r/w
r stat to r furnace
w stat to w furnace
g stat to g furnace
y stat to y furnace to condensing one wire to y the other to netural of the trans former c it doesnt matter which colors as long as it is wired like I just said. good luck Tom
Jun 22, 2009 | Ruud UBHC Air Conditioner
Home air conditioning too cold at "Fan On" setting
Sounds like you have a wire shorted between y and g somewhere. Maybe a bad tstat. email me if you have more problems james3751@gulftel.com and I may be able to walk you thru the troubleshooting
Jun 02, 2009 | Honeywell Electronic Programmable...
Wiring for baseboard heater
I hope you are using a Line Voltage Thermostat!! First, make sure that the power feeding the thermostat is coming from a two pole breaker of the correct amperage (20 amp). If you are using 12-2 wire with ground then please mark the white wire with black tape at each end to identify it as a HOT power source and not a Neutral wire (which is a grounded lead). Do the same for the 12-2 wires feeding the baseboard heater from the Line Voltage Thermostat. The wires from the thermostat (One Black & one White w/black tape) will be wired to each one of the two wires (one Black & one Red or two Black wires) at the baseboard heater. It doesn't matter which wire from the thermostat is wired to which wire at the heater, just as long as there is one wire to one and one wire to the other.(eg. Black from stat to Black at heater/White w/blk. tape from stat to Red at heater OR Black from stat to Black at heater/White w/blk. tape from stat to OTHER Black at heater). I have seen baseboard heaters with two black wires or one black and one red wire. Hope this helps, but if you are confused then please have an experienced tech. do it for you.
Dec 14, 2008 | Fahrenheat Electric Convector Baseboard...
Wiring a thermostat
your red wire will go to the R, RC, or RH terminal on the stat does'nt matter which one ,this is the wire that provides 24 volt from the furnace. the white wire will connect to the W terminal on the stat. If there is a jumper wire that came on the stat going from RC to RH leave it on.
Mar 08, 2008 | Honeywell Electronic Programmable...
Furniture Logo
26 people viewed this question
Top Traulsen Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Traulsen Furniture Expert? Answer questions, earn points and help others
