Question about Hayward SAND FILTER, PRO SERIES
Hayward d.e.pool filter lid stuck
Open
  • Hayward Master
  • 1,631 Answers
Open all air & drain valves, if multi-port valve - place in "Winter" mode. If push pull type valve place between positions. This will relieve any siphon & pressure in the filter tank. After clamp is removed, use a screwdriver or other "Firm" type of pry bar (2 or more would be better) and then begin to carefully pry it off or apart.
If this does not help. then there is another way to do this,
BUT IT IS NOT RECOMMENDED IF YOU ARE NOT GOING TO BE VERY AWARE OF THE POSSIBLE DANGER!!! IF THE PUMP ON OFF SWITCH IS NEAR THE FILTER - DO NOT TRY THIS!!!
At times the filter tends to weld themselves together and it is very difficult to remove (like what you posted - stuck lid) due to excess greases, Vaseline is the main culprit, never use Vaseline on orings - it makes them swell. Use a Silicone or Teflon based Lubricant! And the o-ring is swollen in most cases for these types of problems and need to be replaced.
Anyway, with filter valves back in filter, waste, or backwash mode, Air relief valves wide open & drain cap/plug removed from filter, and the clamp is off, Quickly and consecutively - turn pump on and then off, On and then off. The water pressure will pop the lid off the tank. As you can tell, this can be dangerous as the filter tank will become pressurized and if you leave the pump on for too long (more than a couple of seconds) that lid will fly off that tank at a high rate of velocity with very possible Dangerous circumstances.
STAY CLEAR IF ATTEMPTING THIS! AND DO NOT LEAVE PUMP ON FOR MORE THAN A SECOND AT A TIME.
Be very careful and good luck.
Posted on May 04, 2014
  • 10 Answers
SOURCE: Bought a new home with pool which has the Hayward
Need some more info on the Sand filter. I can help you out. With the rest. Is that the pic of the filter you have. If it is then its a top mount. Depending on the debri that comes into pool, you will back wash 1-2 times a week. After back washing you will turn to rinse and let it run for awhile (of course each time you turn the handle make sure the pump is OFF. Set, then turn on.) then back to filter.. Any Q's just hit me up buddy..
Posted on Mar 11, 2009
  • 4 Answers
SOURCE: d.e. earth pool filter returning dirt to pool
The flow tubes inside the filter canister are torn and letting dirt pass. The repair is simple and can be done by someone with a few hand tools. Download the manual for the filter here:www.haywardnet.com/products/Manuals/pdfs/manual9.pdf
You'll only need to replace the ones that are ripped, and the cost runs about $3 - $5 each. Search around on Google for a supplier or try a local pool dealer.
Posted on Jun 30, 2009
  • 279 Answers
SOURCE: Can't get my hayward filter lid off. It turns a
Sounds like it is stripped. Hope it is the cap and not the part the filter is in. If you are very careful you may get the top off by taking 2 items you can pry with. Either screwdrivers or something similar. Have another person help if there is room. Place one of the pry items under the edge of the cap and put a little upward pressure on it. Have another person do the same thing on the opposite side. Now, carefully start to work the top off. Allow yourself time and patience. It will probably turn with difficulty but keep going. I assume it is plastic and maybe when you take the top off you will cut some new threads. They may allow you to use the same top or not, good luck...Lee
Posted on Oct 08, 2009
thepool
  • 78 Answers
SOURCE: Hayward vari flo filtering system
Check to make sure the plumbing is in the correct inlet/outlet on the valve head. Sounds like it's plumbed backwards. Inlet is from the pump, out to pool...
Posted on Apr 22, 2010
jharwell668
  • 640 Answers
SOURCE: hooking up filter to pump and pool
This website contains a copy of the owners manual for the S180T pool filter. It should have all of the information that you need.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
It is in PDF format. let me know if you have any trouble opening it.
Posted on May 24, 2010
How to take off locking ring from top lid to replace on Hayward xstream filter sysyem,I need to take the locking ring complently off so I can replace locking ring
Hi Mark, The link below is a user manual for a hayward xstream filtration series, This is from that manual...
Depress safety latches (located on the underside of the locking ring handles) and unscrew locking ring in a counter-clockwise direction. Remove lid from filter body.
