Question about GE Refrigerators
Clicking sounds when the compressor starts running, then stops. Also, it will make a bang type noise every hour or two.
It is a side by side with water and ice in the door
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Shannon ! The noises you are hearing are coming from the compressor and its starter. I believe that you will need a refrigeration technician or a good sparky to check it out. The compressor is trying to start but because either starter is stuffed ( cheap repair ) or compressor stuffed ( not so cheap repair ) it the gets saved by the internal overload. this overload will call down over a period of time and the compressor will try and start again. Destructive cycle! TURN IT OFF. & call a fridgy !
Posted on Apr 14, 2014
Sea Breeze
  • 4654 Answers
SOURCE: GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Refrigerator-Parts-Page-6901.cfm
Posted on Oct 25, 2007
the dr
  • 447 Answers
SOURCE: Side by side stopped working but clicling noises every second two.
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Posted on Dec 02, 2007
SOURCE: Clicking noise on GE GSH25SGRE SS
The main controlller board is bad and must be replaced.
Posted on Jan 10, 2008
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
aasc
  • 1606 Answers
SOURCE: GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Posted on Nov 20, 2009
Testimonial: "Thanks for the information on the main control board. I replaced it and its working great. I checked the warranty info but mine wasn't covered."
My fridge knocks when running
Your fridge's compressor motor is suspended inside the compressor housing on three or four springs. These springs are designed to hold the motor load in a vertical position. Transporting a fridge on it's side can stretch or break these springs which can cause a shudder stop condition (the fridge makes a shuddering banging noise everytime the compressor stops and sometimes when it starts).
It's a good idea to let a fridge sit for a bit anytime it is moved. Over night won't hurt but an 8-10 hours is more than enough time some say less.
the internet consensus seems to be that you should limit the amount of time the unit is not upright. And as stated above, leave it upright at least overnight before starting it. Apparently damage can arise from mixing of lubricant and coolant, so damage is more likely in an older unit with worn seals.
Apr 11, 2015 | Hotpoint HSS25GFP Side by Side...
Right before the refrigerator starts running, the unit vibrates, makes a clicking noise, and then a series of loud banging noises that sound like hitting a ping pong ball against a table. Then it gets...
This is just a WAG but it doesn't sound like a compressor problem to me. The clicking could be the start relay, which could be a combination of either the start relay or start capacitor.
The vibration and banging is probably the shock mounts that the compressor are mounted to the cabinet frame with. Although rare, if the screws come loose the compressor will slowly destroy the rubber grommet shock mounts. If you are missing even one grommet (need four) then it will vibrate and rattle. If two screws are loose then it will allow it to vibrate and rattle also.
All bets are off if the compressor is very hot to the touch! Then it probably is the compressor.
Jul 10, 2011 | Whirlpool ED2SHAXM Side by Side...
Hiya,i have a hotpoint fridge freezer ffa91 and the fridge is no longer getting cold.The compressor seems is hot but cant hear the normal noises coming from the fridge.The digital display shows an arrow...
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
try this
Mar 12, 2011 | Hotpoint Refrigerators
Nothing running in refrigerator. Unplugged unit for 2 hours then pllugged back in. unit ran for about 30 seconds then stopped again
4. Wait one hour.
try this
Mar 10, 2011 | Amana Refrigerators
FRIDGE AND FREEZER DO NOT COOL. FAN AND COMPRESSOR ARE RUNNING AND AIR IS FLOWING THREW THE VENTS BUT A WIERD NOISE APPEARS EVERY 2-3 MINUTES LIKE THE COMPRESSOR WANTS TO START BUT IS RUNNING STILL. ...
4. Wait one hour.
also are the coils clean?
Feb 26, 2011 | Maytag MBB1956GES Bottom Freezer...
MSD2454GRW. Clicking noise for about 10 seconds then shuts off. Freezer is thawing. Fridge "appears" to be cooling fine...not sure. Help...don't have the $$ to hire someone.
4. Wait one hour.
try this and let me know if it helps.
Feb 22, 2011 | Maytag MSD2454G Side by Side Refrigerator
It appears the freezer is not keeping the food cold enough and there is an occasional clicking noise underneath where I'm assuming the compressor is. Could this be some type of relay problem? This is a...
The clicking sound your hearing is the compressor trying to start but is not completing the start cycle or achieving run speed so the KliXon thermal overload is tripping trying to protect the compressor.
This can be caused by a bad start relay / Klixon,
A bad run capacitor or...
The bad news a bad compressor.
Letting it just click click click is not a good thing and will cause more damage. Unplug the unit for about 30 mins and then plug it in see if it starts normally.
There can be yet other issues like a defrosting timer contact problem that got weak / hot and isn't allowing enough amperage through to start the compressor.
Jan 28, 2010 | Kenmore 57029 Side by Side Refrigerator
2002 Dodge Ram 1500 A/C Blows Hot When Stopped and Clicking Sound
if the compressor is turning on and and off R1-34 level is low recharge system.
Aug 24, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Banging Noise
If is sounds like a hollow metallic sound then the compressor is likely out of position os the unit has been mis-treated. if this is the case then the compressor will have to be changed (should be a 5 or 10 year wty) If is i a light sounding tap then it is likely to be some of the copper tubing is hitting the chassis. There is a metal or plastic cover that runs along the back lower part of the fridge, remove this and gently rock the fridge to see if you can re-create the noise.
Apr 25, 2007 | Jenn-Air JCD2295HES Side by Side...
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
