Question about Korg Cx3 61Key Modeled Combo Organ
Korg cx3 (non-vintage) - The upper drawbar 1 and 2 buttons stopped working. Every other button works perfecting fine (I have not tried the lower drawbar buttons since I don't have a separate keyboard
I bought this product used a few months ago and I've had no problems with it since then. Can't figure out why two buttons would go bad, and buttons that aren't even regularly used since I generally keep it on the upper drawbar 1 setting for the entirety of my gigs.
2 Suggested Answers
  • 5603 Answers
SOURCE: I have a1980 Korg CX3. Last night at the gig It
This is likely a power supply problem. It is important that all interconnected equipment be powered by the same receptacle OR source or isolation such as DI's be used for system safety.
Posted on Jan 30, 2011
Old korg cx-3 intonation off with standard piano tune
if it's the old analog version, there should be a tuning knob in the group of controls on the left hand side by the drawbars.
Dec 27, 2016 | Korg Music
Won't load to default
Hi Lloyd,
The introduction in the manual warns that you should ask your dealer or store in order to change the batteries. I'd suggest seeing if they have any advice.
That said, how are you trying to default the settings? I've copied the two ways below. Maybe try whichever one you haven't yet. I hope this helps.
Manual: http://hammondorganco.com/wp-content/uploads/2011/03/XK-1manual.pdf
Default #1:
In this mode, you can return entirely or partially to the default setting as set at the factory.
To locate this mode:
Touch the [MENU/EXIT] button for the MENU display, select PAGE D by the [PAGE] button, and then touch the [3] DEFAULT button. To initialize each parameter, touch the button and then [4] OK
1. ADJUST PRESET
  • Initializes the content of the Preset Key [B].
  • If the Drawbar Control mode is at "UPPER A#/B", the content of [A#] is also initialized.
  • If you do this operation before you start a new setting, you can start from the factory
  • setting.
2. PRESET
  • Initializes the content of all Combination Presets.
3. GLOBAL
  • Initializes the Global Parameters such as Master tune or assignment of the Foot Switch.
4. LESLIE
  • Initializes the content of all Cabinets.
5. ALL
  • Initializes all parameters of this keyboard.
  • If anything caused an unstable trouble on this keyboard system, the trouble would be cleared.
Default #2
Please perform the following steps to reset the XK-1 to the initial default setting.
1. Switch off the power of the XK-1.
2. Hold the [REC/JUMP] Button, and switch on the power.
3. Continue to hold down / Keep pressing the [REC/JUMP] Button until "Loading Default..." appears on the Display.
4. After 5 seconds if everything is in order, PLAY Mode appears on the Display. (Completed)
Dec 20, 2013 | Hammond XK1 Pro Drawbar Organ
Can a Korg CX3 Organ 61 keys be compatible with the RolandFantom XR module?
Hi, from what I can tell you cound plug your CX3 into the synth module with a 1/4 inch patch cable and run the audio through it, however I think you will be quite limited in what you can do to modify your sound.
Where the synth really works well is when you feed it digital input data. For you to be able to do that your CX3 would need midi outputs and while I don't have one, I looked it up and can see that the CX3 is too old and does not have midi capability.
Midi (musical instrument digital interface) is a common language that allows musical devices such as your fantom to communicate with other devices. A keyboard with midi running into a synth is in essence just a control surface, a way for you to input data into your synth module, it is making no sound itself, but rather outputting digital data into your synth which in turn generates the sounds you want it to. There are allot of keyboards out there that are only for this purpose and are simply controllers. For example, M-Audio Oxygen 61 - 61-Key USB MIDI Controller. I'm afraid your CX3 is just too old to be able to do this, however, I imagine some of the sounds that thing makes are very vintage and good, and modern synthesizers often times just cant reproduce that (though they are getting batter all the time). Hope that helps :)
Dec 20, 2013 | Music
When I turn on my xk1, I get no sound, no response from any buttons, keys, drawbars or knobs. I have tried the factory reset and it doesn't work either. What else can I do before I return it to the...
Take it to the store and have them test it... don't be surprised if there is a simple thing that has been overlooked. If it doesn't worked there, it needs to go in for servicing so that is the logical course to follow anyway.
Aug 06, 2011 | Hammond XK1 Pro Drawbar Organ
My Korg CX-3 MIDI configuration tests for upgrading to Version 2 have failed numerous times. However, I am confident that it is not my MIDI interface. All Global settings and parameters seem to be...
If this is a flash upgrade to the unit be VERY careful as a failed upload can leave unit dead. They usually have pretty tight checks to prevent an error from killing the unit during the upload. For certain music products I have found that I had to upload an in between version first that was available before uploading the latest current version.
Jul 29, 2011 | Korg Cx3 61Key Modeled Combo Organ
How to perform a factory reset?
1. Power-off the PS60.
2. While holding down the four PERFORMANCE buttons and the OCTAVE DOWN button, power- on the PS60. The PS60 will be initialized, and the factory-set data will be written into internal memory. The display will indicate "Initializing..." while data is being written. Never turn off the power while this indication is shown.
Manual available here:
http://www.korg.co.uk/downloads/ps60/docs/PS60_OM_E1.pdf
Jun 24, 2011 | Korg PS60 61 Portable Performance...
How can I tune mas bass guitar to A=444hz with a KORG GA-40 ???
You turn it on and there are the two buttons under the power on button. These ratchet the base frequency up and down. In the upper left corner of the display you will see what A is currently tuned to in tiny characters.
Mar 22, 2011 | Korg Ga40 Guitar Bass Tuner W Batteries
My Korg CX-3 Combo Organ turns on, but when it's plugged in to an amplifier, I don't hear anything and it doesn't generate any sounds except for a clicking noise when hitting the key. I hope you can help...
From the user manual troubleshooting:
No sound
• Are the other devices or headphones connected
correctly?
Check the connections. ........................................ (see p.6)
• Is the power of your amp or mixer turned on?
• Is the [MASTER LEVEL] knob raised?
• Is the Global mode Group 4 "MIDI Local" parameter
turned On?
Check the setting of this parameter.
• Are the bars of Drawbar 1 or 2 pulled out?
Pull out some of the bars.
Also check out this site and scroll down and do the "Factory reset" by holding down the buttons they say... AND please note that you have to hold them for a while during this.
Mar 08, 2011 | Korg Cx3 61Key Modeled Combo Organ
I have a1980 Korg CX3. Last night at the gig It started to make noice that sounded like all the keys were being pushed down at once. It did npot matter if I was in a preset or using the drawbars. Any...
Jan 30, 2011 | Korg Cx3 61Key Modeled Combo Organ
CX3 Organ V2 firmware: The buttons seem to lock up, but not completely. They work after many presses. If I power off then on again, it's cured, temporarily. What's going on? software/ hardware? thanks,...
Do not get confused by weird things that happen when button contacts get dirty... SOMETIMES powering down and back up will create enough of a transient that it will temporarily make defective contacts work. Many an hour has been wasted with this phenomenon. If you can get to one of these failing buttons carefull short the pins of the switch while it is in failed mode and see if it exits the problem. If the buttons HAPPEN to be the conductive rubber type, then clean them with 99% isoprophyl alcohol and Q Tips. Clean the black rubber pill and the circuit board traces they contact.
Jan 28, 2011 | Korg Cx3 61Key Modeled Combo Organ
Korg Cx3 61Key Modeled Combo Organ Logo
27 people viewed this question
Top Korg Music Experts
Vito Vacirca Jr.
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Korg Music Expert? Answer questions, earn points and help others
