Question about Vitapur Energy Star Bottom Load Water Dispenser - VWD1006BLP
Not sucking up water
New bottle fitted to the cooler, close door and pump kicks in for 20 seconds or so as if it's sucking up water then yellow flashing light comes on and there is no water at all in cooler, done a clean but still the same problem
I cleaned my water cooler with vinegar but the water still taste bad. What can i do ?
it it is a plumbed in unit running off utility water supply, there is a small ceramic water filter assembly that can be fitted into the water inlet side of the unit
because it is extremely fine it removes the contaminates that make the taste if that doesn't work you can fit in tandem a charcoal filter after that ceramic to guarantee perfectly clean tasteless water
add to the fact that every 12 months ( depending on volume usage) the ceramic filter can be removed and the contaminates scraped off the surface using a knife which regenerates the filter
if it is bottle feed then clean out the holding tank using bleach, wash thoroughly and allow water to run from both taps for a few minutes to remove all residue bleach , the fit new water bottle
spare bottles are subject to algae growth ( taste ) if stored in a well lit area so store spare bottles in a dark room ( closet , under bench etc )
Jul 12, 2016 | Greenway Vitapur Point-of-Use Water...
Plugs in but wont turn on
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric ...
www.amazon.com/Koldfront-Bottle-Stainless-Slim-Fit...
Amazon.com, Inc.
Rating: 3.7 - ‎42 reviews
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric Wine Cooler - Black/Stainless Steel ... Item model number, TWR121SS .... the fridge. so you hvae to take out a wine bottle to reach it an usually I would like the controls on the door and only turn in .... The door can be reversed which the description did not mention.
www.edgestar.com/Koldfront-12-Bottle-Stainless-Steel-Slim-Fit-Thermo...
Koldfront 12 Bottle Stainless Steel Slim-Fit Wine Cooler Primary Image ... steel, the Koldfront 12 Bottle Slim-Fit Thermoelectric Wine Cooler (TWR121SS) is ... cabinet and stainless steel accents ensure that this freestanding unit will look ... Power: 70 W/0.95 A .... Unfortunately, your browser does not support video elements.
www.walmart.com/.../Koldfront-12-Bottle-Stainless-Steel-Slim-F...
Walmart
$109.99 - ‎In stock
Jan 20, 2016 | Koldfront 12 Bottle Stainless Steel...
Water cooler runs for 20 sec and then stops says that bottler is empty. not pumping water?
either you faild to unpack it properly and left some thing in the dispenser area where the bottle drops in. It doesn`t pump water, it gavitys out of the bottle.
Apr 23, 2014 | Vitapur Energy Star Bottom Load Water...
the cap on the top of the water bottle at the elbow sucks air. Take off the plastic elbow and put a hose in place of the elbow clamp so no air and the water cool will pump water.
Mar 30, 2014 | Vitapur Energy Star Bottom Load Water...
Primo water cooler red light blinking
What do I do with my Primo water dispenser whenever the red light keeps flashing I have a full bottle of water in there but it just keeps flashing I can turn it off and turn it back on or I can push the button in the door and it'll go off within the next 20 minutes it will come back on and the water's cold and then the water goes to lukewarm
Nov 25, 2013 | Unknown Primo Deluxe Stainless Steel...
Aqua Pro RV Water System siphon kit, #27910 - i followed the instructions and installed the kit, valve right way, arrow pointing the right way. It does not suck the antifreeze out, it blows air or liquid...
The valve should be closed while siphoning from the antifreeze. This allows the RV pump to draw it from the jug instead of the holding tank.
You can not use city water or other pressure to move it.
If all else fails and you are using RV antifreeze imply place the antifreeze in the holding tank. turn the valve open and use the faucets normally until you get liquid out of them.
Come summer you can simply add 1/4 cup of non-phosphours bleach to every 5 gallons of water to clean and purify tour lines and tank again.
Oct 19, 2013 | AquaPRO AQUA PRO 27910 - Aqua Pro Siphon...
Condensation on wine bottles
door not sealing ! or seal around entrance for cold air is sucking in hot air with cold air to create condensation
Sep 03, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
I have a well water pump that will not get top pressure. Does it need to be bleed from the pump to the well?
how pressure will it build does the pump stey running or does the pressure switch kick out ? if u hear a click and pump stops u need to adjust pressure switch so it will go higher or get a new switch switches are rated like 20-50 20-60 what is ur switch rated for ? if the switch doesn't kick out and pump just keeps running and running u either have a bad pump or ur sucking air
Sep 28, 2009 | Plumbing
Air coming out of an adobeair portable evap cooler isnt cold
paula298,
A new unit will take a while for the pad to become wet and more efficient. Remember, there may be two switches: fan and water pump. The unit must be full of water and the pump ON to work correctly.
If the unit has a water pump only setting, run the pump without the fan for about 20 minutes. That will get the pads nice and wet and you should get a good result. A rule of thumb in the desert is 20 to 25 degrees of cooling compared to the ambient air.
Don't use a cooler in closed area. The cooler will simply act like a room humidifier. Use in an open garage or porch for the best result.
I hope that helps.
Ed Phillips ed@azalmanac.com
May 12, 2009 | AdobeAir Evaporative Cooler Direct Drive
True Refrigeration GDM-26 Compressor problem?
More than likely you need a new compressor. It sounds like it's trying to start and then trips on it's "Klixon" overload. Call a commercial refer guy (not somebodys brother in law that works on A/C, it's NOT the same!)
Jul 15, 2008 | True GDM-26 Refrigerator
Vitapur Energy Star Bottom Load Water Dispenser - VWD1006BLP Logo
60 people viewed this question
Top Vitapur Water Filters & Coolers Experts
John Tripp
John Tripp
Tom Chichester
Are you a Vitapur Water Filter and Cooler Expert? Answer questions, earn points and help others
