Question about Magic Chef CMV1000B Microwave Oven
Lost total power of microwave wondering if it could be a bad fuse?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 119 Answers
Check fuses
Posted on Mar 31, 2014
    New Friend:
  • 12 Answers
There is a white ceramic fuse hidden in the control panel area that is likely the culprit when total power is lost. You will not find a word regarding this fuse anywhere in your owners manual, but all microwaves have them. You will need to remove the outer shell of the microwave to access it. Once you have located and removed it, you can check it with a multimeter set to continuity. If it is blown, the replacement must be another ceramic fuse. Because of the high amperage that this fuse carries, if you try replacing it with an automotive type glass fuse and it blows, it will explode and scatter glass from the fuse throughout the insides of the control area.
Posted on May 09, 2014
    Problem Solver:
  • 7 Answers
If you feel confident enough in your electronic skills (metering, soldering, etc.), unplug the oven, remove the screws that hold the cover in place (usually along the backside outer edges - depending upon the model of over, and have a look at the circuit - starting from the point where the power wire enters the oven and connects to the transformer. As you follow along, you might encounter a fuse, either inline along the power wire, or in a bracket on the circuit board. Look for any obviously blown/burnt component (typically one of the small electrolytic capacitors). If you have a multi-meter, and know how to use it, all the better. Simply work your way along the circuit until you find the short/break.Note the value and voltage of the component and order a replacement (I user Mouser). Or you might get lucky and find that something is loose. It happened to me a month or two ago, when I popped open a very new microwave a friend let me have that appeared totally dead. When I opened it up, I found that the power connection to the control circuit board was ever-so-slightly eschew, apparently from being dropped. I snapped it back in place, and it's been working like a champ ever since.Good luck!
Posted on Apr 03, 2014
No power to my Panasonic microwave
assuming u have pwr to the plug - and nothing lights up = it is probably a bad transformer - open thermal fuse.
WHICH was probably caused by a shorted mag, which means junk.
Feb 02, 2016 | Panasonic Genius Prestige Inverter...
Lost all power
Door switch is bad or a fuse blew out inside the microwave cover housing. Switch is most common.
Feb 06, 2014 | Sharp R-1480 Microwave Oven
Have a ge pvm1870sm3ss micro lost power after use open door a couple times came back on did it again after use but now it is total dead can anyone help?
A door switch or two are bad and it took out the main fuse.. Change the door switches and fuse. Get the correct parts and make sure you get the switches in the proper locations and configuration
Jan 26, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
We have a Hotpoint RVM1435WJ01 above the range microwave. We lost our electricity one day due to an outside electric wire splitting - when the electric company fixed the wire, the power came back to...
A mains surge may have taken out the fuse. To find the fuse, remove it from the mains, remove the outer cover and follow where the power cable enters the case. There will be a PCBoard with a fuse on it.
Always replace the fuse with one of exactly the same type and value!
Mar 21, 2011 | Hotpoint RVM1435 Microwave Oven
My model nn-p295wf microwave stopped working ,all power just stopped, about a year ago. I took it to a repair shop and they replaced the DIODE and the fuse, then it worked again. Afew weeks ago it happened...
Replace the magnetron, safety fuse and diode as a set and check the door interlock switches.
That should get it working for another year or so.
Don't forget microwave mains fuses are special sand filled and semisurge type.
Nov 16, 2010 | Panasonic NN-P295SF Microwave Oven
No power to microwave
Hi
When your microwave oven doesn't work at all, it means interior fuse inside the microwave has blown (usually a part inside the microwave makes this fuse blow). Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well. If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. It can also be due to a stuck or faulty door switch which might have blown the interior microwave fuse.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 14, 2009 | Microwave Ovens
Microwave LG LMV1630 st is totally dead after power outage
yes it s a large ceramic fuse and you have to remove the outer cover to access this. it will be on the top of the M/wave frame either front L or front right. Cost is about $40.00
Please rate our help to keep the sevice online
Aug 20, 2009 | LG LMV1630ST Microwave Oven
My Panasonic The Genius microwave just stopped working not getting any power to display. Wondering if it is the fuse and where that would be located.
HI, if this unit is totally dead, this may be a power inverter issue. there is a fuse located on this board inside the unit. you will need to gain access to this board and fuse by removing the outer cover. there should be a few screws on the outside of the microwave to remove.
Check the In-line fuse for its value. if the fuse is good, replace the power unit(inverter board)
Jun 20, 2009 | Panasonic Microwave Ovens
Does not turn on at all it's totally dead
It may be a fuse or, the power supply board. you can check the fuse by removing the cover. the (IN-LINE) fuse is located on the power supply board. check it for continuity. if the fuse is in good condition, replace the power board.
Jun 03, 2009 | GE JVM1631 Microwave Oven
Magic Chef CMV1000B Microwave Oven Logo
104 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
charles
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
