Question about Ipcw Chevrolet S10 / S-pu 1998 1999 2000 2001 2002 2003 2004 Head Lamps Projector Clear Chevy Only-1 Pair
The injectors wont fire on my 1998 chevy s10 zr2
The security light comes on when I try to start the truck, and gas goes to the injectors but they will not fire. and the fuel pump works fine
  • 1,162 Answers
Is it happening on all cylinders? Or just one? Have you removed the injector an inspected it. I have never heard of all going bad at once. It would be a good idea to look for open fuses. The main connector is connected properly, each one has good connection.have you changed something lately?
Posted on Mar 30, 2014
I have a 99 chevy s10 zr2 that will crank but wont start
Does it have spark at the spark plug's ?
Nov 06, 2017 | Cars & Trucks
Not getting any power to the injectors on my 1998 chevy s10
security is the problem.. are you using the same old key you always have ? using a cut key or another key will set this off..
Mar 30, 2014 | Chevrolet Cars & Trucks
did you crack the supply to the injection pump to see if you had fuel pressure if you don't have your pressure then go back to see if you have a electrical supply to the fuel pump are these new injectors may need to bleed them..
Mar 30, 2014 | Chevrolet 1988 Chevrolet S10/s15/sonoma...
Where is the security brain located on my 1998 chevy s10 zr2
if you are having problems that involve having to put fuel in (carb) and then the engine starts and run's fine then there is a problem with the either the starter settings in the ecu or you have a temp/maf sensor fault. if engine runs its not the immobilizer the immobilizer this would not let you start engine in any way cut power to the fuel pump and injectors and ecu start. try using a code reader on the engine and see if any codes are stured.
Mar 30, 2014 | Ipcw Chevrolet S10 / S-pu 1998 1999 2000...
I have a 1998 s10 chevy pu. 2.2. the security system has the fuel shut off. it wants to start right @ first then it just turns over. plenty of fire and i can smell fuel. what sensor is out u rekon? no chip...
if the security light is on, that means the system is failing and shutting the fuel off to the injectors. If it doesn't have a chip, it probably runs off the transponder in the plastic part of the key. This is very common on GM vehicles. Check out this link for info and opinions to fix this yourself. http://vatspasslockpasskeysecurityhelp.yolasite.com/
Jun 04, 2011 | 1998 Chevrolet S-10 Pickup
Ipcw Chevrolet S10 / S-pu 1998 1999 2000 2001 2002 2003 2004 Head Lamps Projector Clear Chevy Only-1 Pair Logo
108 people viewed this question
Top Ipcw Office Equipment & Supplies Experts
Robert McCall
Robert McCall
 Russ Hill
Russ Hill
Bill Boyd
Are you an Ipcw Office Equipment and Supply Expert? Answer questions, earn points and help others
