Question about IBM ThinkCentre Computers & Internet
I get no startup message on my ibm thinkcentre pc so I can't access the boot manager
I have a blank hard drive, and I want to boot from my dvd drive so I can install Windows XP on the PC. I get an initial screen, with the IBM logo, but no startup message telling me what keys to press to enter setup. I've tried F1 & F2 and they do nothing. If I can't boot from an optical disk, the PC is useless.
  • 4 Answers
Can you please try by pressing F10 Key. It should give you the option to boot from. Please share the result.
Posted on Mar 30, 2014
Beni S-P
  • 1006 Answers
SOURCE: My PC will not boot but only displays "press F2 to enter bios setup"
Go to BIOS and go to LOAD SETUP DEFAULT OR LOAD OPTIMIZED DEFAULT -YESS- AND RESTART
Posted on Oct 12, 2007
  • 258 Answers
SOURCE: can't reload XP
Depending on the age of your PC it may have Dell automatic recovery
During startup at the Dell Screen hold down the CTRL key and tap F11 twice
It may display the Dell Recovery from which you can set your computer back to factory settings
Please note all your files will be deleted
Posted on Jan 25, 2009
SOURCE: concerning a thinkcentre ibm 8183 pentium 3: I put
propably u have maked the new hard disque in slave position then u got two slaves and they don't work.try to detect all your drives 2 HDD and DVD by the auto detect utiliti in bios then they must works.ah don't forget in iche nape ther r 1master and 1 slave.thanx
Posted on Aug 15, 2009
SOURCE: How to change the boot option in IBM 6578-PBU desktop
I searched for hours for a solution to this. Here it is:
1). Restart your computer, NOT using ctrl - alt - del
2). Press F1 when guided to.
3). When you get into the config menu, select Start Options, then hit enter twice.
There are all the options you need! Cool, huh?
Posted on Sep 06, 2009
ic0729
  • 212 Answers
SOURCE: Wounlt go past IBM logo and cant access F1 or F12
Did you check the fans to see if the unit is overheating?
Clean out all ducts and airways from the fans and try this again. Write back to me with your results.
Posted on Mar 15, 2010
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
IBM ThinkCentre 8183 (M51) does not boot
I think it is more than likely your hard drive is the problem, you get the splash screen and everything is working up to that point which tells me the motherboard is fine.
Jul 07, 2012 | IBM ThinkCentre M51 PC Desktop
If i want to format the pc first i hv to change my setup as a first boot device is cd-rom , so what i have to do in ibm motherboard thinkcentre in setup in which section the bootable device order is...
Look for the boot order options in the setup or pay attention at the actual startup of the laptop when the IBM logo is being displayed. You will notice a message on the screen indicating which button to press to select the "boot order" or "boot options". Press the button (ussually one of the F1 - F12 keys) and you will be presented with a choice of which device to use to boot from.
Oct 01, 2010 | IBM ThinkCentre A50 8085 Intel Desktop PC...
Bought a used IBM ThinkCentre M52 8215-VAN S/N LK71288 for $5.00. Needed memory and hard drive. Installed memory. Don't have harness for hard drive. Not sure where to plug hard drive in. Has optical...
if you have any discs in the dvd remove them... it should boot to the hard drive when it doesn't find anything in the dvd. if you need to install an operating system put that disc in the dvd and boot from it. during the installation it will start to run off the hard drive. when you are done installing remove the installation disc.
Sep 30, 2010 | IBM ThinkCentre M52 8215 - P4 531 3 GHz...
I have a ibm thinkcentre desktop and the hard drive is blank and i have the restore cd's but not working how tdo i use them?
the computer needs to be set to start from the cd, make sure you got the right cd in the drive and then read and follow this page to change the boot order so that the computer starts from the cd - http://www.whitecanyon.com/how-to-change-boot-order.php
Sep 10, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Concerning a thinkcentre ibm 8183 pentium 3: I put in a blank new hard drive and am wanting to instal a new os from the dvd drive...using f1 to get to different boot options..i choose boot from dvd drive...
your bios settings are not saved because of low voltage of CMOS cell.
Change your cmos cell from motherbord.
CMOs cell gives power to bios flash memory so settings saved.
Aug 15, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Getting problem in formatting the IBM PC
check if the cable from the cd rom connected to your ibm pc if its ok , also check the master, slave configuration pins into the back of your cdrom. make sure that theres no conflict between the hard disk and the cdrom. Your cd rom may probably cannot be detected. make sure that it is working first. then install the hard disk. The hard disk must be in primary master and the cd rom must be in primary slave. then try booting it to your cd rom. also, try checking if your windows xp setup disk is bootable, it means that it can boot from cd rom. PM me if you have other experiences after doing what i adviced. Thank You.. heres my email. jmizpahadonai777@gmail.com
Aug 07, 2009 | IBM Thinkcentre 8185 PC Desktop
Getting a message saying trying to boot from the network drive
Go into setup as it boots up and make sure there is a hard drive recognized by the BIOS. It sounds as if there isn't. If there is, make sure the hard drive is the first boot device.
May 20, 2009 | IBM ThinkCentre A51 PC Desktop
TO CHANGE THE BOOT SEQUENCE FROM HARD DISK TO CD
before you see the logo screen when you boot up, you should see press f1, or delete to go to system settings etc, thats where you change the boot sequence
Jan 19, 2009 | IBM ThinkCentre M50 PC Desktop
Computers & Internet Logo
59 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
