Question about LG Washing Machines
Lg intellowasher 8026c not draining
Machine not draining, no blockage or obstruction
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: LG Intellowasher 7kg WD-8026C. This
Hi.
As you probably know, OE means that the machine does not drain.
To open the door you need to empty water first.
To empty water:
  1. Disconnect power.
  2. Prepare a container to collect water and clothes to dry.
  3. Open the drain filter access door (see picture).
  4. Rotate drain cap.
  5. Collect water.
  6. Remove any blockage from filter.
  7. Re-apply power, wait thirty more minutes or so if door still does not open.
Here the filter access:
If 0E comes back, check the drain hose at the back of the machine.
Regards.
Ginko
Posted on May 31, 2011
LG WT5101HW - Machine won't turn on. Just plays the tune softly when pressing power button. Also, machine have not been draining properly lately. Turns off by itself mid-drain with DR error code.
DR is a drain error. Have a look to see if the drain filter is blocked (if fitted) or if there is an obstruction or blockage in the pump or drain hose. If it cant pump out, the machine will stop during the cycle.
Mar 29, 2016 | LG Washing Machines
LG Intellowasher WD-8026C having problems with the door latch, I keep getting an error message. Latch appears not to be connecting and locking the door. to start the machine.
The DE error or fault code indicates that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly
Jan 31, 2015 | LG Washing Machines
Washing machine won't drain
Check the condition of the drain pump, replace if necessary as one cannot repair them.
Aug 30, 2014 | LG Washing Machines
LG Intellowasher (Model WD-1023C)
The water pump can be blocked and thus stop the machine from finishing the wash cycle. In front on the bottom there is as hatch that can be opened with a flat screwdriver, the small black rubber pipe can be used to first drain all the water before the opening the filter. Small objects such as coins coluld be found in here, blocking the pump. Clean the pump by removing these, optionally blowing into the outlet (yuck!), to dislodge anything. If that does not help to fix the problem, you can clean that actual water pump, but this requires you to use a screwdriver to remove the pump.
Tilt the machine on its side, the pump is attached with 3 self-tapping screws. (if you can't figure out what the pump is you should probably let a technician do this). The pump has 2 parts to it, take it apart carefully and clean out all the dirt that has accumulated in there. Plastic friendly, waterproof grease can be applied to the pump spindle and bearing if available.
If the problem still persists a new pump is available from LG at a reasonable cost.
Jul 30, 2010 | LG Washing Machines
My LG Intellowasher does not finish programme.
Switch off and restart. Or circuit problem of the micro controller.
Mar 29, 2010 | Washing Machines
Blows main fuse under load when going to spin
Sounds like it's scraping against your heater element.Remove back panel then remove heater element(two prongs with nut in centre)you will be able to see signs of damage if so that will have to be replaced. £20 - £30.00p. Your either overloading your machine or your bearings are have gone, to check bearings pull inner drum while holding outer drum if get movement and knocking they will also need replacing.
May 19, 2009 | LG Washing Machines
Front loader noisey
Hi.
If you remove the belt and turn drum by hand, it should revolve freely and without any noise.
If it is noisy or feels stiff, then you proabably have main drum bearing failure.
Could be expensive to put right
Nov 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
LG Intellowasher cannot complete spin cycle.
Unplug power cable, remove top cover and inner panel, locate water level sensor on the right with 3 wires and a thin tube, remove the tube and puff into it until you hear water bubbling. This will clear any blockage caused by suds build up. Replace tube, covers and plug back in. It should complete cycles now.
Sep 11, 2008 | Washing Machines
OE displays and washer will not drain
you have to check the pump,remove the hoses from the pump first and check for any blockage could be lint or a sock,if there is no blockage and the pump spins its the propellar for the pump is worn and you have to replace the pump
Jul 08, 2008 | Washing Machines
Washing Machines Logo
16 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
