Question about Norcent Technologies Televison & Video
Channel blocked do not have code
    Top Expert:
  • Norcent Tech... Master
  • 75,283 Answers
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Posted on Mar 30, 2014
How do you un-block the channels
Once you've ran the auto programming and the channels you want are blocked, it's possible that someone put in a parental block on certain channels. If this is the case, only the person that put the block can tare it off because they know the code.
Mar 23, 2015 | Televison & Video
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
I have a toshiba standard tv 27A33. it has one
This television uses a feature called a V-Chip which allows parental control and consequently blocks channels of your choice. This set is approximately 7 years old and the owners manual is no longer available on line. You can over ride any blocked channel by entering the menu, select parental controls and enter the "secret" code. How one channel got blocked is a mystery. I suspect someone was exploring it's features when they accidentally blocked a channel. Normally the system control works flawlessly and if you have no other symptoms you need to reset that channel. That info is in the owners manual that came with your set.
Mar 30, 2010 | Toshiba 27A33 27" TV
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I need a default code to unlock the channel block
The Factory default is 0000 (4 ZERO's)
Good Luck!
Oct 10, 2009 | Televison & Video
Child Lock is on and I am second owner of tv with no code
This function will block out the picture and sound of the selected channel or video input.
It can also be used to keep the TV from being viewed for a scheduled time period that you set.
The code to enter the Locks feature is a four digit secret code number. The factory preset code is 0000.
Use the number buttons to select access code.
Use CURSOR G or H to highlight function and then press the SELECT button.
To change the access code number, select Change Access Code. Enter a new four digit key number you prefer.
Select CHANGE ACCESS CODE to change factory preset code (0000) to your preference.
When ENGAGE LOCK is selected, SET CHANNEL LOCK, SET INPUT LOCK, and SET FRONT PANEL LOCK can be set individually.
When SET CHANNEL LOCK is turned on, the picture and sound for the chosen channel will be blocked out.
When SET INPUT LOCK is turned on, the picture and sound for all video inputs and the picture and sound for channels 3, 4 will be
blocked out.
When FRONT PANEL LOCK is turned on, all buttons on the Front Panel will be deactivated, except the Power button.
When TV TIME LOCK is turned on (r TIME LOCK) you can set the BEGIN and END times (CURSOR E) and the TV
cannot be viewed during that time period (Set clock first). Use CURSOR G or H to highlight ONCE (TV will time out one time
only), DAILY (TV will time out every day), WEEKLY - SUN~WEEKLY - MON (TV will time out one time a week) or OFF (to disable
this function).
When MOVIE RATINGS is selected, you can block various types of movies and video tapes based on motion picture ratings. Picturein-
Picture will also be blocked automatically (see page 45).
When TV RATINGS is selected, various types of television programming based on a parental guide ratings will be blocked.
Picture-in-Picture will also be blocked automatically
If you forget your secret code, use the factory code 7777 to erase your key number. This will reset the secret code number back to the
factory preset 0000.
Press EXIT to quit the menu.
Dec 07, 2008 | Hitachi 57F500 57" Rear Projection...
Channel block
#1 power off #2 hold the menu butin down and tren power on for 40 sen. #3 tren power off #4 do it 2times #5 tren power no all ok
it worked for me good luck
Aug 18, 2008 | Emerson DTE315 TV
Locked tv
The Digital Channels are Blocked and Some of the Annalog Channels are Blocked that you can't access some channels and how do you unblock the channels by getting rid of the Code for Parental control?How Do you get rid of the Parental Code to acess all Channels .
May 27, 2008 | Apex Digital GT2011S 20" TV
Smartlock code
I used the following that I found on a site that compiles v-chip reset solutions:
Philips and Magnavox:
Philips sets use a four digit code to control the v-chip. The override code
for Philip sets is 0711, although it may say "Incorrect code" the first time
to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To
use it hit the MENU key to get to the menus. Go up or down until you reach
AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow"
key on the remote. Enter the override code, and enter it a second time if it
says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right
arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to
MASTER DISABLE and press the "right arrow" key so that it says "MASTER
DISABLE ON". The v-chip is now reset.
Apr 03, 2008 | Televison & Video
Televison & Video Logo
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
