Question about Vehicle Parts & Accessories
Map,vanity,glove box lights
2012 Ram 1500. These lights would worked intermittently for a time and then stopped. I finial found that if I unplug a the big plug just right of the brake pedal and replugged it (reset) (it has a white handle) the lights would work for the 10 minute power save mode and then would not work again until reset. Also if I started the truck after reset then would appear to only work a could minutes at first and appear to working longer now. Need to know what relay number that might be sticking and if it is in the fuse box in the engine compartment.
    New Friend:
    Problem Solver:
  • 8 Answers
Locate the fuse that provides power for these lights and clean the prongs of the fuse using a knife ,razor blade or sandpaper.If this does not help,I would find out from the dealer if they list a module for these lights and if so replace it.hope this is helpful to you,good luck.
Posted on Apr 23, 2014
Why does my 2012 dodge ram 1500 fuel pump stay on...
About 117,000 results (0.73 seconds) Search Results
    TIPM Repair & Bypass Solutions for 2007-2014 Dodge ...
    www.verticalvisions.com/TIPM_solutions.php
    2011-2012 Dodge Ram 1500; 2011-2012 Dodge Ram 2500; 2011 Chrysler Town ... test your fuel pump relay, and bypass a bad fuel pump relay to stay on the road. .... Mytesting/bypass device will often narrow down your problem to the TIPM ...
    Dodge Ram 1500 Questions - fuel pump keeps running ...
    www.cargurus.com > Questions > Dodge > Ram 1500
    CarGurusNov 1, 2013 - fuel pump keeps running when key removed - 2011 ram 1500 slt quad ...fires right up but will not stay running unless I keep my foot on the gas.
    I Changed The Fuel Pump On My 97 Dodge Ram 1500. Ran ...
    CarGurusI changed the fuel pump on my 97 dodge ram 1500. Ran great for 2 days then stopped running. I can hear pump working, replaced fuel system relay, engine tur... ...Jun 24, 2012 at 03:48 PM about the 1997 Dodge Ram 1500 2 Dr ST 4WD ... The truck fires right up but will not stay running unless I keep my foot on the gas.
    2011 Dodge Durango Fuel Pump Relay Stays Engaged ...
    www.carcomplaints.com/Dodge/.../fuel.../fuel_pump_relay_stays_engag...
Feb 03, 2016 | Dodge Cars & Trucks
My intermittent wiper mode seems to only work on occasion, never consistently.
RAM 1500 Intermittent Wiper Screwed Up / broken. - YouTube
? 0:31
www.youtube.com/watch?v=bljgrhugbBI
Oct 29, 2012 - Uploaded by Jude Augusta
RAM 1500 Intermittent Wiper Screwed Up / broken. ... Update: AFTERMARKET PART (NOT the original) works PERFECTLY: (603) 758-1046 is the CITGO in Hampton, NH ... I lived with it in my 04 Ram but now there is no intermittent - its on or off. ...Replaced the wiper motor - it has the "intelligence" in it.
Oct 23, 2015 | 2004 Dodge Ram 2500
Where is the fuse/s for the map lights and dome lights
ANSWER by patrick mannion on June 01, 2010
Looking at a wiring diagram the dome light and rear reading lights operate through the body control module. Check the BCM 2 fuse, BCM 1 fuse and BCM cluster fuse they may all be in the circuit. These fuses are in the engine compartment fuse box.
Dome glove box trunk vanity map lights all out 2003 Saturn L300
Aug 05, 2015 | 2003 Saturn L-Series L300
2012 gmc savana blower motor works some of the time and some time it doesn't
when it does not work wack the motor or check the voltage at the motor i think under glove box or under hood
Feb 15, 2015 | 2012 GMC Savana Cargo 1500 Cargo Van 4.3L...
I have a 2000 dodge ram 1500, everyday i go out in the morning the battery is dead. bought new battery and put in a new alternator, truck still is dead each morning. anyone have a clue what would be...
Check your convience and vanity type lighting to be sure they are shutting off( underhoodlight, glove box, back sun visor mirror lights, etc...). Next you can use a clamp on amp draw gun and follow the draw thru the harness to the problem. This tool is available at most auto parts stores. Also, just because a battery is new doesn"t mean it Good!
Jan 27, 2013 | 2000 Dodge Ram 1500 Truck
Trunk cargo light not working after LED installed....
The SJB supplies power to the interior lighting system. The SJB will set DTCs if certain circuit failures exist with the interior lighting system.
Visual Inspection Chart Mechanical Electrical
  • Courtesy lamps
  • Map lamps
  • Luggage compartment lamp
  • Vanity lamps
  • Glove compartment lamp
  • Smart junction box (SJB) fuse 3 (15A)
  • Circuitry
  • Courtesy lamps
  • Map lamps
  • Vanity lamps
  • SJB
Check fuse # 3 SJB
Jul 07, 2017 | 2010 Ford Fusion 2.5
2006 Dodge Ram 1500 with hemi. AC intermittently stops blowing
Sounds like the blower motor or the connection to it is failing.Next time it stops give the area below the glove compartment a good whack,if the blower does anything,change it.
May 30, 2017 | 2006 Dodge Ram 1500
2004 Ram 1500 1/2 ton 2WD. Code P0068 is what is coming up. Truck will idle high/low at times and will die sometimes when I stop. Engine light is on, I have checked for vac leaks and cleaned the sensor...
It's a map/tps sensor correlation code, essentially it means the map sensor reading isn't what's expected with the tps reading and vice versa! It sounds like your tps sensor is probably bad or the circuit to one of those 2 sensors.
Hope helps (remember rated this).
Aug 17, 2010 | 2004 Dodge Ram 1500
Vehicle Parts & Accessories Logo
83 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
