Question about Parker House Portofino Space Saver Entertainment Center
How do I connect the lights to get them to work? what to plug into for power?
Can't get lights connected to work
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 115 Answers
Not enough information. What lights are you wanting to connect 120/220 ac volt or 12 dc volts lighting?
Posted on Mar 30, 2014
LG 42LN5400-UA.BUSYLHR back lights not working, sound working, flashlight test shows video working.
This is a common problem for LG 42LN5xxx & 47LN5xxx LED TVs, the problem is defective LED back lights strips, it has nothing to do with main power supply & the main board.
Aug 31, 2017 | LG Televison & Video
Lost all elec.power to trailer plug on jeep
The trailer connection is usually fed off the wiring from the brake and tail lights If those work, my guess is the wire that goes to ground is open. try following the harness back toward the tail and brake lights looking for broken or corroded connections. If you have a meter or 12v test light try connecting the one end to a good ground if using a meter it should be the black or negative lead. Turn on the running lights and one turn signal while probing the plug if you get voltage or the light to light you have an open ground. Locate and repair the connection.
Aug 07, 2014 | 2010 Jeep Liberty
Moniter output not connect
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
May 20, 2014 | Computers & Internet
Front indicator lights
Check the conector plugs. These often get corrosion in them. You will need a test light.connect it to a good earth and stick the probe in the plug coing to the wiring loom. If u get power with the hazards on re connect the plug and try the same where the bulb goes in. Could also be the connection to the bulbs. If its a faulty plug cut it out and join the wires n should work fine. No power to anything its a broken wire or bad connection in the wiring loom
Aug 05, 2013 | 1995 Toyota 4Runner
I have a samsung notebook R580, it worked fine lastnight, will not turn on today no lights come on it is plugged in to a working plug in, any ideas
The problem could be the ON/OFF button but check the power adapter first.
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Feb 01, 2013 | Computers & Internet
Only power light goes on when I reconnect to electricity. WLAN and LAN lights stay off
It sonds like you are ethernet connected to the Edimax from your home computer. Can you access a wireless connection? If so Try This:
Unplug the ethernet connection between the PC and the router. Exchange the connection (The ethernet connected to the PC place it in the Edimax and Put the connection from the Edimax into the PC) Check to see if you have a connection light on both devices.
Reboot you Edimax and PC. First turn on the PC and let it power up to the desktop. Once the PC is on then power on the Edimax. Now check to see if you have a connection. If these steps don't work I suggest you try replacing the ethernet plug connected between both devices.
Aug 14, 2012 | Edimax EW7416APn (EW7416APN) Pre80211n...
I cannot connect my Belkin 54g to the internet at all. I followed the wizard and got the information from my ISP - user name and password. The wireless light works, the port shows that it working but the...
ghost2233_6.jpg Did you connect the lan cable to the right port ????
1. Shut down any programs that are running on your computer at
this time.
2. Make sure you have the following items at the computer that is now
directly connected to the cable or DSL modem. DO NOT CONNECT THE
ROUTER AT THIS TIME.
• The Easy Install Wizard CD-ROM
• The Router
• The Router power supply
• Category 5 networking cable
• This Quick Installation Guide
3. Turn off any firewall or Internet connection sharing software on
your computer.
4. Insert the Easy Install Wizard software CD into your CD-ROM drive.
The Easy Install Wizard screen will automatically appear on your
screen within 15 seconds. If it does not, select your CD-ROM drive
from "My Computer" and double-click on the file named "Setup" on
the CD-ROM.
5. Turn on your cable or DSL modem by reconnecting the power supply to The Wizard will take you through the completion of the process.
the modem.
6. Before plugging the power cord into the Router, plug the cord into the
wall, then plug the cord into the Router's power jack.
7. Verify that your modem is connected to the Router by checking the
lights on the front of the Router. The green light labeled "WAN" should
be ON if your modem is connected correctly to the Router. If it is not,
recheck your connections.
8. Verify that your computer is connected properly to the Router by
checking the lights labeled "LAN 1,2,3,4". The light which corresponds
to the numbered port that you connected your computer to should
to the numbered port that you connected your computer to should be
ON if your computer is connected properly.
Good luck
Mar 12, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
I seem to have a touchy USB connection, when I first got the Belkin and plugged my printer(s) into it, nothing happened, no connection light etc, after about 3 days I got it to light up, and it was fine...
The issue might be the port is broken, please try using another port to see if the issue persists. If it doesn't then the port it was previously connected to is broken and probably have to be plugged in at a certain elevated angle to work
Jul 11, 2017 | Belkin Wireless Share Router (F7D3302)
D-Link DI-534 Starting up problems
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
Jan 08, 2009 | D-Link AirPlus DI-524 Wireless Router
No power light, cannot connect
What is the status of the local area connection on your computer if its connected directly to the router?
Jul 29, 2008 | Linksys Wireless-G WRT54GS Router...
Parker House Portofino Space Saver Entertainment Center Logo
216 people viewed this question
Top Parker House Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Parker House Furniture Expert? Answer questions, earn points and help others
