Question about Insignia Digital-to-Analog Converter for Analog TVs
I get no stations on my tv
I get no stations on my tv . my converter box is hooked up but I receive no signal.
  • 2,071 Answers
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Posted on Jun 15, 2009
Trying to hook up converter box to Westinghouse flat screen the converter is magnavox sdtv. I get autoscan but no channels are found. I do not have an antennae. Do I need one? Help!
If ur tv a LCD tv it is a digital tv.U do not require a Digital converter box to get the new DTV free air signal broadcasting tv channels stations.But u do require a good digital antenna for it to recieve a long an strong signals to recieve a DTV free air broadcasting tv channels stations.
Dec 07, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
How do I record a tv program with a Sharp A400 VCR? Videos will play on the tv, but I was not able to get it to record. Thanks.
Your VCR is no longer capable of recording "off air" tv signals. All tv stations are now broadcasting in digital format, your VCR is analog only. You can however get a digital converter box that will receive "off air" digital signals and convert them for recording on your VCR. CLICKING HERE will give you all the information you need to hook up the converter box... Good Luck!
Nov 10, 2009 | Sharp VC-A410U VCR
I cannnot receive digital stations.
your tv must be dtv ready or u will need a converter box or cable
Aug 05, 2009 | Sharp Televison & Video
Toshiba Color TV CF306 - Can it receive digital, with converter
The short answer is yes. The method is to set the TV to receive either channel 3 or 4. The converter will receive the digital broadcasts and "re-broadcast" them on either 3 or 4 analog for the TV to receive.
Let me know if you need anything else.
Dan
Mar 14, 2009 | Toshiba Televison & Video
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Feb 27, 2009 | RCA Televison & Video
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
No channels downloaded
The antenna must be hooked up to the converter box. The better the antenna, the better your reception will be.
Not everyone in the country will be in range of digital signals. Digital signals have a shorter range than analog signals do right now. It is possible (but unlikely) that you are not currently in range of any digital signals.
So make sure you are set up like this - Antenna--converter box--Television. Then scan for channels. You should still pick up any analog signals while the box is hooked up, you will just view them the same way you do now, by changing the TV station rather than the converter box station.
Dec 06, 2008 | Insignia Digital-to-Analog Converter for...
Analog/Digital
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Nov 04, 2008 | Sansui HDLCD-2600 26 in. LCD Television
DTV converter Box and Zenith system 3
I have the same problem.... On the back of the tv, there are three coax spots. One is for Cable, one is antenna decoder, and another is a loop. I have had zero luck getting any of those to receive the signal. Instead i have ran my digital signal to a vcr, then ran rca cables from it to my tv. I then put my tv in vcr mode, or aux depending on where you hooked it up. You can watch tv through your vcr this way.
Oct 10, 2008 | Zenith C27A24T 27" TV
Greetings kathy76turne,
In February 2009 you will be unable to receive ANY analog television signals therefore the digital converter box will be a necessity to receive any over the air broadcasts.
I am unable to answer the question about the mini van's electrical capability, however you might find the following link handy to get more information.
http://www.bestbuy.com/site/olspage.jsp?id=pcmcat120600050013&type=category
Thank you!
Dorothy
Go Ahead. Use Us.
Jun 09, 2008 | Mitsubishi HD-6000 DTV Receiver / Video...
Insignia Digital-to-Analog Converter for Analog TVs Logo
791 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
