Question about Fisher and Paykel WL26CW1 Top Load Washer
Fault 240 wl80t65cw1
Is this a balance problem?
  • Fisher and P... Expert
  • 554 Answers
240. (11110000) Hall Out Of Order. RPS Fault
Same as previous Hall Error faults See fault code130 for directions.
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
Posted on Sep 14, 2014
WL80T65CW1. Why is it displaying fault 234 and will not cycle?
Replace just the lid lock assembly to start with and see how it goes. Lids are quite expensive and don't usually need replacing. You can always get a lid later if you still have problems.
Aug 25, 2015 | Fisher and Paykel Aquasmart wl80t65c
Torque spec on my harmonic balancer on my ls-1
1999 chevy Camaro 5.7
Crankshaft Balancer Bolt (Installation Pass-To Ensure The Balancer Is Completely Installed)
240 ft.lb Crankshaft Balancer Bolt (First Pass-Install A New Bolt After The Installation Pass And Tighten As Described In First And Final Passes) 37 ft.lb Crankshaft Balancer Bolt (Final Pass) 140 deg
Oct 12, 2014 | LIS 52650 Harmonic Balancer Installer
250. (11111010) SmartPump Loss Of Sync
This fault is normally as a result of the pump not starting. This fault is usually caused by an
object that has gotten into the pump, and is either under or on top of the impeller, which is
causing the motor to stall when it is trying to start.
Primary Source: Pump Stator Windings Open Circuit.
Action: Measure the resistances of the pump stator. For more information
refer to the AquaSmart service manual.
Secondary Source: Pump System.
Action: Follow procedures as for Fault Code 249.
Apr 27, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Aquasmart Fisher & Paykel
You will need a technician to fix this,
Error 105
Try to get a Rotor position sensor as they are cheaper.
105. (01101001) Comms Error Time Out
These faults are reported when the Display Module detects an error in the communications
between the Display Module and the Motor Control Module.
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Tertiary Source: Rotor Position Sensor
Action: Replace Rotor position Sensor. If this corrects the fault refit the
original Display Module and/or Motor Control Module.
Feb 21, 2013 | Fisher and Paykel Aquasmart wl80t65c
Error code 136 on aquasmart wl80t65cw1
If your bowl turns freely bearings are not seized,
Your rotor position sensor must be faulty & not outputting the right signal to the motor controller.
Feb 11, 2013 | Fisher and Paykel Washing Machines
Fisher & Paykel Washing Machine WL80T65CW1 Fault 9
sounds like a size error . when you changed the display did you size your machine to the new display module?did you get the re-size set of instructions with the new display board? ring up where you brought the display from and i"m sure they can help. if not reply back and i will guide you thru it.
May 26, 2010 | Washing Machines
Fisher@paykel aquasmart WL80T65CW1 fault code245 and code49
hi my fisher & paykel aquasmart has a message saying fault 49 what does this mean?
Sep 03, 2008 | Washing Machines
Fisher and Paykel WL26CW1 Top Load Washer Logo
137 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
