Question about Boating
1 long 4 short alarm for DF225Z
What does this mean?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 15 Answers
I'm not sure try this
There is an alarm and the oil ,symbol flashes when its due for an oil change, 20hrs then every 100hrs, or overheating, low oil or clogged oil filter
Posted on Jun 02, 2014
2 Suggested Answers
  • 1162 Answers
SOURCE: alarm codes for Suzuki DF225Z
Those codes seem to be kept under hat. Unless you can find some on the hull truth to give it to you. I searched an found nothing. I wonder if you will have to call a service department.
Posted on Mar 30, 2014
I have an aftermarket alarm system that has drained my battery
Dear Mary. All car alarm systems drain the battery after one week of the car not being used. Also, car batteries are not always fully charged on short trips because to start the engine on each short trip it drains a tremendous amount of power and a short trips do not recharge it fully. Have the car battery checked because the alarm is always on and on standby once installed, they usually have a small back-up battery in the alarm in case of car wires to the alarm have been cut, but that battery is always kept charged by the car battery, so, that is only causing a fraction of car battery discharge. However, to stop it from draining the battery you have to disconnect the alarm, and that is not a good idea. No car alarm that I have known have caused any car battery discharge, but of course if the car is not being used, or it is driven for short periods you are likely to experience a drained battery. Some batteries last more than 5 years not stop while cheaper ones have a lesser life expectancy, but again that depends on a lot of factors, heat from the engine, not enough charge because the alternator has a burnt diode, interior lights left on, too much cranking of the engine to start it and not enough miles done to recharge the battery. Try to get the battery checked and if you do not do any driving for a week, there are a number of solar powered battery charging panels that trickle charge it on sunny days but in winter I suggest you buy a charger that you can connect to the battery to keep it charged. Once charged the charger automatically cuts off and stays on stand-by until the car alarm has discharged it a bit, then the charger sensed the voltage drop and recharges it again, repeating the cycles until you need the car to go out. These small car battery maintenance chargers are inconvenient if you're not using the car too often. Some car alarm with go off when the car battery is disconnected. It's part of the protection the alarm offer. They may not be disconnected from the car battery unless you have a key that shuts off the alarm. But remember, the key shuts off the alarm but it doesn't mean it has disconnected the power from the battery. Check the pilot light status. If it flashes after the alarm key has been turned to off, it means the power is always there. Other alarms remain silent when the car battery has been disconnected from the clamps. If you garage the car at night, you can have a switch installed in the car that switches on the power to the car alarm or you can have the switch connected to a special relay activated Kill Switch that disconnects the battery altogether, but if your car alarm starts to squeal, then you don't need this switch. so try it first, disconnect the car battery and see if the alarm goes off. If not, then the Kill Switch is an option. If it goes off, then there is nothing you can do but to try and have the car battery checked and if you're not driving much or drive short trips, either a solar charger or a Mains powered auto charger can be used to keep the battery trickle charged. But before I go, you say you got an after market car alarm. Looks like it has been wrongly wired, who know. Have it checked by whoever installed it. Good luck.
Mar 17, 2015 | Jeep 1999 Grand Cherokee Laredo
JANDY EA2000T POOL HEATER H20 ALARM
shorted temp sensor replace
Apr 10, 2014 | Jandy Pool & Spa
Alarm codes for Suzuki DF225Z
Mar 30, 2014 | Boating
My display says F3 and the oven won't turn on. What does this mean?
F3: Open or shorted sensor. The cancel key resets the control and stops the alarm. If fault is still present it will reactivate the alarm when the cook mode is chosen. Correction: Check sensor and wiring for shorted or open circuit.
this is on a maytag oven many ovens have their own code
Feb 11, 2010 | Kitchen Ranges
Alarm burning issues. Electrical or just a cheap alarm?
means you have a shorted wire, it keeps touching the body or a ground wire causing the door to say its open. you also more then likely have a bad door switch. check the simple things first
Jan 28, 2010 | Vehicle Parts & Accessories
Corn horn beeps when I lock the doors using the remote. Could this be an electrical short?
no it just means that your car is now locked...
is like a feature. or like an alarm. it means locks are set.
Dec 29, 2009 | 2003 Chevrolet Malibu
What does the F3-1 code on a Maytag flat top double oven range mean?
Well error F3 means open or shorted sensor. The cancel key resets the control and stops the alarm. If fault is still present it will reactivate the alarm when the cook mode is chosen. The error F3-1 indicates problem with Sensor of upper oven
Solution - Check sensor and wiring for shorted or open circuit. you need a multimeter to check them. Please post comments for further help or information........
Good Luck!!
Thanks for using FixYa!!
Dec 18, 2009 | Maytag Kitchen Ranges
Alarm light is RED and data light is AMBER - both are on permanently
This means toner is empty. This condition was probably preceded by a period of "toner low" indications, data- and alarm LEDs blinking shortly every fifth second or so (maybe you never noticed that). Replace toner cassette and it should work normally.
Jun 02, 2009 | Brother HL 1440 Laser Printer
D945GNT motherboard is giving an alarm
yor mainboard is working or not first?
second if is not working they are two posibilities, one your ram is gone , or miss placed or something else, second your processor is gone or wrong.
if it is working i dont now, anyway in the both cases try to clear the bios rom first
Apr 01, 2009 | Intel D945GNT Motherboard
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Boating Logo
22 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