Hope this helps....CHEERS..
https://www.hayward-pool.com.au/pdf/manuals/XStream-CC2000.pdf
Mar 27, 2016 | Pool & Spa
Closed and opened shut off valve to strainer housing basket, no water in strainer, how do you know if shut off knob actually opened or just broke the knob?
if the basket fills with water once you open the strainer lid then the valve is opening properly. If you open the valve and the strainer lid but you see no water flowing in then you can believe that the valve is not opening and needs to be fixed or replaced.
May 20, 2015 | Hayward Pool Products Hayward Power Flo LX...
Pressure psi filter
Is there water flowing into the pool? If the flow is there it may only be that your gauge is stuck. If not make sure the pump pot (where the basket is by the motor) is full of water before starting. If the pump has water + is running + no psi showing + no water flow, then you likely have an impeller issue. The pump needs to be opened up to see if the impeller is clogged or broken.
May 29, 2013 | Hayward SAND FILTER, PRO SERIES
No suction from hayward large filter system.
Suction loss is due to one or more of the following;
  • Skimmer wier stuck in upright position
  • Water level too low
  • Clogged skimmer baskets
  • Obstruction in suction line(s)
  • Breech in suction line
  • Missing/ cracked/ dried out pump lid o-ring
  • Pump pot basket full of debris
  • Clogged impeller
  • Broken pump seal
These account for 99% of suction loss problems, it may require a bit of detective work to find the problem.
Mar 16, 2013 | Hayward 36 Sq Ft Pro Grid Vertical Grid De...
How do I get the lid off the Hayward EC50AC filter? I unclamped the bolt but lid did not loosen.
try turning it with the pump on, shut the pump off if it feels like it has started to come off ..i think you will find it's filter time..
Sep 02, 2011 | Hayward Ec50ac Aboveground De Swimming...
I have a hayward powerflo matrix (1 hp) pump and hayward perflex DE fitration system and I am not able to get the lid off of the filter basket I have taken it off(with a great deal of difficulty) and put a...
magic lube and new o-ring. now put just a small amount on the o-ring and a little on the treads of the lid, do not over tighten ! that's the trick, the lube makes the lid over tighten,so just hand tight, take a marker and mark the lid so you know the perfect spot ever time you put it back on where to stop
Mar 25, 2011 | Hayward Powerflo Matrix 1 - Hp Above...
We have a hayward xstream pool pump for our 18' above ground pool that my daughter got through make a wish last august. we cleaned the cartridge yesterday and when we replaced the cartridge it started...
Try taking the pool filters cartridge out and following these steps to make sure that it is installed properly.
1. Clean debris from bottom of filter tank.
2. Replace element evenly on the collector hub in bottom of the filter body.
3. Place lid evenly on filter body and turn Easy-Lok™ ring clockwise until the safety latches engage securely.
4. Close and secure drain plug (located at the base of filter body).
5. Open air relief valve (Turn lever to left).
6. Open valves (Optional suction & return valves).
7. Prime and start the pump.
8. Once air has escaped the filter and a steady stream of water is flowing from the air relief valve, close the air relief valve and note the pressure gauge reading.
Jul 15, 2010 | Hayward Pool Products Hayward Xstream...
I have Hayward earth filter for the pool along with a Pentair Mini Max 100 pool heater - first time starting both for the season and the filter motor is making a straining noise. For the few minutes its...
make sure all vents are clean check to see if there is anything stuck in impeller with pump off take straner basket out look at opening going back to filter is water filling the strainer basket
Jun 17, 2009 | Hayward 1.5 Hp Northstar High Performance...
In-g pool loss of pressure and bubbles from return line any ideas
If you notice bubbles in the water returning into the pool from the eyeball/discharge, or water in the strainer basket is visibly swirling (bubbles visible) odds are you need you replace the o-ring on the lid of the strainer basket in the front of the pump. This basket may also be clogged with debris, which also effect pressure. Could also be a cracked or warped strainer lid. Should be easy to see when you remove to check o-ring. Once you remove the strainer o-ring make sure you lube it with a good silcone based lube.
May 18, 2009 | Hayward Sand Filter System & Tank 21" 1...
Im having trouble opening the sring clamp on the hayward pool fil
once the ring is unthreaded it may need a good hard tug to open the filter lid.
Feb 01, 2009 | Hayward Easy Clear 40 Sq Ft Cartridge Pool...
Hayward SAND FILTER, PRO SERIES Logo
302 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
