Question about Schwinn Exercise & Fitness
Loosen stripped bolt
How do i loosen a stripped bolt? i tightened it by mistake and while trying to un-tighten it I stripped it :/
  • 20 Answers
Wedge something in-between the nut and what its holding like a flat head screwdriver this will give you leverage to allow the nut to move onto good threds
Posted on Mar 30, 2014
How to tighten alternator belt on 1993 pathfinder
Four cylinder engine - loosen bottom pivot bolt on alternator, then loosen top bolt and pull the alternator away from the engine to tighten belt. When at proper tension, tighten top bolt to hold tension and tighten bottom pivot bolt.
Six cylinder engine - loosen the lock bolt at the bottom of the alternator, then use the adjustment bolt (perpendicular to the lock bolt) to tighten the belt tension. Once properly tensioned, tighten the lock bolt.
Jan 30, 2017 | Cars & Trucks
Expand-It 40 volt locking collar T bolt stripped
http://www.ebay.co.uk/itm/Un-Used-Stihl-KM-Kombi-Power-Unit-Driveshaft-Clamp-Tommy-Screw-T-Bolt-and-Nut-/322089323385
Give these ones a try.. But NOTE; There is no need to tighten these up that tight.! There is no way that you should have to tighten them up enough to strip the thread.. its holding on an extension shaft together, its not having to hold the weight of a vehicle.
May 24, 2016 | Ryobi Garden
Handle bars
just under the part the handlebars go through (the gooseneck)
there is a bolt that takes a 6 mm allen wrench, tighten the bolt, If it still doesn't tighten it might be stripped (there are ridges on the bars and the gooseneck).... Some bikes have 2 shims that fit around the bars, not sure if yours did or not, they could have fallen out when it loosened up if so you need to replace them good luck
May 31, 2013 | Cycling
Torque for head for a 2.5 for an 1985 Buick Skylark
Loosen Headbolts in this order:
1 5 4
3 6 2
Tighten Headbolts in this order:
3 1 6
5 2 4
Following the tightening order, torque Head Bolts as following:
1. Torque All to 22 Ft Lbs
2. Torque all to 51 Ft Lbs
3. Loosen all 180 degrees
4. Loosen all 180 degrees
5. Torque Center Two bolts to 25 Ft Lbs
6. Torque Outer 4 bolts to 11 Ft Lbs
7. Tighten all bolts 90 degrees
8. Tighten all bolts 90 degrees again
Make sure you tighten all of them down the first 90* and then go back and tighten them another 90*. Also make sure you put some lube between the bolt and the washer, and put some sealant on the bolt threads. Use GM Thread Sealant.
Jan 14, 2011 | 1985 Buick Skylark
I have a 99 subaru legacy outback and am trying to find cylinder head torque specs. Cav you help me ?
sure. 2.5 liter engine, right? Thanks for using FixYa!
Secure the head in place with the mounting bolts. Coat each bolts with clean engine oil, and hand-tighten. Tighten the cylinder head bolts to the following specifications:
  1. Step 1: all bolts to 22 ft. lbs. (29 Nm).
  2. Step 2: all bolts to 51 ft. lbs. (69 Nm).
  3. Step 3: loosen all bolts by 180 degrees, then loosen an additional 180 degrees.
  4. Step 4: bolts 1 and 2 to 25 ft. lbs. (24 Nm).
  5. Step 5: bolts 3, 4, 5 and 6 to 11 ft. lbs. (15 Nm).
  6. Step 6: all bolts plus 80-90 degrees.
  7. Step 7: All bolts plus 80-90 degrees.
Dec 22, 2010 | Subaru Outback Cars & Trucks
Front left wiper came loose, it won't follow the right wiper, can I tighten a bolt or something?
yes you normally can un less is stripped from the arm to the links attach to the motor.
can you see the beginning of the arm does have a nut? or you can see a black round lift? if you see the nut normally tighten will be enough but if you see the lift take out with a flat screw driver to found the nut under need then you tighten if you have not success that's mean is strip and the whipper arm need to be replace.
Dec 14, 2010 | 2003 Toyota Highlander
How do you replace a serpentine belt for 1996 jeep cherokee sport?
You need to loosen up the power steering pump and un-adjust the jack bolt that runs under it. Then just follow the diagram on the sticker on the radiator support. If you can't find the sticker, I'll give you the routing if you ask. to tighten the belt just tighten the jack bolt and lock down the bolts you loosened on the pump. Tight is when you have about one inch deflection in the longest run of the belt,
Loose is better than too tight as you can re-tighten it if necessary. Too tight will damage pulley bearings.
Dec 05, 2010 | 1996 Jeep Cherokee Sport
How do i tighten belts on 1997 honda accord?
to tighten the thin belt, loosen the top and then the bottom nuts that go through to the frame. The turn the bolt on top, the closest to the front of the car, clockwise. Then tighten both through bolts up. For the thick belt, loosen the through bolt on the alternator, then turn the long bolt at the bottom, front of car, of alternator clockwise.
Apr 22, 2010 | 1992 Honda Accord
Replacement of a 4.0 1997 jeep fan belt.
in order to do this on the power steering pump you have to loosen a few bolts to let it pivot on the top bolt in the front, then on the bottom on there is an adjustment bolt try to mark where that is tightened to with some electrical tape and then loosen it until the belt can be removed. put the replacement belt on the jeep in the exact same way the older belt was on and then tighten the adjustment bolt on the power steering pump until where you marked it where it was previously tightened to. then tighten the rest of the bolts you loosened and try to start it up. Have Fun.
Dec 28, 2009 | 1997 Jeep Wrangler
Stripped head on a brake caliper bolt
I would try either vise-grips if you can get at it otherwise you may have to get a set of easy-outs. They work by you drilling a hole into the bolthead and then as you turn them they tighten in the opposite direction thereby loosening the bolt .. be sure to put alot of penetrating fluid wherever you can to get in and around the bolt shaft and threads ...
Mar 28, 2009 | 1999 Pontiac Grand Am GT
Exercise & Fitness Logo
55 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
