Question about Fisher and Paykel DGGX1 Electric Dryer
I just replaced the heating element and manual reset button on my electric dryer. After putting everything back together, I started plugging in the plug until I heard a POP. I immediately pulled the
Dryer is not powering up
  • 20 Answers
Dead short
Posted on Mar 30, 2014
  • 641 Answers
SOURCE: heating element doesn't heat
Well done !
Posted on Aug 04, 2007
jsrock516
  • 5911 Answers
SOURCE: Dryer takes too long to heat
Okay...I'm not familiar with the configuration of Fisher and Paykel dryers. I am familiar with many other dryers, though. If the wires become melted this is usually caused by excessive current flow or a loose connection. When wires at a terminal become loose the intermittent connection can cause arcing which leads to the generation of heat, which causes the wire or connector to burn open. I have also seen heating elements short out against the casing and cause an excessive current flow problem.
Just so we're clear here, current is the force that causes electrons to flow. It is usually measured in amperes (or amps). What you are measuring is the voltage. Voltage is the difference in potential between two points. If you were to measure voltage between two points (such as through a simple wire coil) you would read 0 volts because there is no differnce in potential between the two points, as the coil should read a short. Now, if you have a RESISTIVE coil, or a coil that is open (broken) the same measure would yield a voltage reading, because there is now a difference in potential between the two points. Does this make sense to you? I know it can be confusing at times because you normally associate a voltage reading as something being good. In a nutshell: if you measure across a wire coil and read voltage - the coil is open. If you read 0 volts - the coil is good.
Who knows what caused the melted wire in your appliance. The one thing I am sure of is this is not normal. If you want to replace the relay to be sure, that is your judgement call. Relays do go bad. I would strongly recommend replacing the heating element as it appears that this model has a dual element that will still work (to some degree) if one side fails. Very ingenious design, by the way.
In addition, a lot of heat related problems associated with dryers are attributed to poor ventilation. A dryer requires proper air flow in order to work efficiently. If you have not cleaned or inspected your dryer vent ducting recently (or ever), you may want to. This is the source of many dryer malfunctions and can create a fire hazard or habitat for rodents. The rule of thumb when it comes to ventialtion is: The SHORTER and STRAIGHTER the ventilation, the BETTER. Every bend or rise you put in a dryer exhaust vent line creates resistance against the blower motor and possible choke points for lint to accumulate. The lint screens in dryers are not perfect and they do not collect ALL the lint. Simply cleaning the lint trap in many cases is not enough. Cleaning after every use, however, does cut down on the potential for your ducting to become clogged. If a dryer is allowed to run in a condition where it has poor air flow, the heating circuits will actually overheat to the point of failure. I mention all of this because I don't want you to replace parts only to have the appliance fail again due to poor ventilation.
I hope you find some of this information helpful. Let em know if you have any further questions.
Posted on Sep 12, 2008
heatman101
  • 43501 Answers
SOURCE: Replaced heating element for dryer.Dryer started
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: Electric dryer not heating. Already
Sorry to read about your problem. Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Posted on Jan 03, 2011
  • 96 Answers
SOURCE: Our dryer will no longer
is anything coming on at all on the dryer????? lights or any sound when you plug it in??
Posted on Mar 04, 2011
I have a whirlpool front loader dryer duet, and I am not getting any heat! My husband and I took it all apart and cleaned everything and checked all the fuses and elemts everything was working just fine,...
make this test and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating Element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. The proper ohm reading can be found in the service manual or sometimes on the tech sheet located somewhere on your dryer (9- 13 ohms is a common reading). Electric heating elements aren't repairable. The heating elements faulty, replace it.
Thermal fuse / Thermal Cut Out / Thermistor
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel or behind the cover .The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing They are also round and made of metal and plastic. The thermistor is located on the blower housing usually. If any of the fuses do not have continuity replace it. Check for continuity if none replace, But before replacing check for obstructions. The fuses are very inexpensive and replace it
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. Check all connections, make sure they are tight. Loose connections can lead to a fire. You may need to replace power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 02, 2013 | Dryers
I have a Bosch nextt 500 series dryer and after 2 years of use the problem I have is the heat will shut off and the dryer will keep running and I have to press the reset button on the backside of the dryer
Open the front panel, remove heat exchanger and clean. also clean out lint tray. this might help a little. Now lets check if the thermal sensor or heating element needs to be replaced.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button. To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the thermal sensor. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Feb 01, 2011 | Bosch Axxis WTL 5410 Electric Dryer
Samsung electric dryer
How old id the system?
If warrenty is over, Open or remove metal covers.
Before you start, unplug your unit.
After you removed panels or opened your unit, on one side should be the element compartment. At the bottom of compartment, is two wires. remove and then take a Ohm meter and check the element. That ok you won't hurt yourself, because you unplugged it.
If you have a reading or the needle moves... your element is fine.
That would mean something else is wrong.. Follow the plug into the unit..
Are the wires burnt, Has one falling off... It needs replacing
Sometime the circuit breaker trips... only half.. so go and reset your breaker and put the dryer back together
Jul 27, 2010 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
I have a Bosch WTL5410 dryer, which has no heat going to the otherwise functioning tumbler. Do you know where I could purchase another heating element and where I can get instructions regarding the...
Open front panel, remove heat exchanger and clean.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the switch. This is your reset button. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Mar 24, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Start button doesnt start the dryer
Sure sounds like a door switch to me. Is anyone slamming the dryer door? Was there a rubber bumper on the door that is now gone?
Mar 27, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer won't heat
I have a F&P dryer DEGX1 about three years old , followed kristi's advice and it worked. There are two screws holding the information panel on, inside there is a schematic with instructions on how to put the dryer in diagnostic mode and how to take the front panel off. i reset the breaker located at the bottom of the front panel on the heating element box and put it back together and it worked.
My vent cover outside was frozen shut and this caused the breaker to blow saving the heater elements, am changing the vent cover to a different design to prevent this happening again
Jan 26, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Bosch wta3510us tumbling NOT heating. Reset button?
Remove your back cover ,and then you see the heating element.On one side or on top there is a termostat(Small Black)there is a red button which you should press down until you hear a click.Start machine and element should work.You can start it for a little while but be careful.Put cover back after cleaning loose lint etc. Jan
Jan 09, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Getting into a ge harmony dryer seen some posts on it not heating up cannot get to element to check it model #dpgt750ec1ps
taking everything out though the front my breaker was bad not getting both legs of my 220 after I put it all back together I trip the high temp thermister and had to take it all back apart to reset it so do not run your element without air over it for to long.
Nov 29, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryer won't heat
remove plugs on each side of top under lid remove 2 phillips screws lift top remove screws on inside top each corner ..front will pull forward and off look on element assembly for reset button on small round thermostat press to reset..be sure you have clean lint screen and housing behind it ckd vent to outside also element may be shorted together causing it not to shut off properly when temp is reached
Aug 25, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Dryer does not turn on
Sounds like the motor relay is not functioning. Sometimes the motor will work if the button is pushed but will stop when the button is released. This is caused by a loose wire at the motor or a bad motor relay.
Oct 18, 2007 | Amana DLE330RAW Electric Dryer
Fisher and Paykel DGGX1 Electric Dryer Logo
61 people viewed this question
Top Fisher and Paykel Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
