Question about KitchenAid KDRS505XSS
KDRS505XSS freestanding double oven range has wiring faults and will not heat. How do we fix them?
We ran the self diagnostic tests. faults are with the element wiring, the upper and lower oven broilers, and elements. we have checked, and there are no loose wires.
  • KitchenAid Master
  • 842 Answers
I would have this unit checked because the electronic control is 300.00 for this unit. I ran into this and the control was the fault not the wiring to the elements, but I can't tell you to change this because I won't miss lead you like that. Several tests need to be done to rule out a shorted element before the replacement of the control unit p#W10365424, most electronics are not returnable due to there nature of people swopping them and returning them. I think a service call is needed to be sure of the issue you have.
Good Luck
Posted on Apr 02, 2014
Popping sound in oven when baking
Is something boiling over? Or could be something loose depending on the frequency of the "pop". It could be a fuel control problem. I recommend your gas company service be called. Or an appliance repairman.
Mar 16, 2015 | Frigidaire FGGF304DLW Gallery 30"...
Amana Stove just stopped working
Could be the fuse in the back turn off the power and trace the wiring with a multimeter, when you stop getting continuity there is the fuse.
Good luck Ray
Apr 15, 2014 | Amana 30" Self Cleaning Electric Range...
Whirlpool self-cleaning feature not available
Because the features mention utilize 220 VAC power, I do not advise you attempt any corrections. Very dangerous; unless you are a trained technician. If the unit is in Warranty, get the Whirlpool folks out to you home ASAP.
Dec 19, 2013 | Whirlpool Gold GGE388LX Double Oven...
Need a wiring diagram
Most appliances have a wiring diagram inside them. (I know washers, dryers, and fridges do). Have you checked to see if there is one? Usually they are printed on green paper and folded up. Obviously for an oven, they'd have to be away from the heat source. Maybe near the control panel on the back, or if there is a storage drawer on the bottom of the stove, it might be in there, or taped to the back of the drawer.
Apr 08, 2013 | Maytag MER7662WQ - 30"Self-Cleaning...
F4 error
The F4 error means that the oven temperature sensor is giving an open signal. Probably the oven temperature sensor needs to be replaced. However, sometimes, the wiring harness between the sensor and the control unit has a fault or the control unit (computer) is bad.
I hope this helps.
Mar 16, 2013 | Amana 30" Self Cleaning Electric Range...
Whirlpool Double Oven Range
Recycle the circuit breaker for the oven several times. If you haven't used the oven much the contacts may be corroded. The display is off a 110Vac circuit but the ovens use 220Vac, The circuit breaker should be 2 switches "ganged" together as one. Both should be cycled...
Dec 25, 2012 | Whirlpool GGE388LXB - Black GoldR Double...
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
KitchenAid KDRS505XSS Logo
106 people viewed this question
Top KitchenAid Cooktops Experts
Dale Copeland
Dale Copeland
davenpdx
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
