Question about Drills
Manual How do you attach this permanently to a workbench or table?
  • kakima Mar 30, 2014
    What make and model?
  • 3,904 Answers
There should be holes about 9/16 of an inch on the base. I would say 4 to 6 of them. Set it on the bench where you want to mount it, Mark the holes, drill them out and then bolt and nut it down. Make sure you have a solid mounting surface. I would consider putting a mounting plate on the bottom side of the counter that you mount this too.
Posted on Mar 30, 2014
I have Guardian Power BDM58-5SP drill press that needs a table. Any idea where I can find one 11-22 round one with a 44mm post?
ry the manufacturer spares department
try reputable tool supply shops
try e-bay
try your local dump charity shop as there are many units disposed off that have tables attached
Oct 11, 2016 | Drills
Installing the rear outfeed support tubes
About 11,900 results (0.88 seconds) Search Results
    Bosch TS1002 Table Saw Rear Outfeed Support ... - YouTube
    ? 3:59
    https://www.youtube.com/watch?v=d5B4227hBUk
    Jun 18, 2012 - Uploaded by Isabel De Los Rios
    Bosch TS1002 extends 18-inches and stores flush to table. It extends the working depth of Bosch 4000 10 ...
    Tool Free Way of Attaching the Out-Feed Table. - Angelfire
    www.angelfire.com/.../funwithtubes/.../ss_outfeed_table_mounting.html
    The outfeed table which is available from Shop Smith works very well once ... The bottom part supports the far end of the table while the near end attaches to the ... the screws can be installed through the brackets on the outfeed table to hold it in ....Insert one of the extension tubes in the rear rip fence rail, adjust it so it sticks ...
    Craftsman 137.415030 Operator's Manual - ManualsLib
    www.manualslib.com > ... > Saw > 137.415030 > Operator's manual
    be installed underneath the rear. outfeed support tubes (2). Fig. L. 3. Insert the rear outfeed support. tubes (2) into the two holes in the. rear of the saw table, and ...
Feb 08, 2016 | Saws
HID Fargo dct4500 flipper problem
There is not a separate calibration routine specific to the flipper table or module. You can download the Fargo Workbench Utility directly from the manufacturer's website, and install it on your PC. It includes a printer information section that can calibrate sensors, film, etc., and also can send direct commands to the flipper to level itself ("home the flipper table"), as well as step it in either direction.
If you have an issue that is not addressed by these built-in calibrations and other tests, then your unit may need service from an authorized repair facility, like Safe-Card ID Services.
Feb 20, 2015 | Fargo Office Equipment & Supplies
My iron on patches keep coming off my clothing
I have never had success for permanent attachment with any iron on product. I have only relied on iron-on products to temporarily secure placement while I sew the edges of patches. There are industrial spray adhesives (3M) which i have used successfully on leather vests in area which I couldn't use the machine, but I will hand stitch the corners for a more permanent application. If you garment is washed often attach more permanently with needle and thread, small grommets, Velcro (which may also need to be sewn or magnets?
Feb 07, 2013 | Pellon 808 Craft Fuse Iron-on Craft...
How do you install a ridgid router to a craftsman router table?
Brenda, They are just saying that if the router is too big, it won't fit. The sub-base is the plastic, usually black, disc on the bottom of the router. This disc is about 6 inches in diameter and about 3/16 inches thick. It is usually held onto the base of the router with three screws. The base is the big aluminum piece about the size of half a loaf of bread that has the handles and into which the router main part (the motor) slides into. For most router tables, you mount a router base (with the sub-base removed) to the underside of the table with screws. The router table becomes a giant upside-down sub-base. If your base fits, and the screw holes line up, you are good to go. However, it is very helpful to have an extra router base (without handles) to leave permanently attached to your router table so that you can easily swap the router between the table and normal use. Good luck!
Jan 13, 2013 | Saws
How do we close 1 1/4" gap between two sides of table
You probably have either (a) not properly extended the legs all the way, or (b) have attached some of the cross beams on the wrong side.
http://www.sears.com/prince-fusion-table-tennis-table/p-00601215000P
click on this link and you can move the magnifying glass over different parts of the picture to see up close what the table should look like in the correct and finished position.
Dec 15, 2012 | Prince Fusion Table Tennis Table
I need an instruction manual.
Click on the 'Literature' tab here: http://www.mackay.co.uk/draper-expert-magnum-1000-workbench-86265-mwb1000-machine-tools-accessories-power.html - both manual and parts list available
Oct 12, 2011 | Draper Magnum 1000 workbench
I just brought a Powertec Multi workbench Home Gym I need a manual to assembel it
You can contact Powertec Fitness and they will email you a manual or send you a hard copy. Their Customer Service is great!
Jul 31, 2011 | Powertec Workbench Multi System WB MS10
I need the assembly manual for the powertec wb-ls workbench leverage gym.
there is no date on this post so if u still need the manual mail me (demirhan33@yahoo.com) april 2010..
Oct 04, 2009 | Powertec WB-LS Workbench Leverage Gym
Drills Logo
65 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
