Question about Vehicle Parts & Accessories
What is the torque on the transmission pan bolts when replacing the trany fluids
  • Joel Friedenberg Mar 30, 2014
    Hi vincent reed, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Need to know what vehicle, what year and which tranny.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 103 Answers
Most of them are just slightly more than hand tight, but more exotic vehicles have inch/lb readings. Can't tell without more info.
Posted on Apr 02, 2014
How do i change the transmission gasket on a 1988 chevy Silverado
Raise vehicle and support on jack stands. Loosing nuts on transmission making one side lower than the other this will allow you to drain fluid. Drain fluid remove bolts on pan. Remove pan remove old gasket, clean pan and transmission edge, replace with new gasket. Replace pan and bolts. Torque to spec and refill transmission
May 05, 2016 | Cars & Trucks
Bad transmission seal on a 2002 ford explorer
Drain the Transmission Fluid and Replace the Filter
Raise the car with ramps or a floor jack and support it with jack stands. Find the lower cover of the torque converter housing. Turn the torque converter until you find the drain plug. Place a drain pan beneath the drain hole, remove the plug and drain the fluid.
Remove the cooler lines at the transmission and flush them with compressed, low pressure air. Be careful during this step; fluid may shoot from the other cooler line.
Place a large drain pan beneath the transmission. Loosen the retaining bolts on the oil pan with a socket wrench until they are within a few turns of removal. If the seal doesn't break on its own, gently tap it with a rubber hammer. Fluid will drain from the edges of the pan.
Remove the pan retaining bolts when the fluid stops draining. There is still transmission fluid in the pan. Hold the pan carefully and drain as much as you can into the drain pan.
Scape the old gasket material from the mating surfaces on the oil pan and the transmission. Discard the old gasket. Clean the magnet in the pan. Clean the pan and the mating surfaces with a solvent and a clean, lint-free cloth. Replace the magnet and allow the pan to air dry.
Employ a socket wrench to remove the bolt that holds the filter onto the transmission. Some models may have two bolts. Pull the filter and any old seals or gaskets from the transmission. Install a new filter assembly, including any required seals or gaskets.
Put a new gasket on the oil pan and reinstall it on the transmission. Tighten the retaining bolts to 79- to 119-inch pounds with a torque wrench. Replace the cooler lines on the transmission and the drain plug on the torque converter.
OBD Tools 365 Days Shop
Sep 25, 2014 | 2002 Ford Explorer
Change the transmission fluid in a 2000 ford windstar van
The transmission service is performed by lifting the vehicle in order to get access to the transmission pan. Remove all the bolts that hold the pan in place and the fluid will come out when the pan is being lowerd. From there the filter is accesible and should be changed by simply pulling it downward. The new one is installed by pushing it firmly in place where the old one once was. Clean the pan of the transmission completely including the magnet. place new gasket around the pan and reinstall all the pan bolts. be carefull not to over tighten the pan bolts as it can damage the new gasket the you have put on. next, lower the vehicle and add fluid through the dipstick tube located in the engine compartment. It's best to add 4 quarts then start the vehicle and check the level. If more is needed, add accordingly.
Macs Transmissions
281-394-4951
Macstransmissions@gmail.com
There is none. To change the fluid you need to remove the cover - undo one end first to limit the mess - but yes, it's messy. AnswerBest To Have A Good Transmission Shop Do This. Sometimes You Can Miss Alighn The Filter On Some Tranmissions And They Will Go Out. About Changing The Fluid, Even If You Could It Wouldn`t Do The Job Without a New Filter. Good Luck AnswerThere is an excellent write-up on this procedure relating to a Taurus - the steps are the same.
See "Related Questions" below for more
NOTE: dropping the pan alone will NOT change ALL the fluids - specifically the fluid that is in the torque converter. That would require a shop to perform a full fluid change with their specialized equipment. Answerdrop the pan, replace filter, clean pan replace gasket torq bolts to spec. refill to warm line on stick
Rick
ASE L-1 Master TransMichigan.com AnswerRemove the pan and then remove the filter on the valve body. Clean the pan and gasket surfaces on pan & trany. Install new filter and pan gasket and gently tighten bolts. Caution, if overtightened it will leak!!! Remember how tight they were when you removed them or get a spec & torque them. Refill the trany through the filler tube, DON'T overfill it or it may not shift properly. To check the fluid level the vehicle needs to be running in park and on a level surface. If you do the above you will only change aprox 40% of the fluid. The torque converter, cooler & lines hold the rest and the fluid won't drain out of them.
I suggest you take it to a shop that has a trany FLUSHING machine and will exchange 100% of the fluid and do the filter & gasket at the same time. Add a bottle of seal conditioner when done. With the price of a new trany this should be done every 80,000 kilometers (50-60,000 miles) or check your owners manual for service intervals. Not a lot of shops have this machine so be selective. Might cost up to $200-250.00 for this service to get it done properly but a proper trany rebuild can be $1500-3000.00 or more in some cases on some vehicles.
