Question about RCA Televison & Video
Rca home theatre twin tuner pip wont turn on it clicks 4 times whats that mean?
My tv will not turn on at all. i checked the power cord and tried different outlets. when i push the power button the tv makes four clicks and stops no picture or anything.
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
My rca home theater HP TWIN TUNER PIP crt tv will
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 15, 2014 | Televison & Video
Cant get hd sound through home theatre system
Hi,here is my simple solution...
to listen your TV on your
Panasonic Home Theater System
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out "of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
Panasonic Home Theater System RECEIVER corresponding your RCA or Optic or HDMI connection
There you go..Your TV sound is on the
Panasonic Home Theater System Receiver..By this means whatever you watch on the TV (TV tuner, satellite , Xbox ..etc.) ,it's sound will come thru your stereo..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Thanks
Jun 26, 2011 | Panasonic Home Theater System System
I have a sony (model KP61V75) a split screen came on (two pictures) and I cannot figure out how to get it back to one screen. Im going crazy!
Some television remote controls have a PIP OFF button, while others only have a PIP button that needs to be pressed repeatedly until the PIP/Twin-View window disappears.
NOTES:
  • Some Sony rear projection televisions have a FLASH FOCUS button that will turn off the PIP/Twin-View feature.
  • Some Sony universal remote controls, if programmed to operate a Sony TV, can disable the PIP/Twin-View feature by pressing the REC or ENT button.
  • If the original TV remote control is not available or is not functioning properly, auto programming the television tuner orperforming a power reset may deactivate the PIP/Twin-View feature.
  • If pressing the appropriate buttons on the TV remote control does not work, then the PIP/Twin-View window might be from a two-tuner cable or satellite set-top box. If this is the case, use the remote control provided with the set-top box to remove the PIP/Twin-View window.
Jan 25, 2011 | Sony Televison & Video
No sound on my RCA TV, Home Theatere H P, Twin
http://elektrotanya.com/rca_ctc179cm_chassis.pdf/download.html
Please find above your service and repair manual, all is inside this manual.
May 24, 2010 | Televison & Video
Hi, The quetiopn is about SONY DVD home theatre system DAV-HDZ235. For some reason I have big black box on a TV screen at time DVD playing. The picture appears and box dissapears when I pushong volume on...
Thanks for giving me the opportunity to help. Sounds like you are inadvertently activating P.I.P (picture in picture) with your remote. Perhaps the P.I.P button is next to the volume control. The black box you mention, is a blank channel. That means the way you have your cable box set up, there is no signal coming in to that p.i.p. tuner. Press the P.I.P. button and see if that's what's happening.
If this advise helped you, please give me a rating so I can make my boss happy! Thanks for using Fixya.com
Jan 27, 2009 | Sony HOME THEATER SYSTEM System
RCA Home Theatre - Tuner problem
you may coldsolder the tuner first before replacing the new one,maybe it can works.
Apr 30, 2008 | RCA TruFlat 27F520T 27" TV
Power supply regulator for rca 52" home theatre twin tuner pip
no parts from a pioneer wont work. There are roughly 4 regulators for the power supply maybe 5. The sad thing is they cost between 7 and 20.00 , he didnt happen to mention which power supply was affected did he? You would have to check the various regulators out of circuit to determine which one is bad. If its a F.E.T they are hard to check without the proper equipment.
Apr 05, 2008 | Televison & Video
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
