Question about GE Spacemaker JVM1640SJ Microwave Oven
Does not heat
Will not cook or heat
    Top Expert:
  • GE Master
  • 34,711 Answers
Failure to heat can be caused by an open fuse, a faulty door interlock, a failed controller, or a failed magnetron.
Posted on Mar 30, 2014
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
Oct 16, 2012 | Sharp R-1510 Microwave Oven
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
My JVM1653 stopped cooking, The turntable turns
your magnetron might be out. its what heats
Feb 13, 2010 | GE JVM1653 Microwave Oven
Does not cook even . put 2 items in cooker one well done other one half,
were both items the same density? Was one maybe thawed more that the other? A microwave cooks by rapidly heating the water molecules within the product that you are heating. If you heat two of the same product, it should cook them both evenly, however say you put in a frozen hamburger and a thawed hamburger, the frozen one will only begin to defrost while the thawed one will actually cook
Feb 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave runs but does not heat or cook food
If a Goldstar, LG or Zenith MV1610 or MV1608 is running but not seeming to heat a load placed in center of turntable, its probably because the "stirrer" intended to spread microwaves generated by the magnetron around the cook chamber is stuck so that most all the heating is directed toward the back and top rather than the center of the cook chamber. This usually occurs after cooking for longer than a minute with no load in the cook chamber - as when a model w/o a timer (such as a MV1608) is intentionally operated in cook mode to serve as a kitchen timer, or when a model with a timer function (such a MV1610) is accidentally operated for longer than a minute w/o any load. Before assuming the magnetron (usually warranted for 5, 8 or even 10 years) or other high voltage component such as diode or capacitor needs to be replaced, try “cooking” a 16 oz pyrex cup of water at full power on the outer edge of the turntable for 2-3 minutes - which usually reactivates the "stirrer" and restores normal cooking function.
Jan 18, 2010 | LG Microwave Ovens
Weak heat ???
Is the cooking level set to high? most microwaves you can adjust the cooking level. 10 is usually the highest. When you turn it on, there is usually an icon or indicator light that tells you you are cooking on high somewhere on the display
Dec 28, 2009 | Microwave Ovens
Express cook doesn't heat. Time cook seems to work at least sometimes
Oct 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GH7145XFB-1 not heating properly
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 16, 2007 | Whirlpool GH7145XF Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
13 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
