Question about Video Game Consoles & Games
Nead to long. in
Nead to log. in
    Master:
  • 508 Answers
Well need more info then that
Posted on Apr 01, 2014
No problem, except we need a manual for our Remington Bread Maker BM-50
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, and Installation Instructions as required.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
I hope this helps.
Jan 11, 2011 | Microwave Ovens
My Whirlpool works in every way but will not spin.
sounds like a bad door switch,to replace the door switch you will nead to remove the body.first you nead to remove the two screws behind the control panal one on each side.next pull the panal forward and flip it up.next you nead to unhook the door switch.next you nead to remove the two s-clips one on each side.next you nead to pull the body forward and remove the body.now you con remove the two screws that holds the door switch on under the door next remove the door switch connecter from the body and install the new one.next reasemble unit
Dec 18, 2009 | Whirlpool LSB6200KQ Top Load Washer
Ice continually forming on bottom of upright freezer
you nead to clear the drain.when you clear the ice you nead to make sure that the drain is clear.a spider can build a nest in your drain line.if you remove the ice,you nead to clear the drain line with a hose.you nead to blow though hose and clear line.
Nov 18, 2009 | Ovens
DRUM WILL NOT SPIN AND MAKES HUMMING NOISE AND TURNS OFF WITHIN 5 SECONDS
you will nead someone to help you to know if you have a bad moter.first you nead to open the door,with your right hand you nead to push in on the door switch and hold it in.next you nead to have someone puah in on the start switch,at the sam time ,you nead to take your left hand and turn the inner drum clockwise, if it starts than you have a bad moter.
Nov 18, 2009 | Roper REX4634KQ Electric Dryer
I have a Kenmore special edition model # 110.63912100 (S/N ML350387S) that will not heat. What do you suggest, heating element, thermostat, or ???
first make sure you have 240 going to the dryer.you will nead a meter check this.if you have 240 ,than you nead to unplug unit.pull unit out and take back panal off.on the right side you will see the heating colom.at the top is one of the high limit switch's.you will nead a continueaty meter to check this.at the bottom you will see the other high limit switch.make sure you unplug wire's before you check them.under thst you will see the heating element.remove wire's and check out element.also look for bad wiring.if all check good, you nead to call for service call.
Nov 16, 2009 | Kenmore 62802 Electric Dryer
No heat the dryer runs light is on it just will not heat up
nead to check ignitor,then the flame sencer on the right side of the cone.then check the high limit thermal switch on the left side of cone.you nead a continueaty meter to do this. if they check out you nead to call for service call.
Nov 15, 2009 | Whirlpool LGB6300 Gas Dryer
My Roper dryer won't start?
first make sure you 220 going to you dryer.next you nead to unplug the dryer.next you nead to remove the vent hose.next you nead to remove the back panal and power cord cover.on tge lower left side you will see a white plastic switch with two blue wires going to it.this is the thermal switch.if you use a meter and the switch is open tha you nead to replace this switch.part#3392519
Nov 11, 2009 | Roper REX4634KQ Electric Dryer
Dryer has power when i hit the start button it hums and dryer does not spin or heat
you will nead a nother person to help you see if you have a bad moter.first you nead to open the door and with one hand you nead to push in and holddoor switch, now have someone push in on the start switch and at the same time you nead to take your other hand and turn the dryer drum clockwise,if dryer start's than you have a bad moter.
Nov 08, 2009 | Whirlpool LER5636P Electric Dryer
Model # is LSR8233EQO Top portion of the agitator seems loose and does not agitate properly?? Does is remove? It seems to unscrew??
you have to replace the dog's in the top ov the agitator.the part# ror this part is WPL80040462.the cost is $4.62.to replace the dog's you nead to remove the fabrick sofeiner assembly from the top of the agitator.next you nead to remove the top cap.now you nead to use a 7/16 socket to remove the bolt in the agitator.now you nead to grab the agitator at the bottom and pull it up.now yopu nead to seperate the top from the bottom.place the agitator on the floor,put a foot on both side's of the bottom of the agitator and pull up.now you the top portion of the agitator.turn top portion upside down and remove the cam.you will see the rubber dog's.replace the dog's and reverise the prossess.
Oct 05, 2009 | Whirlpool LSR5132PQ Top Load Washer
How to time a 1995 nissan maxima engine.
wat did u do to make u do the timeing az thay r not over head cam. so if u did head gasget u dont nead to do the timing. timeing how to set check the crank make 1piston top dead senter right up top then u nead to go to your cam u nead to find 1 on the cam on the mark on the block there will be a mark or if u r good with motor,s put the cam so u just went past inlet then it fires then out let them u nead to take off your dizzi cap make your points line up get the leads on the dizzi cap right or u will hav fun an games
May 27, 2009 | 1995 Nissan Maxima
Video Game Consoles & Games Logo
13 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
