Question about Maytag Neptune MDG5500AW Gas Dryer
Partial Heat The upper cabinet has heat but the drum does not..
  •  Mekano Electromenagers
    Hi Dave Lux, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • Dave Lux
    Dave Lux Mar 30, 2014
    The unit that I have has a drying cabinet on the top and the standard drum dryer on the bottom. The cabinet has heat but the drum part does not. I know Maytag did not make this unit easy to service but I vaguely remember having to clean out the inside of the unit under the drum once before (I've had it since 12/2005). I need some type of service directions in order to take the front off as well as a likely culprit. Thanks!
    Problem Solver:
  • 16 Answers
Hi Dave, there's the explosed view of your gaz dryer. I hope this will help you. tank you MDG5500AWW Reliable Parts Appliance Model Lookup
Posted on Mar 30, 2014
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: magtag neptune mce8000ayq
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
fggfs
Posted on Sep 30, 2010
kel1guy2002
  • 3740 Answers
SOURCE: My Neptune Drying center is
Hi and welcome to FixYa, I am Kelly
There are several reasons for the symptom you describe.
Before you do anything.... go to the main circuit breaker panel and turn off power by physically pushing the circuit breaker to OFF (resets breaker) and then back to on. Then test for heat.
NOTE: Anytime there unit internal drum cabinet is opened make sure power is OFF as failure to do so can be fatal.
- First as you just open or just close the fryer door listen for an audible micro-switch click. (No click and the door switch has failed)
- Next reach inside the dryer grab one of the 3 baffles and attempt to rotate the dryer drum. If it rotates with little resistance (as in your sure the motor is not also turning) then the drive belt has broken. (You would hear the motor running but the drum would not turn when pushing the start button)
- There is a thermistor that is a one time failure component that is item 13 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174453
The thermistor opens when the internal temp reaches 210 deg and will terminate power to the unit. The thermistor fails as a result of poor air-flow. You must check ALL of the dryer ducting for signs of lint build up inside the cabinet and all the way though the outside wall. The though the wall flapper is often where the lint problems manifest. Also if the blower wheel Item 19 of the above link has failed it will result in poor air-flow and cause the thermistor to fail. The thermistor will read continuity at all times if it is good and open if it has been activated. IF THIS THERMISTOR FAILS THE UNIT WOULD NOT RESPOND to any user inputs.
- Make sure to wash the lint filter with vinegar and water, then soap and water before returning the unit to service. If you use dryer sheets the lint filter will appear clean but can be almost completely blocked,
- Pull out the lint filter then using a flash light inspect for lint in the bottom of the lint filter receptacle.
- The thermostat that is item 4 of this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174453&diagram_id=28600840#d28600840 can cause it not to heat.
- The heater Item 5 of the above link can also cause it not to heat.
- The heater circuit also has a themistor Item 9 of the above link that will cause no heat.
WIRING DIAGRAM:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28600844&pkw_=basket&model_id=5174453&NewWindow=1
(Make sure to test all thermal fuses, thermostats AND the heater for continuity)
The motor relay board and the motor start / run switch can cause this problem also. These are very rare failures.
Performing the above checks should isolate where the failure(s) have manifested.
Thanks for choosing FixYa,
Kelly
Posted on Feb 14, 2011
My AEG induction oven is suddenly blowing the fuse - both ovens do it. Is it still the element, do you think? Thanks
Check the power cord to the oven, follow it inside and see if might be heat damaged or otherwise shorted, this means partial disassembly of the oven cabinet.
Nov 29, 2016 | AEG Ovens
Maytag electric dryer de410 trouble shooting! How do I remove the cabinet?
There should be an element behind the spin drum,take cover off the back to undo drum.
Jul 26, 2014 | Maytag Dryers
My Maytag double stack gas dryer does not work, the screen is blank(not lighted)
Most clothes dryers have a thermal limiter or fuse, which is a heat-sensitive safety mechanism that shuts off heat to the drum or the power supply to the dryer if it overheats. Unfortunately, you can't replace a thermal limiter once it activates. The only choice you have is to replace it; your dryer won't operate properly until you do.
Although you can't reset a thermal limiter that has been blown, you can reset the dryer's two circuit breakers and restore heat to the drum and power to the dryer. However, after the breakers are reset, you'll still only have partial function of your dryer. For example, it might spin but not heat or it might initially turn on just to shut down after a few minutes. You must replace the defective thermal limiter to reinstate your dryer's full function.
Apr 16, 2012 | Dryers
Maytag neptune dryer upper cabinet no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 26, 2011 | Dryers
I have a kenmore gas dryer, the drum turns but no heat, I replaced the radiant sensor and the control thermostat but still no heat?
here is a partial list of componets that could cause the dryer to not heat
Ignitor
control t-stat
high limit t-stat
gas valve coils
thermal cutoff
thermal fuse
flame sensor
electronic control/or timer depending on your exact model
cycling t-stat
motor
Jul 23, 2011 | Dryers
The dryer operates but does not produce heat. i think it is the heating element but i can not get in to the back of the dryer to check. i would like to get a service manual so i can check the element
1 Unplug the power cord from the electrical socket.
2 Remove the screws located around the edges of the back panel of the DVLR223 dryer. Move the back panel away from the cabinet.
3 Push the idler pulley away from the belt to loosen the belt tension. Remove the screws on the panel behind the dryer drum. Remove the panel.
4 Remove the four screws located on the underside of the top panel. Lift the top panel off of the cabinet.
5 Lift the drum up through the top of the cabinet and set it aside.
6 Unplug the electrical wires connected to the heating element assembly. Remove the old heating element from the DVLR223.
7 Insert the new heating element where the old one was previously located. Plug the electrical wires into the heating element assembly.
8 Replace the drum inside the dryer cabinet. Replace the top panel and the four screws that go on the underside of it.
9 Replace the panel behind the drum. Replace the screws that hold it in position.
10 Reposition the back panel onto the DVLR223. Replace the sheet metal screws around the perimeter of the back panel.
Jun 19, 2011 | GE DVLR223 Dryers
My Neptune Drying center is not working. The lower cabinet is ok but the upper cabinet does not heat up and does not steam. We've tried cleaning the bottle etc & made sure the filter was not clogged. ...
WIRING DIAGRAM:
Kelly
Feb 14, 2011 | Maytag Neptune MCE8000AY Electric Dryer
Magtag neptune mce8000ayq
heatman101
fggfs
Sep 22, 2009 | Maytag Neptune MCE8000AY Electric Dryer
No heat from dryer
remove the back and check the heater box fuse upper left on heater box,and check the heating element bottom part of heater box,the heat box is located to the right of the back of dryer-mike
Apr 29, 2009 | Kenmore 63942 Dryer
Dryer heat but what turn
Hello Friend, Replacing a dryer belt is very simple. Just remove front of dryer cabinet. unplug wires from dryer door switch. Just slide a new belt over the drum with the belt grooves facing to the inside. Underneath drum you will see a tention wheel next to motor. Install belt around tention wheel and around motor shaft pully. Re-install front dryer cabinet. Make sure to plug in the wires to the door switch and make sure that the drum is re-inserted back over the felt glide on inner cabinet front. Happy to help, Tim.
Mar 28, 2009 | AEG T57800 Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
70 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
