Question about Peg Perego Triplette Stroller
Does anyone know how to fold/collapse a triple stroller for easy storage? Does each seat have to be removed before you can fold the frame? Is there a user manual that I can review? Any help would be much appreciated. Thanks
  • 127 Answers
You have to remove each seat before folding it,you can call perego at 1800-671-1701 they will send you one for free or go to www.pegperego.com to get one.
Posted on Jun 16, 2009
Trouble opening and collapsing a quinny stroller
The Quinny Buzz can only be folded/unfolded with the seat in the most upright position facing forward. If this is the case and it won't unfold, remove the seat first by pushing down the two grey release buttons either side of the frame. It may be the case that the gas strut (automatic close/opening mechanism) is seized and will need replacing. This can only be done by Dorel UK 01842 763 281 as it is a pressurised unit. Hope this helps
May 28, 2010 | Quinny Buzz Jogger
Design Ditto - Manhattan Twin Seat Jogger Stroller: I have a older model of a Dreamer Design double jo...
The older models unhook at the front wheel. Right behind where the wheel connects is a black peice that you can release and the T frame will separate. Just push the top of the stroller back and then you can also fold it onto itself. You may need to un-velco the storage basket front tabs to release the frame. Feel free to contact me directly if you need further assistance.
May 16, 2010 | Dreamer Design Ditto Manhattan Twin Seat...
What is the best position for the seat back to be in when closing the Chicco Cortina stroller? When I collapse the stroller using the handle, there is some resistance before it locks into the closed...
The seat back position isn't important. What IS important is the position of the stroller handle (not the one used to collapse the stroller).
If the handle is left up while collapsing, the stroller should fold easily. If the handle is down, it can get in the way and cause the process to be more difficult.
I have to take most of the removeable parts off of mine in order to fit in in the back of my coupe.
Oct 14, 2009 | Chicco Baby Gear
How to fold the Graco Stroller 6001BCL1
Take the carrier off by raising the handle and then lifting the handle with one hand as you pull the red handle on the back of the carrier with the other hand. Set the carrier aside and stand behind the stroller. There should be 2 matching plastic 'things' on either side of the stroller, just under the rubber handle. Put your thumbs on the rubber handle and your first 2 fingers on those plastic pieces. Pull those plastic pieces up with your 2 fingers and the stroller will collapse. I hope this helps!
Sep 26, 2009 | Graco Baby Gear
How to fold stroller
i have both the double and single dreamer design stroller and on both - there is a black pull thingie ... if you put your hands on the handbar and then follow down the frame (along the back side of the seat). You will feel it - as it is kinda hard to see. Once you pull this on both sides, push down on the handbar - towards the ground. The stroller will then fold down and in half.
Aug 18, 2009 | Dreamer Design Ditto Manhattan Twin Seat...
Packing Stokke Travel Bag with the Chassis - bassinet
Hope I can help you out with this...for me it was quite easy once you get the hang of how to fold the stroller system at the smallest possible fold. You have to have the seat at the lowest position, next you fold the front wheels inward so that it is flat against the stroller, then fold the handle all the down toward the stroller frame so that it is flat. NOW you have the stroller at the smallest fold. Remove the SEAT from the Stroller frame and place it on top of the stroller (FYI - the adjustable foot plate should still be attached to the SEAT and it fits directly ontop of the 2 metal pieces that protrude from the stroller that you normally instert the seat into)
NOW it will fit inside the Stokke Travel Bag.
Apr 06, 2009 | Stokke Xplory Stroller
I purchased a quinny zapp and am wanting to take of the pushchair material in order to fix the maxi cosi cabrio fix car seat to the frame can u please tell me how.
Removing Seat
It is necessary to remove
the seat from the frame
when preparing to use
the car seat adapters.
Unzip seat zipper at the
back of the seat.
To unclip the seat from
the frame,
fold stroller enough to
relieve the tension on the clips.
To view instruction manual with pictures for further assistance. Go to the Quinny page below and download the manual.
http://www.quinny.com/quinny/productdetail.aspx?id=29
Good Luck! from Moms Just Know
Oct 23, 2008 | Quinny ZAPP Stroller
Cant fold my instep safari tt stroller
One-hand fold is not as quick and easy as it's name suggests. This model requires reclining seat all the way first, then step on the safety release lever (about shin-high) located above one of the rear wheel axles. While holding down safety release lever with your foot, then squeeze the one hand fold mechanism located near the parent console and the stroller will collapse. There is a lock bar/plate to hold stroller in place. It will not stand on its own in this position, but with the foot brake activated, will lean against something and stay in place.
Oct 11, 2008 | InSTEP Safari TT Single AR165 Jogger
Closing it
You need to push the red buttons underneath the seat.  This releases the seat's connection on the back bar.  Next sort of wiggle the seat until you can push it forward and then separate the seat from the frame. Then to collapse the frame, look for the piece half way down the frame that looks like it can slide. Slide the pieces up (on both sides of the frame) until you can fold the frame in half.  It is still pretty bulky.  I dont think the seat part collapses any further.
Hope it helps.
Jul 11, 2008 | Zooper Boogie Jogger
Peg Perego Triplette Stroller Logo
294 people viewed this question
Top Peg Perego Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Are you a Peg Perego Baby Gear Expert? Answer questions, earn points and help others
