Question about Sony Playstation 3 (PS3) Console
Blank screen i have tried to fix it over 100 times by holding in the power button any other options
    President:
  • 2,653 Answers
The problem is with the GPU on the motherboard.
HERE's a guide to fixing the problem but it's not for the average home user.
Posted on Jun 15, 2009
Why when I turn on my zeepad screen is blank battery is fully charged the green man shows then blank screen?
Hi, try a Hard Reset!
Normally, you have to hold one of the volume buttons down while powering on the device(try them one at a time). If you get a screen that says something about download, try the other volume button.
Once the device has booted to the "special recovery" menu, this is controlled by one of the volume buttons to scroll through the options and the POWER button acts as an enter key. Be on the lookout for an option that says something about "restore factory settings" and select that!
Oct 18, 2014 | ZEEPAD 7DRK Dual Core 4.2 Blue Android...
My phones screen is blank how can i fix it ?!
You could try reseting your phone (do this by holding the volume up or down button, power button and the menu button all at the same time) do this until the service screen appears. If this doesn't work you could try the same thing only with just the power button and menu button.
Jul 01, 2014 | ZTE Cricket Score Android Muve Cell Phone...
Black screen when turned onno display
There are several reasons that your Toshiba laptop screen may not come on, even if the laptop appears to be running, and several options you may try to get your screen back up and running without an expensive service call.
Common causes for a blank screen include a backlight that is turned off, a display toggled to an external monitor and improper shutdown errors.
To avoid blank screen errors after your current error is fixed, make sure to follow all instructions in your user's guide to care for your Toshiba computer.
Shine a flashlight directly at your screen and look for an image.
If you see one, this means the backlight on your laptop is off but the screen is still working. This backlight normally turns off only when your screen is closed.
Look for a small metal or plastic pin near one of the screen hinges.
The screen pushes this pin in when it is closed, so if the pin is stuck in the screen closed position, the backlight will remain off.
Tap the pin several times to release it.
You may need to use a small object, such as a pencil tip or straightened paper clip, to reach it on some models.
Monitor Toggle
Press and hold down the "Fn" key if you do not see an image when you use the flashlight.
Tap the "F5" key several times while the "Fn" key is pressed.
This will cycle your screen through the various options that toggle the display to an external monitor.
Attach an external monitor, restart the computer and try this method again if no image appears on the laptop screen.
Click "Start," "Control panel," "Hardware and sound," then "Device manager "using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Select the "Monitor" option to expand your selection and select your LCD monitor from the device list.
Click the "Driver" tab and select "Update" to update the driver, as this error is likely caused by a software driver error.
Force Restart
Press and hold the power button until the computer shuts down completely.
Check the indicator lights at the edge of your laptop to see if the computer is truly off or if it has simply gone into hibernation mode.
If it is off, all lights will be off except the battery-related lights if you have a charger plugged in. In hibernation mode, the power light will blink slowly.
Press the power button to restart the computer again after leaving it off for 15 to 20 seconds. This may fix the problem.
If the blank screen returns or you get a flash of images and then a blank screen, move on to the next step.
Force Power Down
Unplug your laptop from the power source.
Remove the battery by pressing outward on the battery latch and pulling the battery unit completely out of the computer.
Press the power button several times to completely discharge the computer.
Replace the battery and plug the computer back in after about 30 seconds.
Press the power button to turn on the computer.
If you get an error screen upon startup, choose to restart Windows normally.
This error is caused by improper shutdown procedures.
Hope this helps
Nov 14, 2012 | Toshiba Computers & Internet
My toshiba l355d black screen all fans and lights are working
Monitor Toggle
Click "Start," "Control panel," "Hardware and sound," then "Device manager" using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Force Restart
Force Power Down
Hope this helps
Nov 03, 2012 | Toshiba Satellite L355D-S7901 Series...
Kindle fire screen is blank
Try doing a hard reset of your Kindle Fire as advised on the Kindle Fire Support web site for dealing with Screen problems
If you still have a problem after doing the above, then you follow the additional steps advised on the above web page, i.e. ensure the Kindle Fire is fully charged (the power indicator has changed from Orange to Green) and that you have the latest Software Updates installed (assuming you can view the screen to do so!).
Jan 08, 2012 | Amazon Kindle Computers & Internet
When i turn on my iphone, the screen lights up but is blank
Hi!
You can try to restart your iPhone if that doesnt make any difference you can try to reset
To restart:
Hold down the hold button at the top right of the phone until a red slider appears onscreen. Slide it to turn the phone off and, when it's off, turn it back on again by holding down the hold button until the Apple logo appears.
To Reset:
Hold both the Home Button and the Hold button at the same time. Do this until the screen flashes and the Apple logo appears, indicating that the phone has restarted.
If none of the steps above fix the problem then contact Apple to check for repair options
GoodLuck!
eBookBoy
Jul 09, 2011 | Apple iPhone Smartphone
My galaxy tab screen has blanked out and i cannot get it to do anything
option 1. Plugin in Power Cable Then Hold Volume down + Power button for 10 to 20 secs Your tab will Turn OFF. now turn it on using simple power button it shd work perfectly option 2. do one thing Turn Off Your Tablet
-> Hold Volume Button and Power button for 3 to 5 Secs -> You will see a screen with android and triangle with exclamation mark -> you will also see 4 lines of writing in blue. -> use volume buttons to navigate to 3rd option, use home to select it ( warning this will erase your system data if need please take backup) (memory card is not affected) -> now navigate to 1st option saying " reboot to system" use home key to select it.
I hope this will fix things
Mar 31, 2011 | Samsung Galaxy Tab Tablet PC
Blank screen
Try this,
turn the unit off, then back on this time holding in the power button until it beeps, a diagnostic screen will come up.
you need to restore this back to the factory so you need to select that option.
After that if you having issue it will need repair I suggest the fols at www.videogamerepair.com simply the best.
Please do be considerate and leave a positive feedbanc and ratings for you free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 29, 2010 | Sony Playstation 3 (PS3) Console
When i turn on my ipod, there is just a blank white screen
Ooh, blanks WHITE screen normally means there is a hardware break, try putting it into recovery mode:
Hold the Power and Home buttons together for 10 seconds, release the power button and continue holding for another 5 seconds, then plug into iTunes and restore it.
If that doesn't work I hope you have warranty because it'll be a hardware error :(
Sorry I ccouldn't have better news!
Thomas
Aug 23, 2009 | Apple iPod touch
When i turn on iphone it freezes at apple logo
try to restore your iPhone.
When the iPhone is powered off, plug into your computer holding down the HOME button. Then restore your iphone.
This should fix it.
www.mobileease.co.uk
May 07, 2009 | Apple iPhone 3G
Sony Playstation 3 (PS3) Console Logo
98 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
