Question about Exercise & Fitness
Instructions bodymotor treadmill
BMR-TR-2000l treadmill shows error message E0 indicating safety key is not attached. Key IS attached correctly yet error message still shows. Unit is clean and is indoors so not subject to moisture etc. Using a different magnet as safety key doesn't work. Help please?
SOURCE: I have lost the safety key for my Weslo treadmill
Hi I folded up a piece of paper several times to make it into a small rectanguler shape and inserted into the slot for the key and it worked.
The replacement key doesn't need to be magnet just small enough to fit the shap of the slot is fine.Mine was a Weslo cadence 1000 (bought in 2002)
Posted on Jan 10, 2010
SOURCE: i have a pro form performance j4 treadmill. i
It is just plastic. You can wedge a piece into the slot
Posted on Feb 02, 2010
  • 246 Answers
SOURCE: WE have just moved home and lost our safety magnet
here's a link to an ebay page of treadmill safety keys for horizon treadmills. hope this helps!
Posted on Feb 18, 2010
  • 95 Answers
SOURCE: I have a Sportsart treadmill
I would think that it can't hurt anything to try another magnet but if you end up needing to buy another one here is one website that sells them: Sportsart TR20F safety key
Posted on Apr 18, 2011
ercupa190
  • 12223 Answers
SOURCE: where can I buy the the safety key for a jazzfit s1 treadmill, I've lost the magnet to power on, can anyone please help
www.fitnessrepairparts.com
www.treadmilldoctor.com
www.gympart.com
sincerely.
Posted on Nov 15, 2011
What is the safty key
the SAFETY key attaches to the console of the treadmill usually by a magnet and is linked to the users clothing so if they fall they pull the safety key off and the treadmill automatically stops. The treadmill will not work without the safety key in place
Aug 03, 2014 | Nordic Track Nordictrack A2350 Treadmill...
Error E0 motorized treadmill ts5202fi
Usually this means a problem with the safety key area.
Dec 03, 2013 | Exercise & Fitness
Repco rp300tm
1) reset the treadmil.2) adjust the speed sensor, see the diagram attached. 3) Run the software calibration for easy diagnostic and fix it. God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button 31d332da-cd1c-4885-8ae4-393941ca1930.gif
Oct 18, 2013 | Proform Perspective Es Treadmill PFTL99806
Error Code E7
To fix the error you have to put the safety key in start it it and wait for it to say E7. Now press stop and incline( up) together and hold for 20 seconds. Your treadmill will start to incline up. Take out your safety key. You just restarted your treadmill and can now put the safety key back and your problem will be fixed.
Apr 22, 2012 | Exercise & Fitness
Error 7 on my york inspiration treadmill tried reset button but still not working any ideas.
hi,
By error 7 it means that the safety is not positioned correctly. or the saftey switch inside the unit is faulty. Its a magnetic switch. When you place the safety key (its made of magnet) this switch will activate. Then only teradmill start. Check the safety key is positined correctly or not. If it is in position then you have to replace the safety switch inside the control console.
OK
Sep 01, 2011 | York Barbell Home Use Fold-Up Treadmill
Two lines appear on the console screen and incline starts going up, then when key is removed all lights go on but nothing works.
I assume you are talking about the safety key. It should have a string attached to it and a clip on the other end of the key's string.
The key is a safety feature and the key should be in the control panel and the clip attached to your shorts or shirt when you are using the treadmill. If you fall of the treadmill, the clip pulls the string and the key is pulled from the panel on the treadmill. This should stop the treadmill instantly by cutting main power to the unit. Main power is shut off because the key is a safety device and it MUST work every time. To help avoid design errors or unreliable stops when the key is pulled, a good designer will shut everything off, not just the motor for the tread belt. I would say your unit was designed by a good design team since everthing goes off when the key is pulled.
From my point of view, it is working as designed unless you are talking about a different key.
I know someone who did not wear their safety key and they slipped on the treadmill, the treadmill threw them into the wall behind the unit and they were stuck with their leg against the treadmill. The belt on the treadmill wore their skin down to the bone on their knee in only a few seconds. Lesson one, keep your treadmill at least 3 feet from the wall. Lesson 2, use the safety key and clip.
-Mark
Jul 17, 2011 | Reebok V 680 Treadmill
Hi, our proform 790 tr treadmill is aorund six years old and the walking belt and height motor seem to be going. Is it worth replacing these and is it fairly straightforward?
Changing a walking belt takes about an hour for someone who has done it before. Check the walking deck for scratches, damage as well. Often times if the belt is worn out, the deck needs to be replaced as well. Belts vary in price depending on the make and model of treadmill. Parts can be ordered by calling the number found on the model number sticker on the treadmill. There are 10 different machines with the 790t model name. To get the correct parts find the actual model number (will start with "H"). The parts come with replacement instructions.
Belt $105 Deck $190
As for the incline motor, it is very rare to change that part. It may just require calibration. Start the machine . Press incline up and hold, remove the safety key. Now reinsert the safety key. The machine should rise to full incline then back down to minimum. Once the cycle is complete, the treadmill should work normally. If the incline sensor is defective, the motor will have to be replaced. Incline motor $150.
Feb 26, 2011 | Proform 790T Treadmill
I turn the treadmill on and it has a message saying that the safety key is off. How do i turn it on?
Your safety key is the magnet switch with the cord attached to it on the front of your computer. If the computer says the key is off then try repositioning the safety key magnet. If it still doesnt work you may have a loose wire behind the key section.
Feb 10, 2011 | Horizon AFG 5.0 AT Treadmill
Proform Crosstrainer 5.0 Treadmill
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
Jul 15, 2010 | Proform Exercise & Fitness
York t500 treadmill model no:LQ6010 showing err07 when turned on
Error 7 is a Safety Key Error..
that's the red magnetic circular thingy on the console.
Simply secure the safety key in place and try it again
Jan 19, 2009 | York Barbell Home Use Fold-Up Treadmill
Exercise & Fitness Logo
42 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
