Question about Vicks Cool Mist V3500 Humidifier
Medicine where does the medicine go
Re: medicine
You don't. There are some solutions you can but for it to make sure it doesn'y get slimmy, but that's about it. It works quite well without any medicine, just works great!! Ever since I bought it six years ago my son loves it and his room gets nice and cool and he can sleep and breathe much better at night. Good luck and hoepfully this was helpful to you. Have a nice and pleasant day.
Posted on Aug 23, 2008
0 characters
3 Points
I am sorry but i didn't understand if i need to mix de medicine with water or put in medicine cup. I lost the instructions....thanks
the vapour oil medicine is put in the little reservoir right at the front top on the blue unit that sits on the plastic base... about a tablespoon. It will still be there after use, but it's only oil residue, after the medicine has evaporated with steam. clean it out with paper towel and refill for each use when needed. Only salt is added to the water, not the oil...
Mar 09, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Do you fill with cold or hot water for vicks warm steam humidifier
im pretty sure you fill it with cold least thats the direstions for when you use the vicks medicine you can add great by the way
Feb 28, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
How much medicine or vicks additive
vicks additive in the lil slot in front of where the steam comes out thats what the ilpouch is there for
Feb 23, 2010 | Vicks V150SG 1 Gallon Humidifier
I added water and the vicks medicine and no steam
medication was never meant to go into a humidifier. it clogs the transducer. if you can clean the vicks off the transducer plate you might squeeze another season out of it, otherwise by adding medication to the machine you just gave it an early death.
Oct 23, 2009 | Vicks Warm Mist V745A 1 Gallon Humidifier
How do I clean my humidifier?
I had the same problem. This will cause the orange reset light to turn on as well. You need to remove the reservoir and the cooling chanber. Under the reservoir there is a locking mechanism that you push to the side. You then pull off the cooling tower. Then you push the locking mechanism in the other direction and remove the steam mechanism. I found a month of build up of "gook" inside. Dump it out and use a scrouring pad to remove it. After this was done, I could smell the vapor from the medicine cup again and it ran all night on the high setting again.
Dec 16, 2008 | Vicks Warm Mist V745A 1 Gallon Humidifier
Humidifier leaves a crusty dark substance in water
Discoloration/Black Particles
After use, the water residue in the bottom of the container may contain black particles, and, in
some areas the water and the bottom of container may discolor. These conditions are normal and
do not effect the purity of the steam or medicine. The container is easily cleaned with soap and
water. Rinse and dry the container after cleaning.
This was taken from the manual that comes with the humidifier...
Dec 12, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vaporizer is making a spitting sound -
No salt, unless you had 0 steam - to stop water spit, throughly clean the water tank, just as clean as new. It will work like new if the tank is as clean as new! I dont know where the small particles of dirt come from, but trust me, I just went thru this with mine, it's got dirt in it!
Nov 19, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
For Model V745A Vicks Warm Mist Humidifier:
Weekly Maintenance (Removing Scale)
  1. Turn the switch to off and unplug the corn from the wall.
  2. Remove Water Tank and empty any remaining water from the water tank.
  3. Remove Medicine Cup from the Cooling chamber from the Base. Carefully remove the Cooling Chamber and Removable Water Tray from the Base.
  4. Soak the Removable Water Tray in a solution of white vinegar and water for 20 minutes. Rinse thoroughly and then wipe dry with a soft clean cloth.
  5. Fill the heating chamber with undiluted white vinegar. Let stand for 20 minutes. Dampen soft, clean cloth or sponge with undiluted white vinegar and wipe out Heating chamber to remove scale. DO NOT use soap, detergents or abrasive cleaners.
  6. Rinse the Heating Chamber using clean warm water, being careful not to submerge the base in water.
  7. The Water Tray, medicine Cup, and Cooling Chamber are top shelf dishwasher safe.
May 23, 2008 | Vicks Warm Mist V745A 1 Gallon Humidifier
Vicks Cool Mist V3500 Humidifier Logo
418 people viewed this question
Top Vicks Humidifiers Experts
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