Flushing the fluid?
But the system should be flushed. Just dropping the pan and draining the oil and changing the filter on your transmission leaves all the used fluid still in torque converter. Have the system evacuated and totally replacing ALL the fluid is a much better approach. It will cost you more but if you plan on keeping the Ford, it's a worthwhile investment.
Source.
Dec 12, 2012 | Cars & Trucks
Is the Transmission sealed, can not change the filter and fluid? Where is the radiator, is it also sealed, can water only be put in the overflow?
The transmission is not sealed in the v8 I looked up. It's bolted together. prev.gif next.gif Fluid Pan Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section
  2. Raise and support the vehicle
  3. Place a drain pan under the transmission fluid pan
  4. Remove or disconnect the following:
    • Drain plug and drain the fluid
    • Shifter cable bracket NOTE: The transmission fluid pan gasket is reusable, clean and inspect for damage; if not damaged, the gasket should be reused.
    • Fluid pan and gasket
    • Transmission fluid filter
    • Clean and inspect the transmission fluid pan and magnet
    • Converter housing access plug
    • Converter drain plug
To Install:
NOTE: A new converter drain plug must be used to prevent leakage.
  1. Install or connect the following:
    • Install the converter drain plug. Torque to 89 in-lbs (10 Nm)
    • Install the converter housing access plug
  2. Lubricate the seals and install the transmission fluid filter. Torque the bolts to 89 in-lbs (10 Nm)
  3. Install the oil pan magnet in the transmission fluid pan NOTE: The transmission fluid pan gasket is reusable, clean and inspect for damage; if not damaged, the gasket should be reused.
  4. Install the transmission fluid pan and gasket and loosely install the screws.
  5. Using a crisscross sequence, torque the screws to 8 ft-lbs (11 Nm)
  6. Install the shifter cable bracket. Torque bolts to 18 ft-lbs (25 Nm)
  7. Install the drain plug. Torque to 19 ft-lbs (26 Nm) NOTE: It will be necessary to hold the drain plug (larger plug) with a wrench when removing the fluid level indicator plug.
    NOTE: Use 3/16 inch Allen key to remove the fluid level indicator plug. Remove the fluid level indicator plug.
  8. Verify the transmission fluid level
Jul 21, 2010 | 2001 Lincoln LS
Does a torque converter for a 1989 ford bronco trwo have antyhing to do with a fly wheel
the torque converter bolts to the drive plate that supports the ring gear
Mar 24, 2010 | 1989 Ford Bronco II
HOW TO CHANGE TRANSMISSION FLUID AND FILTER
jack van, use safty stands to hold up, put a pan under trany pan to catch fluid, remove blots holding pan,fluid will start to leak out.leave the front bolts for last ,that way theoil leaks out the back,after all bolts are removed then take pan down, pull filter out,install new filter with gasket ring for neck of filter, clean pan and trany, install pan gasket and bolt up.use cross pattern to tighten,just tight alittle dont crush gasket. put in 4 qts,run engine and run through gear, check fluid and add acording to dip stick,hope this is helpful.
Dec 24, 2009 | 1996 Dodge Caravan
How to change trany oil
u have to drop the pan and chane filter
Nov 05, 2009 | 2003 Ford F150 Regular Cab
Where is the bolt to drain the transmission fluid on a honda element
Allot of trani pans have no bolt.. You would just drop the pan & fluid comes out..
Dont forget to get a new pan gaskit & a filter - if that model calls for one..
FYI; A pan drop is only part of the fluid - about 3 to 5 quarts..
The trani & torque converter hold 7 to 9 quarts all together..
Hope this helps !!
Rate me good ;o)
Jul 10, 2009 | 2008 Honda Element
Need to change the transmission fluid in my 98 corvette
to change your tranny fluid and filter is relativily easy i will tell you step by step here.
1. raise the vehicle and support it with jack stands
2. get a large drain pan
3. locate the transmission oil pand and losen all the bolts removing the rear half of the bolts only and just losening the other bolts to keep the pan held up but allowing it to sag on the rear.
4 be carefull because in this step your likely to get a bath in tranny fluid. insert a flat srewdriver in the back of the pan and carefully pry it lose. now trany fluid is going to pour out of the pan.
5. remove the rest of the bolts be carefull because the trany pan still has a lot of fluid in it.
6. grab ahold of the filter and pull it down.
7. insert the new filter but make sure the rubber gasket came offf with the old filter they have a tendency to stick in the transmission.
8 replace oil pan and torque down evenly
9 refill with correct fluid to the correct level
10 take for a drive and recheck the fluid level and check for transmission fluid leaks
ps when the pan is off clean the inside of it out with brake cleaner really good
If there are no leaks after you get done congratulate your self on a job well done
hope this helps you
please rate me
Thank you
Apr 21, 2009 | 1998 Chevrolet Corvette
Vehicle Parts & Accessories Logo
64 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
