Question about LG Shine CU720 Cellular Phone
Forgot passcode for lg an272
Need code
How do i hard reset my lg an272
put in this code from your dial pad.....##3282#
This is called a data reset and should fix you right up. Caution!! It will take you back to factory set so get your numbers pic music ect off first.
Jan 23, 2015 | LG Cell Phones
How do i hardreset lg an272
#1; check owners manual... if that fails-
#2; Remove the battery for about 10 seconds. Replace and turn on.
It should be rebooted.
Good Luck.
Cannot access phone - forgot passcode - is there a way to reset the passcode?
Dear:
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 18, 2012 | LG Dare VX9700 Cell Phone
I forgot the passcode to my LG cosmos but i dont have a sims card what should i do!?!?!?!
First, you need to buy or get a sim card then insert it with your phone.
Second, you need to get LG Cosmos Unlock Code tohelp you get the code and unlock your mobile
Hope this is helpful.
Thanks.
Jan 26, 2011 | LG Cell Phones
I have an env3 and I forgot my passcode
last four digits of your phone number
Mar 27, 2010 | LG enV3 VX9200 Cell Phone
Forgot my security pass code for LG KC910
2 my IME :3357090022126619
can you help me? LG KC910
Apr 25, 2009 | LG KC910 Renoir Cell Phone
Forgotten passcode for lg chocolate
Well you could try inputting random codes until the phones asks you for a PUK code, if it doesn't ask for one already.
Then you'll need to call your carrier's help number, and ask the representative for a PUK code. (You'll need paper and a writing utensil handy)
When you enter the codes you were given, it should reset the security code, and you'll be able to use the phone normally.
Apr 04, 2009 | Verizon Communications LG Chocolate Cell...
Unlock LGVX8300 passcode
Try dialing *228, then pressing 1. This reprograms the phone to factory defaults, making your security (lock) code the same as the last four digits of your phone number. For example, if your phone number is (315) 123-0101, then after following the above instructions, your passcode is now "0101". *228 is accessible EVEN when the phone has been locked. This method does NOT delete contacts or change your phone number. All of that information remains the same as before you dialed *228. Also, you do NOT need to remember your old passcode for this to work.
Nov 21, 2007 | LG VX8300 Cellular Phone
LG Shine CU720 Cellular Phone Logo
73 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
